  • 1 Post By Brendanb
 Old 04-20-2017, 10:31 PM   #1
Brendanb's Avatar
Posts: 203   (View Stats)
Brendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud of
Groaned at 37 Times in 7 Posts
Default Fuel hose
I've been trying to locate the part# for this OEM hose (see pic below) for a gen2 MS3. I tried to order part# L3K9-13-49XC through tasca parts, and they emailed me telling me this wasn't the correct part # for my vin. I ordered the part they suggested, L3k9-13-49YB, but this is the wrong hose. I think L3K9-13-49XC (pictured on the right) is the correct part number. Could anyone please verify this for me? thank you
File Type: png Screen Shot 2017-04-20 at 10.25.02 PM.png (116.9 KB, 28 views)
Brendanb is offline   Reply With Quote
 Old 04-21-2017, 12:18 AM   #2
manu's Avatar
Posts: 76   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Is this..what you need?
Sent from my SM-G900P using Tapatalk
manu is offline   Reply With Quote
 Old 04-21-2017, 12:46 AM   #3
Brendanb's Avatar
Nope, see the pic attached. I need the soft plastic hose that connects to the top back of the fuel pump and goes to hard steel line near the firewall.
 Old 04-21-2017, 04:13 AM   #4
g00s3y's Avatar
Posts: 2,096   (View Stats)
Groans: 418
"Blue clip" hose or "yellow clip" hose? I think you might be talking about the one with blue clips.
I've got an extra OEM yellow clip hose if you need one.
The Following User Says Thank You to g00s3y For This Useful Post:
Brendanb (04-21-2017)
 Old 04-21-2017, 05:24 AM   #5
Brendanb's Avatar
Yeah, i need the blue clip hose. Thanks though. I'm still trying to figure out the part# for it
slowcum likes this.
 Old 04-21-2017, 11:04 AM   #6
Varomnia's Avatar
Posts: 387   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
Check mazdaspeed blue clip low pressure fuel line in ebay. From my searches the part number doesn't help much purchasing from 3rd parties, and buying from dealer is $80+. You can snatch one from Ebay from $15-30 or purchase from one of the guys shelling out for even cheaper. If you need just the clip, I got you covered, as I have a few spares, but if you need the actual line as well, ebay is your friend, unfortunately.
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
The Following User Says Thank You to Varomnia For This Useful Post:
 Old 04-21-2017, 06:58 PM   #7
Brendanb's Avatar
I just ordered on ebay searching as you said "mazdaspeed blue clip low pressure fuel line." there was only one left. thanks for your help!
Hose barb cap and factory oil cooler hose dia 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-07-2010 11:19 AM
Page generated in 0.27575 seconds with 24 queries
