  • 1 Post By mitch11wmm
 Old 02-12-2018, 06:41 PM   #1
mitch11wmm's Avatar
Posts: 11   (View Stats)
mitch11wmm will become famous soon enough
Default Fog Lights Stuck On, Ugh
Hey everyone,
So I bought a 2012 Speed3 about a month ago and have loved it so far, however, today it started acting like a normal Speed3 lol.
I walked out to my car after class and my fog lights were on. I started the car and plugged in my AP and read the battery voltage to be 14v (previous owner bought a battery less than a week before I bought it), therefore, they must not have been on long.
I drove home and after shutting off my lights and locking my doors, my fogs were still on. I have pulled the fuse and it looks okay. I disconnected the battery for a minute or two and when I plugged it back in, the fogs immediately came on. I am trying to find out which relay controls the fogs now but cannot find a direct answer.
does anyone know which relay is the fog light relay or has anyone had this issue?
I have read it could be the body control module also. this weekend I am going to be tracing wiring and looking for a short however, since the fuse looks good I think this is highly unlikely.
TLDR: fog lights wont turn off. Can't determine which relay is the fog light relay.
mitch11wmm is offline   Reply With Quote
 Old 02-13-2018, 07:16 AM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Maybe the previous owner did the fog light mod to have them on with the parking lights and he spliced into the wrong wire.
2010 black mica speed3
Soon:built motor
 Old 02-13-2018, 07:31 AM   #3
mitch11wmm's Avatar
I wouldn't think so, it's never stayed on before. When I went out to my car at first I figured i had left them on but I didn't.
Sent from my VS995 using Tapatalk
 Old 02-13-2018, 09:58 AM   #4
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Just remove them all together. Get a good set of 55w HID's for your low beams, and you won't need any other lights to see.
Plus weight loss, because racecar.
 Old 02-13-2018, 10:01 AM   #5
mitch11wmm's Avatar
I like fog lights though :/
Plus I'm thinking the relay is stuck closed. I have the fuse pulled for now, so I'm good until I find the issue
 Old 02-13-2018, 06:03 PM   #6
JakeMS3's Avatar
Posts: 1,161   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 7 Times in 5 Posts
You did turn them off inside the interior right? I know you can turn them on and they will turn on and off with the auto headlights, but have you popped that knob back in so they’re off?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
 Old 02-13-2018, 06:09 PM   #7
mitch11wmm's Avatar
No they are 100% off
 Old 02-13-2018, 06:14 PM   #8
JakeMS3's Avatar
You could grab a flashlight and take a peek at the back of the fog lights and see what the wires are looking like. You can actually turn the wheels to the left, pull out the fender well portion on passenger side and peel it back a little which should give you enough room to look around. Repeat for drivers side turning wheel to the right. This is how I swapped out my fog lights.
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
 Old 02-13-2018, 07:52 PM   #9
mitch11wmm's Avatar
I see. Any idea where that relay is? Im thinking it's stuck closed
 Old 02-14-2018, 02:20 PM   #10
nekret's Avatar
Posts: 419   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
relay is on the passenger side and is clipped on to the body just under the headlight. easiest access is by removing the fender liner on the passenger side and looking up. you should be able to follow the fog light harness right to it.
http://www.mazda3tech.com/front_fog_...ation-756.html
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 02-16-2018, 07:17 PM   #11
mitch11wmm's Avatar
UPDATE: thanks to nekret I found the relay and replaced it, everything works fine as of now. If it messes up again I'll post another comment with the fix. As for the issue, the car was in an accident before I bought it and I guess the repair shop did not put the relay in it's correct place, instead it was just inside that area on the inside of the bumper, loose. I pulled it out and it leaked water. The contacts were all corroded to hell as well. I picked up the relay from AutoZone with part number "20928" and replaced the old one with this. I also replaced the fuse just for good measure. Finally, there were some prongs along the wires to the relay, I pushed these into the clips on the back of the coolant tank and then, just for good measure, ziptied the relay to the top clip so that it won't fall down and be exposed to water again.
Hopefully this helps someone. I got tired of seeing threads about an issue with no update so I figured I would break the cycle!!
nekret likes this.
The Following User Says Thank You to mitch11wmm For This Useful Post:
kTaLgsTo (02-16-2018)
 Old 02-16-2018, 07:22 PM   #12
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Good job, forums live and breathe on people following through
Tail lights/trunk lights options z28forlife Exterior 9 11-21-2018 12:31 PM
led interior lights and license plate lights cocoleveo7686 MazdaSpeed 3/6 - Appearance 1 11-25-2013 01:25 PM
wiring fog lights to the parking lights exftw MazdaSpeed 6 - How-To's 16 02-10-2013 10:23 PM
MS6 Painted Fog Lights and Tail lights rrussell50 MazdaSpeed 3/6 - Appearance 1 10-10-2012 05:55 PM
HIDs, Reverse lights, Liscence Plate lights Franconemo Exterior 31 06-12-2010 03:25 AM
Page generated in 0.31652 seconds with 25 queries
