Like Tree3Likes
 Old 07-15-2011, 12:49 PM   #41
rikyrick87's Avatar
Posts: 266   (View Stats)
rikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the world
Groaned at 6 Times in 6 Posts
Alright, well today I went out and did some runs, all in third gear. I'm not quiet sure what I am suppose to be looking for/targeting/doing? If someone could look these over for me and let me know how they look i would greatly appreciate it.
K&N SRI COBB TIP: COBB AP(FREEKIN'): AutoTech Internals: CS Racepipe: JBR Stage 2 SSP: JBR Heavy Knob: JBR Trans and RMM.
rikyrick87 is offline   Reply With Quote
 Old 07-15-2011, 12:57 PM   #42
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
I really don't want to say this, but you need to master the sticky tuning thread on ECU Tuning subsection before you start messing up anything on the map. It's just that you sound like you have no idea how this car works. When you are completely comfortable with what you are doing, then do it.
Here's the linky for the thread. It's a long thread, but you need to read everything.
Gen 2 Cobb ATR discussion
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 07-15-2011, 01:00 PM   #43
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
You need to do better logs...in the first one you stopped at 5200RPM. You need to go higher than that.
 Old 07-15-2011, 04:15 PM   #44
jaybhola's Avatar
Posts: 12   (View Stats)
jaybhola is an unknown quantity at this point
Default Blow of valve
where is the best place to get work done on my ms3? I live in NY.
jaybhola is offline   Reply With Quote
 Old 07-15-2011, 05:26 PM   #45
rikyrick87's Avatar
Thanks for the thread man, and don't worry about my feelings all this stuff is new to me and im kinda trying to learn on the fly. Good lookin out.
 Old 08-04-2011, 01:05 PM   #46
rikyrick87's Avatar
OK, Ive been on vacation for a little while, but I got some logs done the other day. I've been reading up on the thread posted above, but I'm still not exactly sure what all i am looking at. Anyways again if somebody could look at these for me and let me know where i stand i would really appreciate it.
 Old 08-04-2011, 01:08 PM   #47
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Wait till the mods start coming in, your gonna love it even more..
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
 Old 08-05-2011, 01:52 PM   #48
computergeek's Avatar
Posts: 272   (View Stats)
computergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the world
Groaned at 8 Times in 5 Posts
log 8, 9 and 10... assuming based on rpm and top speed you are doing only third gear pulls and based on boost temps it was about 85-90 degrees.
means your boost is low and could maybe go up a bit. however your AFR is a little rich too. FP is a little low and you want that to stay at 1700 or more. so maybe for your setup 15PSI is all you can get safely.
Try to lean out Fuel a tad adn see if that brings on knock or not.
Log 9-10 looked more consistent with boost though, still rich though. But you have no knocking so you are good to go!
computergeek is offline   Reply With Quote
 Old 08-05-2011, 09:55 PM   #49
spizot555's Avatar
Posts: 48   (View Stats)
spizot555 has a spectacular aura aboutspizot555 has a spectacular aura aboutspizot555 has a spectacular aura about
Any suggestions on what to put on next?
For the most bang for the buck, I would go with a RMM. I don't know if mine was defective, but I got much more fun and drivability from the RMM than any of my mods other than the intake so far.
My stock motor mounts were loose and it made shifting tricky because the motor and everything was just rocking back and forth.
I also have the KN and have had no CEL's. Actually, thinking about cleaning the filter this weekend.
2010 Speed 3. Hooker Red. K&N Typhoon intake, Corksport TIP, CP-E RMM, CP-E driver and passenger motor mounts, Corksport catless test pipe, CP-E CBE, CP-E TMIC.
spizot555 is offline   Reply With Quote
 Old 08-05-2011, 10:03 PM   #50
spizot555's Avatar
Originally Posted by dereeek View Post
These are the mods I did in order on my 2011: JBR short shifter with solid shifter base bushings, Cobb AP, Cobb Sri/Tip, forge bpv, cp-e rmm, Denso ITV22, Greddy oil catch can and than re-flashed the ECU to Stage1+SF+TIH 93 BT. also, i did a few little misc things like HIDS, shark fin, and had the res cut out for a little more sound.
My car transformed from awesome to awesome...
I went KN intake, then CS TIP, then Cp E RMM, CPE side motor mounts, then CS test pipe and CPE CBE.
Needless to say my next is either fuel pump or AP. Then....I want the downpipe (or...a mild sound system upgrade or a remote start.)
Page generated in 0.31512 seconds with 26 queries
