Like Tree7Likes
 Old 04-24-2012, 02:17 PM   #41
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Originally Posted by MammaFreed3 View Post
same here, only I can't figure out how to get the nut tightened down because the bolt is so long and a standard socket won't fit over it. i also gotta find another nut, recovered 1 from the inside, the other is apparently just gone or still floating around in there. if someone knows a better way of accessing the bolts to put the nuts back on without taking half the damn car apart, I'm all ears.
That nut can be taken out if you get it with a magnet from the outside.
You have to place the magnet over the hole (outside hole with the wing off) and open and close the hatch slowly.
IMO, it will be hard to isolate / fix a rattle with nuts rolling around in the hatch.
Darth_Nuruodo (04-24-2012), DoMiNic (06-24-2013)
 Old 04-24-2012, 02:33 PM   #42
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Genius solutions as always.
rfinkle2 (04-24-2012)
 Old 04-24-2012, 07:13 PM   #43
MammaFreed3's Avatar
Posts: 164   (View Stats)
MammaFreed3 is infamous around these partsMammaFreed3 is infamous around these partsMammaFreed3 is infamous around these parts
Groaned at 37 Times in 10 Posts
Ahh hell with it, the car's got 16,XXX on it, under warranty, I'm just gonna march in there and say, "the damn spoiler's falling off, fix it," and that'll be all.
MammaFreed3 is offline   Reply With Quote
 Old 04-25-2012, 08:47 AM   #44
Groans: 88
Pretty much what I plan to do if mine gets any worse or it finally starts annoying me to the point of wanting to rip it off.
 Old 04-27-2012, 03:14 PM   #45
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Originally Posted by mtran View Post
There is no escaping rattles if you have any motor mounts installed in your car.
I have JBR's trilogy mounts in 88/88/80 durometer. Here is a list of things that rattle in my car.
1. gauge cluster
2. steering column cover
3. right side dash (bolts may have come loose)
4. glove box
5. arm rest
6. cup holder
7. shifter console
8. rear seat belt tensioners
9. rear spoiler
You can pretty much see, it's inevitable lol. I tried fixing all these rattles with felt tape/foam etc to no avail.
I was thinking about this the other day and I wonder if you checked the distance of your PMM and the inner wall since you installed it. I was double checking the bolt torque on my RMM and PMM a week after I installed them and I noticed the PMM was practically touching the inner wall on the right hand side. You are supposed to have at least a 3/16" of gap there. I think doing this, in addition to the TMM significantly lowered the felt vibrations, but not the noise.
I tried that, it didn't work. I had to take the inner panel off in order to gain access to the center of the hatch. I ended up using 2 cheap telescopic magnet dealies and bending them to breaking. Then I raised and lowered the hatch until one of them caught the offending nut. This was almost an hour process because there was barely any room to work.
Last edited by himurax13; 04-27-2012 at 03:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-27-2012, 06:44 PM   #46
analbumcover's Avatar
Posts: 152   (View Stats)
analbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant future
Originally Posted by zatara View Post
Try lightly lifting the overhead liner in the middle near your rearview mirror. Just stick your finger in there and see if that get's rid of the passenger side rattle you hear.
is there a permanent fix to this?
analbumcover is offline   Reply With Quote
 Old 04-27-2012, 07:30 PM   #47
zatara's Avatar
Posts: 1,505   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
I haven't tried to figure it out yet, but if I had to guess, either using rubber tape, or 3m tape to stick the two pieces together.
2010 Mazdaspeed 3 Black Mica
CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB
Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear
zatara is offline   Reply With Quote
 Old 04-27-2012, 09:21 PM   #48
Good idea.
I have some left over 3m outdoor industrial velcro i used for my HID ballasts. I'll try this tomorrow or sunday and report back.
 Old 04-27-2012, 10:08 PM   #49
mtran's Avatar
Posts: 195   (View Stats)
mtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond repute
Mine does have a gap there.. I read the instructions carefully the first time. It's torqued properly, so the mount hasn't moved at all.
You just learn to deal with the noises. Crank up your stereo louder!
2010 Black Mica MS3
mtran is offline   Reply With Quote
 Old 05-01-2012, 06:13 AM   #50
This trick works. I used 3m industrial outdoor velcro. When 2 pieces are velcro'd together it creates like a 5mm think double sided tape. Used that to wedge it between the head liner and the roof. It applies a little downward pressure on the front of the headliner and gets rid of the rattle.
The Following User Says Thank You to analbumcover For This Useful Post:
zatara (05-01-2012)
 Old 05-01-2012, 06:35 AM   #51
zatara's Avatar
Good to know, when I stop being lazy I'll get some of that velcro and do the same thing.
Now to get rid of the rattle coming from my gauge cluster.
 Old 05-01-2012, 06:39 AM   #52
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
the gauge cluster comes out easily and comes apart with very little difficulty. some velcro tape and some thin foam pipe insulation tape worked perfectly to silence that pandora's box of rattles.
The Following User Says Thank You to tddvrrn For This Useful Post:
zatara (05-01-2012)
 Old 05-01-2012, 06:51 AM   #53
zatara's Avatar
Good to know. I just need to stop being lazy and do this.
The Following User Says Thank You to zatara For This Useful Post:
tddvrrn (05-01-2012)
 Old 05-01-2012, 06:54 AM   #54
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Groaned at 18 Times in 4 Posts
Originally Posted by nextgenerationx1 View Post
I had a rattle clanking noise coming from the rear of my car hitting bumps n shit, I was like wtf, the sway bar but was loose they sold me my car partly assembled lmao
I'm gonna have to check and see if that's what's making the clunk on my car...only when I hit bumps going around corners and shit. I figured it was my 3" UR CBE clunking off of something in the rear end. Seems it's about when I put it on that the clunk started happening.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
 Old 05-01-2012, 11:31 AM   #55
himurax13's Avatar
Groans: 255
Is there a how to thread for this?
 Old 05-01-2012, 06:25 PM   #56
tddvrrn's Avatar
Groans: 103
it is, oddly enough, in the how-to section...
attack-instrument-panel-noise
himurax13 (05-01-2012)
 Old 01-05-2013, 06:12 PM   #57
makjur's Avatar
Posts: 1,313   (View Stats)
the squeaking when you get in and out of the car, might be e-brake giving slightly from movement of the car
thatsmrgimp2u likes this.
°(ಠೆಒಠಿ)°
 Old 01-05-2013, 06:19 PM   #58
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
Groans: 28
turn on radio.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 01-06-2013, 01:23 AM   #59
Twofer's Avatar
Posts: 191   (View Stats)
Twofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the worldTwofer is the leader of the world
Groaned at 5 Times in 1 Post
Since I got the JBR 80d Trilogy, I can't hear anything except the transmission, the synchros, the throwout bearing, the intermediate shaft, the individual cylinders firing...
Shit is awesome.
2012 Mazdaspeed 3 Crystal White Pearl (Sold!)
2006 Mazda MX-5 Track Car
2010 Mazda 3 Happy Car
Youtube channel with trackday videos with engine data: http://www.youtube.com/user/turbohappycar
How To Use Google Docs to View Datalogs: http://www.youtube.com/watch?v=so-4VIKM51U
Open Beta: PHP Datalog Reader v105 http://www.mazdaspeedforums.org/forum/f9/need-beta-testers-php-138814/
Twofer is offline   Reply With Quote
The Following User Says Thank You to Twofer For This Useful Post:
 Old 01-06-2013, 01:57 AM   #60
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Yeah I'm pretty sure my mounts cause me to hear colors..... Especially in the winter.
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 01-06-2013, 02:15 AM   #61
tinboi479's Avatar
Posts: 267   (View Stats)
tinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the worldtinboi479 is the leader of the world
Shit rattles. Just deal with it. I have too many rattles I don't even know where to start lol
tinboi479 is offline   Reply With Quote
 Old 01-07-2013, 05:51 AM   #62
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
I get stereo surround rattles.
Glovebox. Both front windows. Something up by the dash. Rear left area. Exhaust. Basically everything.
 Old 01-07-2013, 07:14 AM   #63
PushingRedline's Avatar
Posts: 146   (View Stats)
PushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond reputePushingRedline has a reputation beyond repute
Originally Posted by infeKteDx View Post
It was loud, and it made the sound everytime I drove. I made them do a ride along, and when it started I said..."Tell me you DON'T hear that?" Had a tech in the back messing with the locking mechanism, he was almost certain he fixed it like THREE times, only for me to drive back after a test drive and tell them it still did it. You can't stop it by pushing on the mechanism. So I went in, and said "So what, am I shit out of luck then?" and the guy at the counter said something along the lines of "nope, we're gonna order you a new locking mechanism, under warranty." ....I was REALLY happy considering the noise made me almost sell the car.
I have been trying to figure out where my rattle is coming from in the hatch area and that just might be it. Guess I should take it to the dealer then.
PushingRedline
2012 Mazdaspeed 3 - Red w/ Tech
-Cobb AP/S-OTS Stage 2
-AT Internals
-JBR 80 Duro RMM
-JBR Stage 3 CAI System
-CorkSport SSP
-JBR Solid Shifter Bushings
-Ebay Catless Downpipe
-NGK Iridium IX 1-step Colder Spark Plugs
-Forge V2 BPv
PushingRedline is offline   Reply With Quote
 Old 01-08-2013, 04:29 PM   #64
Limeybastard's Avatar
Posts: 578   (View Stats)
I think I got a rattle on my13. Sounds like stones or marbles ( small ones ) under the floor board jiggling around at speeds above 50. Or it might be coming from the gauge area.
2013 W/tech
 Old 01-09-2013, 10:59 PM   #65
klafaille's Avatar
Posts: 68   (View Stats)
klafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond reputeklafaille has a reputation beyond repute
Passenger seat back rattles in mine. Drove me nuts until I figured it out.
klafaille is offline   Reply With Quote
 Old 01-14-2013, 08:45 PM   #66
galens47's Avatar
Posts: 1,616   (View Stats)
galens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the world
Groans: 24
Mount trio rattles much more pronounced. Oh well fuck. I like not having wheel hop.
G
Sent from my sortasmart HTC
2008 Toyota Prius Grand Touring. Slow, no mods. Saving $600/month - Fuck off you judgmental Assholes. I miss the fuck out of my speed3 way more than the mustang. Alas I'm waiting for the next one.
2014 Mustang GT Premium, Deep Impact Blue. Boss 302 Steering wheel (Alcantara), SR Shift bracket, Roush Axelback -sold
2010 ms3 Black Mica Tech Package -sold
Internals are easy. Who the fuck thought it would be a good idea to point the genjuan's valve cover recirc tube at the EGR?
“It is the mark of an educated mind to be able to entertain a thought without accepting it.” --Aristotle
galens47 is offline   Reply With Quote
 Old 01-14-2013, 09:36 PM   #67
tddvrrn's Avatar
Groans: 103
i had a mega annoying rattle from the passenger seat. i unbolted it, tilted it back and checked for tightness. everything was ok.. hmmm, odd.
a week later i found a chopstick inside the seatback cover that i had randomly unzipped. it had been rattling against the seat frame. uh... i guess my car was made in japan...
 Old 06-24-2013, 09:48 AM   #68
de_wiz's Avatar
Posts: 1   (View Stats)
de_wiz is an unknown quantity at this point
Speaking of rattles, I was wondering if anyone has had a problem with their driver side window, constantly rattling when it is in any other position but up?
I took my car to my local Mazda dealership 4 times for this problem now, and they messed around with the control arm, and some other things, but never ended up fixing the window. They told me that this is normal operation for the window, and that I just have to deal with it. The service manager informed me to just spray silicone spray on all moving parts until the problem corrects itself, but they themselves would not do this. Any suggestions?
de_wiz is offline   Reply With Quote
 Old 06-24-2013, 10:52 AM   #69
Kawiralph's Avatar
Posts: 17   (View Stats)
Kawiralph is just really niceKawiralph is just really niceKawiralph is just really niceKawiralph is just really niceKawiralph is just really nice
Other than that my genpu shows the same behaviour and the stealer has no solution, no...
Gesendet von meinem GT-N8010 mit Tapatalk 2
Kawiralph is offline   Reply With Quote
 Old 06-25-2013, 06:33 PM   #70
nayilsi's Avatar
Posts: 52   (View Stats)
nayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to all
I had rattles coming from the dome lighting area. Got it fixed under warranty.
nayilsi is offline   Reply With Quote
 Old 01-05-2014, 04:02 PM   #71
zedekias's Avatar
Posts: 197   (View Stats)
zedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond reputezedekias has a reputation beyond repute
Groaned at 5 Times in 2 Posts
Can someone clarify how they fixed their latch/locking mechanism rattle?
Mine is insanely loud. I've tried moving the latch back and forward.
What did you do with the silicone adhesive or open cell foam??
I refuse going to dealer. I don't have time for that.
2011 Silver MS3
CS SRI and TIP // Cobb AP // Autotech internals // Cobb downpipe // CP-e TMIC // Cobb BPV // Resonator delete // JBR RMM // JBR RSB // NGK spark plugs // e85
Stratified Tuned
zedekias is offline   Reply With Quote
 Old 01-05-2014, 04:08 PM   #72
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Originally Posted by babypetit View Post
do you have a picture of where you applied the silicone adhesive? I already adjusted the latch, but it still rattles. need to try this to see if it works. Thank you!
check your rear wing bolts
*edit OLD ass post
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 01-05-2014, 04:22 PM   #73
zedekias's Avatar
For the record I've done the spoiler fix. Added butyl rope and tightened all bolts.
I had my gf sit in the hatch yesterday while I drove and it's definitely coming from the latch area.
2011 Silver MS3
Stratified Tuned
 Old 01-06-2014, 06:32 AM   #74
Yousuf's Avatar
Posts: 1,398   (View Stats)
Yousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the worldYousuf is the leader of the world
Groans: 128
My sunglasses holder rattles sometimes and it stops completely when I just support it with my hand, also I've been hearing something slight from the seatbelt near where you adjust them from, mainly the drivers side. I just ignore it
Mod-bug's back...
Yousuf is offline   Reply With Quote
 Old 01-06-2014, 08:22 AM   #75
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
I have a 2013 with 1500 miles and it rattles like a 89 Honda. Annoying as fuck and makes the car feel cheap.
Anybody else repeatedly bash the spot u think is rattling and hope it goes away?
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
The Following 3 Users Say Thank You to 2011speed For This Useful Post:
DingoDave (01-06-2014), makjur (01-08-2014), mxlplx71 (01-06-2014)
 Old 01-06-2014, 08:24 AM   #76
Yousuf's Avatar
Groans: 128
If anything don't you think repeatedly bashing the trouble spots would make the problem worse
Mod-bug's back...
 Old 01-06-2014, 10:19 AM   #77
oOfactoryOo's Avatar
Posts: 107   (View Stats)
oOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond repute
Groaned at 6 Times in 1 Post
So far no rattles on my 13. Right around 12000 km. JBR 88RMM going on today though, things might get loud lol
Sent from wherever I happen to be.
2013 CWP MS3 with Tech package
Cobb V3 // JBR 88RMM // Corksport SRI with TIP // Autotech Internals // UR Test Pipe
oOfactoryOo is offline   Reply With Quote
 Old 01-06-2014, 10:42 AM   #78
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
I don't know if bashing the "trouble" area is gonna fix it...check your sunglasses holder and latch area. Also make sure your glove box is completely shut...I had some papers stuck in it which caused it not to latch properly and it rattled bad.
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
 Old 01-06-2014, 10:45 AM   #79
2011speed's Avatar
I have a distinct noise coming from the driver side corner vent by the windshield. Bashing it made it slightly quieter but still incredibly annoying. And then I believe my passenger seat makes some sort of noise.
FreeKtuned
fitty fitty
 Old 01-06-2014, 11:59 AM   #80
wife her.
also, holy batman old thread. dig up.
how did you fixed that rattle?
Rattle from maplight mustanglt 2010 MS3 - Troubleshoot/Diagnostics 13 09-29-2011 03:32 PM
Rattle expoz3d MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-16-2011 10:50 AM
New Rattle brandonms3 Mazdaspeed3/6 General Discussion 7 12-05-2010 02:08 AM
Rattle on Start seanmiller09 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 06-23-2010 03:24 AM
HKS exhaust rattle himynameisevan MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-05-2010 09:59 PM
Page generated in 0.57190 seconds with 48 queries
