![]() | | #81 | ![]() |
![]() Join Date: Aug 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Inside the wheels like.. behind the spokes. I have no smarts. |
![]() | | #82 | ![]() |
![]() Join Date: Aug 2011 Location: Littleton, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score So I did fix my hatch/latch rattle by wrapping the U shaped metal piece the hatch latches to with electrical tape. So relieving. It sounds like driving a Lexus comparatively now.
__________________ 2011 Silver MS3 CS SRI and TIP // Cobb AP // Autotech internals // Cobb downpipe // CP-e TMIC // Cobb BPV // Resonator delete // JBR RMM // JBR RSB // NGK spark plugs // e85 Stratified Tuned |
![]() | | #83 | ![]() |
![]() Join Date: Jul 2013 Location: Brossard
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
Groaned at 6 Times in 1 Post
I get the same thing. I had to pull over on the highway the other day it was so bad. Can't wait for winter to be over! Sent from wherever I happen to be.
__________________ 2013 CWP MS3 with Tech package Cobb V3 // JBR 88RMM // Corksport SRI with TIP // Autotech Internals // UR Test Pipe | |
![]() | | #84 | ![]() |
![]() Join Date: Oct 2013 Location: Houston,Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Back hatch creaks and groans like crazy when temps drop below 50* Had the tech re-tighten the spoiler wing nuts last week when I changed the oil @ 2300 miles...made no difference... I'm happy that it doesn't stay cool here in Houston for very long.. Forgot to mention the slightly muffed rattle in the middle of the dash behind the info screen close to the windshield.. My 2003 Protege5 had less rattles when I bought it new...
__________________ _______________________ 2013 Black mica w/ tech 2003 Suzuki SV-1000-N Stock and proud..for now.. Last edited by Dark1; 01-08-2014 at 05:53 PM. Reason: forgot stuff |
![]() | | #85 | ![]() |
![]() Join Date: Dec 2011 Location: Warwick, RI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,517
| Not Ranked : 0 score When it started to get colder recently, November or so, I was given a rattle in my 2010... sounds like its coming from the nav screen are, can't find anything loose, hitting it doesn't help... sometimes it goes away for a day, or a few minutes, I'm learning to ignore it Also noticed that there is a high pitch almost whine from the belts when I start it up in sub 35* weather tapatalc
__________________ 2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals ♡°☆(ಠೆಒಠಿ)☆°♡ |
![]() | | #86 | ![]() |
![]() Join Date: Dec 2011 Location: Fullerton
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score So this is the only way known of fixing that latch? there's not a bolt or something that can be tightened? I just got this rattle a week ago after reading this thread for a different rattle =D |
![]() | | #87 | ![]() |
It only helped my rattle marginally, but the tape fixed it completely. It's not noticeable so I don't really care that it's a little ghetto haha.
__________________ 2011 Silver MS3 CS SRI and TIP // Cobb AP // Autotech internals // Cobb downpipe // CP-e TMIC // Cobb BPV // Resonator delete // JBR RMM // JBR RSB // NGK spark plugs // e85 Stratified Tuned | |
![]() | | #88 | ![]() |
![]() Join Date: Jun 2013
| Not Ranked : 0 score So guys, what to do about seatbelt tensioners? Dealer says they won't replace because it's not technically a malfunction and my mileage is already fairly high (warranty-wise). What's the guarantee the new part won't develop the noise if I replace at my own cost? How did you resolve it? Mine does the same thing. I just recline the back a little more and it stops. Last edited by MS3Shadow; 10-02-2015 at 01:12 PM. |
![]() | | #89 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
Groaned at 32 Times in 17 Posts
| Not Ranked : 0 score Sounds like a lot of you guys need a case of the movsies. Move to warmer climate.
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | WAMBUSHHHH! (10-02-2015) |
![]() | | #90 | ![]() |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
At the end of the day, rattles are going to happen, especially if you're running any kind of upgraded mount. All part of the game. I can't hear much rattle these days between my music and mount vibes. Just part of ownership at this point. So long as I don't say hello to one of my rods, I'll take all the rattles.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 | |
![]() | | #91 | ![]() |
![]() Join Date: Feb 2014 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Dear GOD, thank you to whoever first mentioned the latch rattle. I tightened it up a bit and wrapped some electrical tape around the "U" shaped latch. Rattle is almost entirely gone. Has been driving me nuts for close to 2 months.
__________________ 2013 Mazdaspeed3: CPE Stage 2 RMM, AP, JBR SRI, HTP TIP, Konig Oversteer - 18x8 +35. 2010 Honda Fit Sport: Stock. 1994 Dodge Viper RT/10: Drop in filters with straight tubes, Lemke 3pc hardtop. 1981 Corvette: Slowly became a restomod. |
| Rattle from maplight | mustanglt | 2010 MS3 - Troubleshoot/Diagnostics | 13 | 09-29-2011 03:32 PM |
| Rattle | expoz3d | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 07-16-2011 10:50 AM |
| New Rattle | brandonms3 | Mazdaspeed3/6 General Discussion | 7 | 12-05-2010 02:08 AM |
| Rattle on Start | seanmiller09 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 06-23-2010 03:24 AM |
| HKS exhaust rattle | himynameisevan | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 04-05-2010 09:59 PM |
