 Old 07-20-2018, 12:07 PM   #1
BMC
BMC's Avatar
Posts: 170   (View Stats)
BMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond reputeBMC has a reputation beyond repute
Default Fuel pressure problems
I've got a 2013 speed3 that began showing intermittent fuel pressure drop to in-tank-pump pressure (approx 75). This was early last year. I went through the narrowing-it-down process to find the problem (spill valve, fuel pressure relief valve, O-rings, loose connections etc.) It looked like it was the relief valve so I replaced it. Wrong. I tended not to think it was the Autotech internals as they so rarely fail. I then purchased a new pump and installed the Autotech internals in it. Still had the problem. I then sent the internals back to Autotech for inspection. They said they were off spec a bit and sent a new set. I installed them and had trouble free motoring since May of 2017. That's about 10,000 miles ago. Now I've got the same symptoms. Before starting the same bullshit process all over again, I was wondering if anyone else has had issues like this or any thoughts on it. Thanks in advance.
Black 2013 w/tech - initial installs - all COBB; FMIC, Accessport V3, SF Cold Airbox, Short Ram Intake, Turbo Inlet Hose, 3" SS Downpipe, 3" SS Cat-back Exhaust, Rear Motor Mount, XLE BPV, Polyurethane Exhaust Hangers. Autotech Fuel Pump Internals, Greddy catch can, Freektune,
Most recent installs/swaps; BNR S4 , HTP 3" intake kit, , TIG intake to head, CPE EGR delete, Swift lowering springs, rear camber arms, CPE 75 duro driver and passenger mounts, ProMeth Tank, Aquamist HFS-4 V-3 w/m injection kit (to combat our absolutely garbage, 91 octane), (.8 & 1.0 jets), vent gauge pod, Nitto NT05s
BMC is offline   Reply With Quote
 Old 08-05-2018, 01:00 PM   #2
BMC
BMC's Avatar
Not much interest in this thread but to finish it off, it turned out to be the in-tank-fuel-pump. After revisiting the usual suspects (spill valve, relief valve, HPFP etc.), I dropped the fuel tank and replaced the entire pump unit. For whatever reason it's cheaper to buy the complete assembly than the pump by itself. Big job (see earlier thread re disconnecting green quick release connector at the tank), problem fixed.
Low fuel pressure brandonnicholson MazdaSpeed 3/6 - Troubleshoot/Diagnostics 51 09-06-2018 05:49 PM
Fuel Pressure Problems at Idle CJones1225 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 06-03-2018 09:49 AM
FUEL PRESSURE HELP riflex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 5 02-14-2018 01:00 PM
Fuel Pressure Qual1ty MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 48 10-13-2013 11:28 AM
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-03-2012 12:12 AM
Page generated in 0.24358 seconds with 20 queries
