Like Tree2Likes
 Old 09-27-2011, 08:53 AM   #41
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I know the beginning is a bit technical, but the meat of the document is Cobb's recommended upgrade path:
http://accessecu.com/support/docs/su...%20Support.pdf
Design (09-30-2011)
 Old 09-28-2011, 12:54 PM   #42
Jake5713's Avatar
Posts: 1,775   (View Stats)
Bump
Any other recommendations thinking TBE now
Jake5713 is offline   Reply With Quote
 Old 09-30-2011, 09:24 AM   #43
adrager622's Avatar
Posts: 745   (View Stats)
adrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the world
Groans: 46
I would get the HPFP (EA has a sale for AT internals going on right now) as well as a DP. That would free up the restricted stock DP and definitely net some good HP gains, especially allowing you to run a stage 2 map. I would definitely do that before getting coils or an upgraded IC. Plus, leaves some extra cash in your pocket if you have that much to play around with.
2010 MS3 Black Mica
-JBR RSB, JBR Boost Tubes and BPV hose, JBR 80a RMM, CP-e Nano SRI, 6000K HIDs
adrager622 is offline   Reply With Quote
 Old 09-30-2011, 10:05 AM   #44
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
He already has internals, at least according to his sig.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
 Old 09-30-2011, 11:29 AM   #45
Jake5713's Avatar
I have internals
I wanna do TBE what DP do you guys recommend?
 Old 09-30-2011, 11:34 AM   #46
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Originally Posted by Jake5713 View Post
I have internals
Depends on what you're willing to pay and what setup you want.
If you want to replace your DP+TP (long DP) look into:
CNT (cheapest) offered in catted and catless
Cobb catted
cp-e catted/catless
If you only want the upper portion look into
UR (catted in metal and ceramic choices, catless)
CS (catted/catless)
Cobb, cp-e and UR will not throw CEL codes, but you can always clear them with your AP anyway if you go with the other brands.
The Following User Says Thank You to adlpb For This Useful Post:
rfinkle2 (09-30-2011)
 Old 09-30-2011, 11:43 AM   #47
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Suspension. A car that handles well is more fun.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Nliiitend1 (09-30-2011), rfinkle2 (09-30-2011)
 Old 09-30-2011, 11:50 AM   #48
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
COBB or cp-e, less connection = less restriction = happier turbo
Grumpyjap is offline   Reply With Quote
 Old 09-30-2011, 12:00 PM   #49
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
This is not the Gen 1 we're talking about here. Aside from some inherent understeer, the Gen 2 tuning is nearly perfect out of the box. If anything, a rear sway bar or wider tires (IMO).
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following User Says Thank You to Design For This Useful Post:
 Old 09-30-2011, 07:06 PM   #50
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Anyone have evidence that a cpe or Cobb dp net more gains than a cnt for half the price, and does cx actually make a dp @adlpb
"Exclusivity" - CP-enis
Demodded.
The Seals
adlpb (09-30-2011)
 Old 09-30-2011, 07:41 PM   #51
adlpb's Avatar
Groans: 669
Thanks for that I mixed up the names. To many companies here start with the letter C. Lol. It should have been CNT, not CX
 Old 09-30-2011, 07:59 PM   #52
Jake5713's Avatar
is cnt's DP for the gen 2
Link?
thanks
looking at this point for a cheap one piece DP doesn't seem like name brand matters too much
don't want to spent 500 for a DP
 Old 09-30-2011, 08:12 PM   #53
adlpb's Avatar
Groans: 669
Link?
thanks
http://www.cntracing.com/category_s/36.htm
 Old 09-30-2011, 09:55 PM   #54
Jake5713's Avatar
Thanks
 Old 09-30-2011, 10:10 PM   #55
Jake5713's Avatar
So besides $$$$ is there really a difference between the cobb and CNT DP?
The Following User Says Thank You to Jake5713 For This Useful Post:
Tokay444 (10-01-2011)
 Old 10-01-2011, 01:29 AM   #56
adlpb's Avatar
Groans: 669
Installing the CNT DP is more complicated from what I've read because of how the upper part is designed. It will also throw a CEL code.
Other than that it should be similar performance wise. At least until you go BT. I know the Cobb DP is good with that, not sure if the CNT one is designed for 400+hp, maybe someone can input on that.
 Old 10-01-2011, 06:28 AM   #57
Tokay444's Avatar
Groans: 793
It won't throw a cell if it's catted.
3" dp is a 3" dp is a 3" dp....
Doesn't cobb's taper?
Demodded.
The Seals
Last edited by Tokay444; 10-01-2011 at 06:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-01-2011, 06:31 AM   #58
rfinkle2's Avatar
Groans: 298
I know I've read some people having to hack off the flange on the gen2 to mate it with certain exhausts. (CNT)
I'd say that my test pipe made the biggest gains exhaust wise on my car.
I see almost no difference with my catted dp, although I'm sure it isn't hurting performance.
 Old 10-01-2011, 07:51 AM   #59
adlpb's Avatar
Groans: 669
UR's catted DP used to throw a CEL. I've read some people here with CNT catted that say the same. The CEL is triggered because of where the 02 sensor location, to which the genpu is more sensitive.
Not like it matters anyway if you have an AP...just clear the code.
What coils should I get? I_Heart_Haters 2010 MS3 - Suspension & Brakes 4 06-20-2011 02:07 AM
What coils should I get? PapaSmurf 2010 MS3 - Suspension & Brakes 28 06-17-2011 08:53 AM
KW Variant 1 Coils vs. H&R Coils surfwagon MazdaSpeed 3/6 - Suspension & Brakes 11 04-10-2011 10:18 AM
drop on BC coils MS3Zoom24 MazdaSpeed 3/6 - Suspension & Brakes 10 02-03-2010 11:46 PM
Page generated in 0.38553 seconds with 28 queries
