-   -   Forge BPV fluttering (http://www.mazdaspeedforums.org/forum/f544/forge-boost-bypass-valve-fluttering-116899/)
Pintozoz 06-20-2012 06:21 PM
Wondering if someone can give me some input.
Got a forge v1 BPV. I'm getting nasty fluttering. Very long and loud.
I did some research and did the cleaning and regreasing. Checked all the hoses and make sure there was nothing lose.
I'm running the red spring. I tried no Shim, one shim and two shims. Issues persist.
I'm usin the stage 1 Surev2 map.
Dahouse702 06-20-2012 06:31 PM
I think you need the blue spring with 1 or 2 shims....
Pintozoz 06-20-2012 06:33 PM
Fuck I bought this one used. Only came with red shim.
Dahouse702 06-20-2012 06:35 PM
Goes red/blue/yellow.... You can order new springs
Pintozoz 06-20-2012 06:37 PM
Will look into that. Thanks.
Lex 06-20-2012 08:40 PM
Flutter means the spring is too stiff or the valve needs lubrication.
Toymachinespeed 06-20-2012 09:53 PM
And this would be considered bad flutter? Or compressor surge?
Lex 06-20-2012 10:41 PM
Flutter is compressor surge. If it's very mild it is fine but more severe surge can cause damage.
Raider 06-21-2012 05:37 AM
There is a how-to on cleaning/lubing, but inthemean time, call/email Forge. Make sure you also have the o-rings inside and onthe cap. The used one I bought used I found was missing 1 o-ring and another was split. Some lithium grease and new o-rings made it work great!
G26 06-21-2012 05:43 AM
You can purchase a spring set from forge
Forge Motorsport | Alloy Fabrication
You will want to run blue spring and use shims accordingly. I have run blue +2 shims since I've had the valve.
Uranium9v 06-21-2012 06:00 AM
make sure you didn't put the plunger in upside down. If the domed side is facing the wrong direction, it will flutter bad.
Hamilton69 06-21-2012 06:09 AM
http://i684.photobucket.com/albums/v...4ef7e56686.jpg
Page generated in 0.17918 seconds with 11 queries
