 Old 11-24-2011, 07:06 PM   #1
bschuske's Avatar
Posts: 17   (View Stats)
bschuske will become famous soon enoughbschuske will become famous soon enough
Default Fuel Leak
Hello all - I have a Q for you guys. I had a fuel leak recently in the main supply line and I am curious if it is possible that Cp-e's hpfp could have caused that or is it just a fluke? I only ask because a friend of mine does work with a variety of pumps and he says that it is possible that the pump could cause this, however, if it can I canít find any instance of this happening to anyone else. I am going to send the pump back to Cp-e for inspection but I would like your thoughts on the matter.
Thanks guys
Bryce
bschuske is offline   Reply With Quote
 Old 11-24-2011, 07:16 PM   #2
JustanotherMS3's Avatar
Posts: 268   (View Stats)
JustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the world
Groaned at 45 Times in 11 Posts
did you tighten the main fuel line up nice and tight, i read loads about upgrading fp and guys having that line leak due to not tightening
Currently own:
2012 Sunburst Orange Civic SI Coupe W/Tech package
Basically stock with an Injen SRI (much thanks to madspd6)
wheels will be here in a week or so: 18x9 +25 Fast Hayaku powder coated White (basically TE37 knockoffs)
Previous car... 2011 Velocity Red MS3 W/Tech
-Engine/Power Mods:
FREEK TUNE IN PROGRESS/UR CBE/UR Race Pipe/Injen SRI/COBB AP/AutoTech HPFP Internals/Stage 2 Driver Mod/Turbo Smart Duel Port/JBR SSP/JBR SSB/Razo Weighted Shift Knob/
-Wheels and suspension:
Lowered on H&R Springs
18x8.5 +30 offset XXR 522 in Gold.
JustanotherMS3 is offline   Reply With Quote
 Old 11-24-2011, 07:19 PM   #3
bschuske's Avatar
It was tight, the issue was that there was a tiny whole in the line, at least that was according to Mazda. I had the pump on the car since last December and last Friday I suddenly had the leak.
 Old 11-24-2011, 07:22 PM   #4
thats pretty weird, i can't imagine it was rubbing on anything to cause it to wear through, the mazda tech did'nt have any conclusion to the hole?
Currently own:
-Engine/Power Mods:
 Old 11-24-2011, 07:23 PM   #5
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
did they warranty it?
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 11-24-2011, 07:29 PM   #6
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Well the hole didn't just appear. That line doesn't rub against anything.
 Old 11-24-2011, 07:33 PM   #7
bschuske's Avatar
The tech didnít have a clear reason why, just that there was a tiny leak.
Yes, they did cover it under warranty they replaced all the fuel lines and the pump. Before I took it in, I re-flashed the car to stock and reinstalled the stock pump. After that that all I had was intake, DP and TP, and a blow off. Initially they were trying to tell me that because of those mods it might not be covered but dealerships canít decide not honor the warranty just because of mods. There is an act called the MagnusonĖMoss Warranty Act of 1975 and among other things it says that the dealership must prove that the modifications lead to the fault. I didnít have to pull that card but I was prepared to. That act also says that warranties cannot be voided just because of mods (obviously not all mods are created equal but thatís the general idea of the act).
 Old 11-24-2011, 07:38 PM   #8
bschuske's Avatar
Your right nothing rubs on it but that’s what my Q is about. Is it possible that I just happened to have a bad line to begin with? Or maybe I somehow damaged the line when I installed the pump but I can’t see how, I only ever touched that line with my hand and an open ended wrench. Or could it be that the hpfp caused excessive back pressure in the line? I don’t know.
 Old 11-24-2011, 07:44 PM   #9
i know it dosen't rub on anything, i just think it's odd that the pump has been on since dec and only NOW is it deciding to leak.
Currently own:
-Engine/Power Mods:
 Old 11-24-2011, 08:25 PM   #10
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Arrow Honestly...
...you can't say the cp-e pump "caused the leak"... Also, it has been fixed under warranty so there should no longer be an issue.
You have a DP on the car, right?. You should probably re-install the cp-e pump, re-flash & motor on.
 Old 11-25-2011, 02:00 AM   #11
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
Groaned at 62 Times in 28 Posts
You said they replaced the pump...
So does that mean the dealership put a stock HPFP in place of your CPE pump?
Rich-PMS is offline   Reply With Quote
 Old 11-25-2011, 02:41 AM   #12
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
The Following 2 Users Say Thank You to adlpb For This Useful Post:
kmac (12-01-2011), Rich-PMS (11-25-2011)
 Old 11-25-2011, 04:13 AM   #13
Rich-PMS's Avatar
Groans: 68
I overlooked where he wrote stock pump. Thank you
 Old 11-30-2011, 09:17 PM   #14
bschuske's Avatar
lol, you convinced me I did just what you said. I don’t actually think it was the pump. Before I reinstalled the stocker I hooked up my AP and fuel PSI held strong so...in the end I think it was just a bad line.
The Following User Says Thank You to bschuske For This Useful Post:
 Old 12-01-2011, 03:36 AM   #15
kmac's Avatar
Posts: 1,792   (View Stats)
It's a defective line.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
2011-12 Audi R8 Spyder recalled for fuel leak Haltech Automotive News 0 08-11-2011 04:00 PM
Lexus fuel leak took almost 2 years from diagnosis to recall, Toyota says Haltech Automotive News 0 01-27-2011 08:40 AM
Fuel Leak? azokaei MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 12-13-2010 04:09 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.34161 seconds with 26 queries
