Like Tree5Likes
 Old 01-30-2012, 12:42 AM   #1
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
Default is fuel pump upgrade necessary for light bolt on?
just want to know that if an fuel pump internal is essential for gen 2 with light bolt on. Just SURE SRI and Corksport exhaust. I've read most of the threads abt fuel pumps and it looks like i'll definitely need one in the future but currently I only have budget for an intake and exhaust. Will the gen 2 run fine with SRI and aftermarket cat back exhaust only?? thanks for the replies!
dhsieh911018 is offline   Reply With Quote
The Following 10 Users Say NO Thank You to dhsieh911018 For This Un-useful Post:
adrager622 (01-30-2012), ASHMS3 (01-30-2012), BobbleHead (01-31-2012), faeker (02-01-2012), i8urgti (01-30-2012), J-Liss (01-30-2012), manelscout4life (01-30-2012), rghispanic88 (01-30-2012), SWAY (01-30-2012), thatsmrgimp2u (01-30-2012)
 Old 01-30-2012, 12:44 AM   #2
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
spend the money on an AP or you will never know
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
The Following 2 Users Say Thank You to BobbleHead For This Useful Post:
Bucker (01-30-2012), SWAY (01-30-2012)
 Old 01-30-2012, 12:44 AM   #3
bayarea_pat's Avatar
Posts: 120   (View Stats)
bayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond repute
---2008.5 MGM Mazdaspeed 3--- SURE Aeros & Sidewinder - OBX Test Pipe - JBR SSP, RSB, 88A RMM - Turbosmart BPV - ETS TMIC Autotech FP Internals - ~~Getting Dizzy~~
bayarea_pat is offline   Reply With Quote
 Old 01-30-2012, 12:50 AM   #4
that's actually the part of the question, with an AP im sure i will need an upgrade on the pump, but how abt without?
The Following 2 Users Say NO Thank You to dhsieh911018 For This Un-useful Post:
manelscout4life (01-30-2012), SWAY (01-30-2012)
 Old 01-30-2012, 01:04 AM   #5
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
well unless you can monitor your FP your not going to know. so you need something to monitor it, being the AP.
Seaton is offline   Reply With Quote
The Following 5 Users Say Thank You to Seaton For This Useful Post:
Ingle (01-30-2012), ScarMS3 (01-30-2012), Stealth01 (01-30-2012), SWAY (01-30-2012), vrspeed10 (01-30-2012)
 Old 01-30-2012, 01:08 AM   #6
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
uh no.. you can use stock map with cobb AP, then monitor your fuel pump.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
The Following 3 Users Say Thank You to xtasy For This Useful Post:
Ingle (01-30-2012), SWAY (01-30-2012), vrspeed10 (01-30-2012)
 Old 01-30-2012, 01:09 AM   #7
oh i c, for that purpose maybe the ultraguage is a more economical solution? is there anybody with an experience with just SRI and exhaust installed? instead of just having me just try it and see what happens.
i8urgti (01-30-2012), manelscout4life (01-30-2012)
 Old 01-30-2012, 01:12 AM   #8
BobbleHead's Avatar
Groans: 186
if you're going to mod, you'll need the AP anyway. If I knew what I'm learning now, it would've been my first mod.
The Following 3 Users Say Thank You to BobbleHead For This Useful Post:
 Old 01-30-2012, 01:32 AM   #9
dantes5823's Avatar
Posts: 6,576   (View Stats)
I'm thinking it'll be fine. I had an ultra gauge. Yea it's cheap and it monitors. But it has a lag. It's a live feed but delayed. So while your wot and it's showing your 1700 whatever. If you dip for a split second it might miss it. And you can't log. And going wot looking at the screen is a little fail. Ap won't force internals I think. Stage 0 map and have at it.
 Old 01-30-2012, 01:50 AM   #10
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Have you not searched these questions have been answered many times, now we can add this with the other 500 threads asking same fucking question.
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
The Following 3 Users Say Thank You to SWAY For This Useful Post:
ASHMS3 (01-30-2012), BobbleHead (01-30-2012), fortressofcomfort (01-30-2012)
 Old 01-30-2012, 02:34 AM   #11
Speedin's Avatar
Posts: 58   (View Stats)
Speedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond reputeSpeedin has a reputation beyond repute
I had just a corksport sri and cbe and my fuel pump looked ok but it was border line... do yourself a favor and get the ap and internals first! You wont be sorry!
2011 speed3- cs cbe, cs race pipe, autotech fp internals, cs catless down pipe, rx8 oem wheels, rallyarmor flaps, nextmod mz style lip kit, cobb ap, jbr dogbone rmm, jbr shift knob
Speedin is offline   Reply With Quote
The Following User Says Thank You to Speedin For This Useful Post:
 Old 01-30-2012, 03:13 AM   #12
Seaton's Avatar
Not if you end up with an AP down the line anyway, and trust me, you will.
For us over here in Australia, its only in Alpha testing now as we speak, It wasnt available to us when my car was Ecutek tuned over a year ago. Oh i wish it was, my Ecutek tune cost $1500,(that is cheap for a full pro tune here) then around $500 if i change any mods like to a FMIC down the line for retune, where the AP is a fraction of that cost with great support and many more features. Plus it will datalog everything you need. do it right the first time. Worst case you dont want the AP, you wont lose much on the sale of it anyway.
 Old 01-30-2012, 04:34 AM   #13
evilgrin's Avatar
Posts: 77   (View Stats)
evilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant future
U guys are way too fukn soft on noobs! I have'nt asked a single question (especially an ignorant one) I've just read and researched and I pretty much know what I need to know to do what I need to do to my car. Not saying I could'nt possibly need a little "micro-tuning" help down the road, but I have a firm grasp on the fudamentals. I'm gonna donate as well, so don't call me a fukn brownie either! Sorry for the rant, I just think some guys should'nt even be trying to mod their cars without some serious remedial 101 fundamentals type shits. I'm done.
evilgrin is offline   Reply With Quote
The Following User Says Thank You to evilgrin For This Useful Post:
 Old 01-30-2012, 04:44 AM   #14
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Groaned at 64 Times in 21 Posts
Shut it brownie fag!
2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In
2014 Ford F150 FX4 Ecoboost - Current
Dmurray06 is offline   Reply With Quote
The Following 5 Users Say Thank You to Dmurray06 For This Useful Post:
BobbleHead (01-31-2012), letzleta (01-30-2012), Sid3wayS (01-30-2012), vrspeed10 (01-30-2012), zkrick (01-30-2012)
The Following 3 Users Say NO Thank You to Dmurray06 For This Un-useful Post:
BMON3YZOOMIN (02-01-2012), Delphie (01-31-2012), i8urgti (01-30-2012)
 Old 01-30-2012, 05:02 AM   #15
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
Sometimes you just got to let the noobs learn the hard way. OP, only way to monitor fuel pressure accurately is Accessport. Why chance it with an intake and exhaust? Put that money towards an AP. Take our advice or don't, just don't come crying and bitching when your shit blows up, because all I'm gonna do is call you an idiot and laugh at you.
Sent from my Etch a Sketch
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
ASHMS3 (01-30-2012)
 Old 01-30-2012, 05:21 AM   #16
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Haha!
The joy of NOOB BOOM. I got input and was stupid enough to ignore it. I blew it, and now learning to be more patient and learning that power mods are like crack..getting that next fix is possible, but I have to double check and re-read all enough before bolting.
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
 Old 01-30-2012, 06:06 AM   #17
Jake5713's Avatar
Posts: 1,775   (View Stats)
Fucking dumbass
Can we have a mod just close this useless thread?
-Jake
Jake5713 is offline   Reply With Quote
 Old 01-30-2012, 07:34 AM   #18
thanks to the guys who are willing to actually answer the question!!
and...yes i did searched and i do know there are millions of threads talking abt fuel pumps but none of them addresses my question directly:
"Will the gen2 stock pump be ok with just SRI and cbe?"
and while i was utilizing the search function and looking over the threads, all i see is the same thing where people just tell them to go search and how stupid they are...... trust me if i didn't even search, instead of this i'll probably ask what a hpfp is... and then that would be a really stupid question......
The Following User Says NO Thank You to dhsieh911018 For This Un-useful Post:
 Old 01-30-2012, 07:37 AM   #19
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Skip the exhaust, no power with that mod anyways
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
MS3inDC (01-30-2012)
 Old 01-30-2012, 07:56 AM   #20
mswierse's Avatar
Posts: 313   (View Stats)
mswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the worldmswierse is the leader of the world
Why is AP only accurate way? Has Torque been shown to be wrong? I currently use Torque and can log fuel rail pressure. I will get an AP soon, but can't beat Torque for $30.
Sent from my DROID BIONIC using Tapatalk
jpshotya likes this.
2012 VRM MS3: JBR 3.5" WP Intake, JBR 80 Duro RMM, MD OCC, Cobb AP, MeTune (with Phate's help!), Autotech internals, Denso ITV22 Spark Plugs, Second Cat removed, Ksport Coilovers, SPC camber arms...
13.5@106
mswierse is offline   Reply With Quote
 Old 01-30-2012, 08:03 AM   #21
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Why waste money on exhaust? Use that money to buy an AP...
 Old 01-30-2012, 08:07 AM   #22
to satisfy the inner rice of me hahahahha
yeah for the power the ap is the way to go..... according to corksport the cbe does give you +15 hp or sth like that tho
faeker (02-01-2012)
 Old 01-30-2012, 08:13 AM   #23
btstarcher's Avatar
Groans: 112
Not even close...CBE nets almost no usable HP.
 Old 01-30-2012, 08:14 AM   #24
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Yes they have answered your question directly. Since a CBE doesn't give you any gains except for noise it would have nothing to do with your fuel pump internals. And since you read you would see that a SRI will or won't cause your fuel pressure to be at a safe level. It's hit or miss with these cars. I decided to go with a SRI and TIP before doing anything else and will be going with fuel pump internals for my next mod no questions asked. By a set of quality internals, install them correctly, break them in, and then save up for an AP. you won't be able to know exactly what your pressure is until you get an AP but with the new internals and your basic SRI, at least you know it is safe for awhile. That was me being nice. Next time don't come on here bullshitting about you read and never got your answer because that's a fucking lie. Read some more. And then read again. And just when you feel like you should post a new thread, read again.
2012 Mazdaspeed3 Black Mica
SweetJP (01-30-2012)
 Old 01-30-2012, 08:15 AM   #25
btstarcher's Avatar
Groans: 112
Torque is OK...but as I said previously, if you're willing to spend the $$ for a CBE, that money would be more wisely spent on an AP.
mswierse (01-31-2012)
 Old 01-30-2012, 08:25 AM   #26
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
You must be fucking stupid
it has been discussed hundreds of time that some vehicles with just a SRI have fuel pump failures.
exhaust nets you maybe 0-5hp. an AP will give you a lot more than that and if you tune for it (which i doubt you ever will) you will be happy.
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 01-30-2012, 08:37 AM   #27
thank you for answering the question with nice and warm suggestions.
and no, that's not a fucking lie nor bs, it's the truth.
your right, i wont get a tune for it.
you are a very well mannered person, you're family must be very proud of you
socrispy likes this.
Last edited by dhsieh911018; 01-30-2012 at 08:37 AM. Reason: MSF Database - Automerged Doublepost
faeker (02-01-2012)
 Old 01-30-2012, 08:41 AM   #28
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
OP, this question has absolutely been asked before. so don't get annoyed with the people giving you shit...
in case you haven't heard it enough, skip the CBE. spend the money on an AP. you can run their stage 1 OTS maps just fine. and if shit starts failing, you'll know because you'll be logging. the Cobb website specifically says what you can and can't run on those OTS maps. i'd also just get a TIP since you are doing the SRI.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline   Reply With Quote
 Old 01-30-2012, 08:47 AM   #29
Groans: 263
well in that case
mazdas247 is ---------->
2010 Black Mica
The Following 2 Users Say Thank You to rghispanic88 For This Useful Post:
ASHMS3 (01-30-2012), Sid3wayS (01-30-2012)
 Old 01-30-2012, 08:51 AM   #30
GODspeed7's Avatar
I pick up on sarcasm very well. I did answer your question and even suggested future paths as well. I have donated to this forum and have answered repeated questions multiple times by people who haven't donated. Forgive me if I offended you but your question is like asking "if I play with fire will I get burnt" the answer is sometimes you will sometimes you won't. It just depends on the user. You know there is a risk involved and you know what steps to take to prevent it. But good luck and install your SRI without worries and save your CBE money for internals instead. Also might want to get some thicker skin and\or a flame suit if you plan on sticking around.
 Old 01-30-2012, 08:51 AM   #31
bigriver's Avatar
Posts: 1,123   (View Stats)
OP - you are just looking for someone to agree with you. No one will because we are all passionate about our cars and the collective experience here is that FP is a top priority which needs to be monitored. No sense wasting your money on an intake if you arent serious about FP. Plus your car is gonna feel slower off the line on a stock tune, then you'll be looking to get an AP anyway. Been there, done that. If you even read the sticky on getting to know your speed, you wouldnt have started this thread. So everyone knows you really didnt your homework.
 Old 01-30-2012, 09:15 AM   #32
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
dizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the world
Groans: 64
@dhsieh911018, definitely get an exhaust first. It's the only mod you will need and power is really noticeable. These guys clearly don't know what they are talking about when they say AP or Torque--this car has plenty of torque, no need for more.
deadlandxtreme likes this.
Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint
dizzydtrain is offline   Reply With Quote
The Following 8 Users Say Thank You to dizzydtrain For This Useful Post:
ASHMS3 (01-30-2012), bigriver (01-30-2012), BobbleHead (01-31-2012), deadlandxtreme (01-30-2012), Ingle (01-30-2012), mswierse (01-31-2012), Onelovesoccer (01-30-2012), Sid3wayS (01-30-2012)
 Old 01-30-2012, 09:20 AM   #33
Groans: 82
Well said sir!
 Old 01-30-2012, 09:41 AM   #34
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
Get an AP, or don't we don't care. Your question has been answered, now run along and go play in traffic.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
 Old 01-30-2012, 09:53 AM   #35
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
get internals or start looking for a spare motor.
/thread.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 01-30-2012, 11:12 AM   #36
DownSideFX's Avatar
Posts: 234   (View Stats)
DownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the world
Groaned at 25 Times in 9 Posts
I ran a Corksport Race pipe and SRI with the inlet pipe and had no issues for almost a year. Just got the AP so I'll take a look at how my fuel pressure has been looking. I think honestly you'd be OK, to be safe you'd want to get the internals but I'd be very surprised if everything went immediately downhill for you right after adding those 2 mods.
Garage: 2014 Evolution MR, 1983 Volvo 242 Turbo
Past: 2010 Mazdaspeed3
Do not donate to this fucking shithole. lol
DownSideFX is offline   Reply With Quote
 Old 01-30-2012, 11:20 AM   #37
Wouldn't be to surprised if your fuel pressure is low, GenPu's factory pump internals dont seem to hold the same as the Gen1 stock internals. There have been plenty of threads from GenPu owners with just an intake that are having FP problems.
FREEKTUNE
 Old 01-30-2012, 11:42 AM   #38
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
Groaned at 4 Times in 2 Posts
OP Many have given you sound advice on what to do, but it doesn't seem to be sinking in, so perhaps I can spell it out in a different manner, so that it makes more sense.
What you want:
SRI + CBE = mazda24/7 "cool sounds bro, must be fast becuase racecar"
What MSF recommends
SRI + (optional TIP) + AP + HPFP = properly monitored and regulated FASTER, safer car with further help from experienced tuners down the road
or in an even simpler way.....
$200 + ~$700 (for no power gain)= sound and most likely zoom zoom boom and no girls
or
$200 + $500+ $350 = "Wrexx in Effect => zoom zoom and the poom poom" on a stable car!!
Capiche???
KingKoopaBoy likes this.
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline   Reply With Quote
The Following 2 Users Say Thank You to J_Logik For This Useful Post:
BobbleHead (01-31-2012), Titan (01-30-2012)
 Old 01-30-2012, 11:54 AM   #39
Elusivellama's Avatar
Posts: 351   (View Stats)
Elusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the world
You would gamble your engine on a $350 part that's known to be barely adequate as it is? That's the question I asked myself.
BobbleHead likes this.
Elusivellama is offline   Reply With Quote
The Following User Says Thank You to Elusivellama For This Useful Post:
 Old 01-30-2012, 11:58 AM   #40
ASHMS3's Avatar
Groans: 126
Deadland's blown motor thread shuold be a sticky at the top of Genpu section so we have a place to point these guys when they ask why they need internals. Or, we can just start letting them go ZZB and laugh at the carnage.
Fuel pump upgrade total noob Jake5713 Gen2 MS3 General Discussion 84 09-21-2011 04:42 PM
do i need the fuel pump upgrade? stageup MazdaSpeed 3/6 - Turbo Induction 10 08-15-2009 01:40 AM
datalog not doing so well not tune no fuel pump fully bolt ons Sanch MazdaSpeed 3/6 - ECU Computer Tuning 21 01-20-2009 05:21 PM
Fuel Pump Upgrade? mrjoshyman MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-08-2009 11:13 PM
Page generated in 0.58686 seconds with 45 queries
