 Old 07-07-2019, 06:42 PM   #1
JMPS3's Avatar
Posts: 1   (View Stats)
JMPS3 is an unknown quantity at this point
Default FR wheel noise
Hi guys, new forum member here.
Recently I’ve had a noise come on within the past 2 weeks of a light creaking/popping noise coming from what i think is my front right wheel area. It mostly happens on full lock under load such as leaving a driveway in reverse or going up hill turning. It comes and goes.
I just went to my mechanic and he checked all the cv joints and said there are no leaks or cracks. Any suggestions on what else this could be and how I could diagnose?
JMPS3 is offline   Reply With Quote
 Old 07-08-2019, 09:46 AM   #2
Db09ms3's Avatar
Posts: 490   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 96
Sway bar bushing is likely. Check to see if your struts are leaking as well
Stockish
Possible wheel bearing noise? GODspeed7 CX-7 > Issues & Troubleshooting 15 08-16-2013 07:55 PM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 06:32 PM
Clunking noise from my passenger wheel Atomic41 MazdaSpeed 3/6 - Suspension & Brakes 14 02-07-2012 03:37 PM
hearing odd noise in wheel well spike589 MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-23-2010 09:25 PM
Wheel hop noise? Speedn3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-02-2008 03:34 PM
Page generated in 0.22572 seconds with 21 queries
