 Old 01-02-2012, 12:57 PM   #1
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
Default Front end groaning/warranty work
Took my car in today for warranty work. A few thousand miles ago my front end developed a groaning noise when turning left or right, at a slow speed, from a dead stop.
The groan vibrates the clutch pedal, gas pedal, and passenger floor board. noise is dependent on wheel speed (noise speeds up or slows down).
has anyone else developed this issue, if so, what was the result?
while I was in I tried to get them to fix the excessive toe in issue the gen2 has...no luck. But I had my drivers seat fixed from the notorious pop/squeak.
Thanks for any info.
cesaros is offline   Reply With Quote
 Old 01-02-2012, 01:04 PM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
Wheel bearing.
ScarMS3 is offline   Reply With Quote
The Following User Says Thank You to ScarMS3 For This Useful Post:
cesaros (01-02-2012)
 Old 01-02-2012, 01:06 PM   #3
cesaros's Avatar
Groans: 106
that was my suggestion to the tech. however 5 hours later and they're still stumped.
The Following User Says Thank You to cesaros For This Useful Post:
ScarMS3 (01-02-2012)
 Old 01-02-2012, 04:03 PM   #4
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Originally Posted by ScarMS3
Wheel bearing.
+1
2012 Black Mica MazdaSpeed3
Street creds:
 Old 01-03-2012, 03:12 PM   #5
cesaros's Avatar
Groans: 106
Dealership called me back and said the issue was "blah blah...friction modifier for the LSD"
I'm not sure exactly what the guy said because every other word was Uhh..Umm...
But I picked up on "friction modifier for the LSD".
It looks like the dealer slapped a bandaid on my car that will probably last long enough for my warranty to expire.
Oh, and it took TWO DAYS for them to do this.
 Old 01-03-2012, 03:14 PM   #6
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
wait...so it doesn't vibrate anymore?
 Old 01-03-2012, 03:21 PM   #7
cesaros's Avatar
Groans: 106
I dont know, they wont let me pick the car up until tomorrow.
The tech could never duplicate the noise and vibration when I took in the car origionally.
I went in and had to duplicate it for them. The service counter worker said they couldn't hear the noise when they added friction modifier..
but considering they could never duplicate it in the first place, im not too sure they actually cured it, or just cant duplicate it..again.
Sacrilicious (01-04-2012)
 Old 01-03-2012, 07:27 PM   #8
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Groans: 52
Groaned at 145 Times in 38 Posts
Hm,I'll stay away from that dealership, for the future
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
 Old 01-03-2012, 11:50 PM   #9
cesaros's Avatar
Groans: 106
ya, I went 26000 miles without ever needing a dealership (still on OE tires too..with tread)
But I figured i would use my warranty for something.
 Old 01-04-2012, 06:11 AM   #10
pewpew
hrrm...if the friction modifier actually did the trick, i'd be really worried about your trans/LSD. are you still on the stock fluid, or did you swap it out?
 Old 01-04-2012, 09:16 AM   #11
Instrument_Guy's Avatar
Posts: 167   (View Stats)
Instrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the worldInstrument_Guy is the leader of the world
FWIW, I get the groan noise when I am turning at slow speeds when the transmission is cold. Car has done it since new. Groan is a bit more noticeable with the Motorcraft transmission fluid..
Instrument_Guy is offline   Reply With Quote
 Old 01-04-2012, 11:09 AM   #12
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
What did they do to fix your squeaky seat?
deadlandxtreme (01-04-2012)
 Old 01-04-2012, 12:25 PM   #13
PureDrive's Avatar
Posts: 183   (View Stats)
PureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond reputePureDrive has a reputation beyond repute
Groaned at 25 Times in 11 Posts
I just started getting a groan once in a while when turing at low speed/from a dead stop. It has only happened about 5 times so far, but the car only has 3300 miles on it. I was going to check the lug nuts and wheel area for any signs of issues. I would hope it is not a wheel bearing already.
PureDrive is offline   Reply With Quote
 Old 01-04-2012, 06:06 PM   #14
Make no mistake, the LSD in this car is relatively noisy (to a car without an LSD). A bit of a moan along with a bit of stickiness to the steering wheel during the first turn of the day (or more if it is very cold outside) is normal operation of an LSD. The question for the OP is how much is normal versus how much indicates pending failure of the differential. Having this documented is very important. Friction modifiers may help. So has this differential been abused (extensive one wheel peels? Different diameter tires left versus right?) Non OE fluid or level too low? Do you tend to hear things more than other people? Just thinking out loud. Without hearing it it is hard to say if this is within tolerance or not. If it goes away when warmed up, the friction modifiers help, and you get it documented, then I wouldn't continue to worry about this 'issue'. My $.02
Street creds:
 Old 01-04-2012, 07:13 PM   #15
cshunter's Avatar
Posts: 1,312   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groans: 28
I Have heard that but more of a popping noise from mine quite a bit today. It was a pretty cold day today tho, but to note my car has only about 4700 miles.
cshunter is offline   Reply With Quote
 Old 01-04-2012, 07:20 PM   #16
cesaros's Avatar
Groans: 106
picked up the car, the friction modifier did stop the groan.
however, it takes a bit more effort to shift gears, that makes me a bit nervous...like I said in an above post, it seems like they only slapped a bandaid on the issue.
I did swap trans fluid about 10k miles ago to motorcraft synthetic. but I'm not hard on my car by any means.
my groan noise was constant, it never went away with temp changes, or after driving for a while. the sound was a definite mechanical rubbing sound that vibrated the floorboard and clutch pedal. it started several thousand miles ago and only seemed like a normal characteristic of the car. it became very loud and much worse within the past few months.
the dealer said the issue was the LSD slipping when turning...Im no expert about the transmission or differential in my car, so I just nodded my head and said "ok".
and my seat pop was cured by them replacing and adjusting a bolt in the rail; seemed to do the trick
 Old 01-04-2012, 07:59 PM   #17
If it was me I'd put oem trans fluid back in without the friction modifiers.
Street creds:
 Old 01-12-2012, 04:39 PM   #18
makjur's Avatar
Posts: 1,313   (View Stats)
Hrm, I get a popping kinda clunking noise but i'm pretty sure its from my suspension and not related to stearing/LSD.
It only happens when I go over a bump or a dip, feels like its only the drivers side, both front and back.
I have a 2010, has almost 7k miles on it now, planning to have it looked at via warranty, but I'm not sure if they will be able to replicate the problem.
Also, I have a very slight alignment problem, but I bought the car used so I'm not sure if they will want to do anything about it. There is no damage to the rims,but maybe the alignment and clunk is related, since it pulls to the drivers side...
As far as OP goes, try another dealership? 2nd opinion wouldn't hurt
°(ಠೆಒಠಿ)°
 Old 03-11-2012, 08:36 PM   #19
NW MS3 Guy's Avatar
Posts: 4   (View Stats)
NW MS3 Guy will become famous soon enough
Hi-
I am new to this forum but am having same problem at 4,500 miles. Dealer has so far replaced the inner drive shaft bearing and one of the motor mounts. Problem abated for a BRIEF time but is now back.
Hope this helps.
NW MS3 Guy
NW MS3 Guy is offline   Reply With Quote
 Old 03-12-2012, 05:49 PM   #20
Renn's Avatar
Posts: 97   (View Stats)
Renn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant future
I had a similar experience to the OP - had the groan with factory tranny fluid, but it got noticeably worse with the motorcraft fluid. I haven't noticed any shifting improvement from the motorcraft, so I'll be switching back to factory.
Renn is offline   Reply With Quote
 Old 03-27-2012, 03:52 AM   #21
makjur's Avatar
My rear clunking issue ended up being blown struts, milage not in the 10's yet... Replaced under warranty with no issues
They told me the 2010s come with shit struts and they replace them with another brand,
°(ಠೆಒಠಿ)°
 Old 03-27-2012, 05:09 AM   #22
AegisKlein's Avatar
Posts: 209   (View Stats)
AegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the world
Same here. Just noise for me. No huge vibrations
2011 MS3 Black Mica
Autotech Internals // Cobb AcessPORT (FREEKTUNEd) // CorkSport Racepipe; Springs; Camber Arms // Cp-e TMIC; SRI; TIP; RMM 75A // DDM 35W 6000K HIDs
Denso ITV22's // JBR SSP stage 2; Mud Flaps // Tenso-R Concept 9 rims // 35% Tint // OCC (Matt Damon) // Koni Yellow Sport
AegisKlein is offline   Reply With Quote
Going in for warranty work tomorrow... guitarzan134 MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-30-2011 04:13 PM
Tried to get some warranty work done today and got denied. Blindeye_03 Gen2 MS3 General Discussion 23 07-05-2011 09:09 AM
Warranty work diagnosis brownfaux 2010 MS3 - Troubleshoot/Diagnostics 10 05-24-2011 05:27 PM
warranty work Rich-PMS Mazdaspeed3/6 General Discussion 22 05-24-2011 10:07 AM
Dentless body work and warranty redd9444 Appearance - RED 4 11-12-2009 11:49 AM
Page generated in 0.45388 seconds with 32 queries
