| AwAfrican | 03-12-2017 06:28 PM | Quote:
Originally Posted by Mechman1978
(Post 3109803)
OK, I appreciate it. I will go with oil for gauges. I want to make sure I can see as much as possible. May wait until the ap is hooked up so I can see what I need. | You can see AFR, hpfp pressure, boost, coolant temps, fuel trims, knock, mass air flow, intake temp, BAT to name some of the most comm watched temps (can display up to 6 a time of you have a v3). Don't know if you've seen these but probably one of my favorite on the market http://www.innovatemotorsports.com/p.../MTXD.php#3852 |
