![]() | | #41 | ![]() |
![]() Join Date: May 2011 Location: Palisades Park, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 687
| Not Ranked : 0 score Came out one piece at a time.
__________________ 2011 Black Mica MS3 NJSPEED3 Ported IM + other shit ![]() NJ NATOR NY 316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12 |
| The Following 2 Users Say Thank You to xb2ms3 For This Useful Post: | danieldolina70 (06-02-2012), Voltron (06-03-2012) |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #43 | ![]() |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
| Not Ranked : 0 score Here's my $.02 There's so much going on under that hood, as far as airflow, turbulence, etc after you get up to a certain mph that's there's not much any of us can do to change it or affect it. Say, at 40mph, there's so much air moving around up and down, left and right, swirling, leaving out the side, leaving out the cowl, leaving out bottom, etc.; I'm thinking opening up an extra 10% of airflow over the aluminum engine block and intake manifold aren't going to magically drop your BATs more than a few percent if you are lucky; and that would be after driving for 1/4 of a mile. The problem is, the intake manifold and engine block/head are as prone, or more prone to heat soak than anything else under that hood. Expecting the temp of any of those pieces to drop by even 1*F during a 0-60 run by opening up that slot versus leaving it shut is crazy. Remember every 11*F = 1% gain in hp. We all know that when you sit still at a stop light in 100*F weather that IATs go up big time. So if I launch, even just spiritedly, getting a smooth flow of ambient air around that cone filter, even if only for 4 or 5 seconds, is going to help on the order of 10s of degrees F immediately, up until about 40mph when, again, none of us can control shit after that point. None of this "free aerodynamic redirecting using reused stock intake parts" is going to make much difference. As far as BATs, BATs are simply a function of IAT * boost * some constant. PV = nRT. The amount of heat picked up by boosted air passing over the intake manifold could surely be significant (this is why most modern N/A cars use plastic intake manifolds, to reject heat even more), but are we going to affect the WHOLE MASS of the intake manifold on a simple launch from 0-60 ? I just can't see it so. Ever seen the bottom of a million dollar exotic car? They line the thing with a flat sheet of something so that the air coming into the engine bay is actually aerodynamically flowed through the rest of the car, probably past various radiators and intercoolers, finally exiting just prior to the rear brake rotors where yes 200*F air can cool an 800*F brake rotor. Probably a team of engineers making more money than any of us could dream of came up with that shit. I'm talking Ferraris, Bugattis, etc. I doubt our $24k Mazdas have undergone such overthought in terms of aerodynamic flow through the engine bay. Besides, if it was more efficient to blow air right onto the intake manifold, why didn't the factory just do that in the first place? Cars are machines. All machines are based around a set of requirements and COMPROMISES. We know why the big heavy airbox is there from the factory.... to quell noise. So we all yank that out, put up with extra noise, and enjoy the extra 10hp. But why would Mazda go to extra lengths to purposely suck air from in from that fascia slot than from the surrounding engine bay? I'd have to think someone got approval to add $10 to each car for gathering most of the intake air from the fascia slot instead of leaving the fascia slot just open to blow air across the motor. There's more to a 2.04 60' time than just traction y'know. Bottom line, without numbers we are all in the dark. And let's stop using dynos as our medium of testing? Let's get someone with some god damned temp probes in there and do some heat soaked accel runs, rolling starts, high speed runs, etc. You know test the cars in an environment closer to what they will actually operate in. So there's some $0.02, it could be right, it could be wrong, and I've surely pissed off the TL;DR crowd with THIS baby.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... Last edited by fortressofcomfort; 06-01-2012 at 11:40 PM. |
| The Following 2 Users Say Thank You to fortressofcomfort For This Useful Post: | forcedinduktion (06-04-2012), MS309 (06-01-2012) |
![]() | | #44 | ![]() |
![]() Join Date: Feb 2012 Location: Sacramento, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 33 Times in 13 Posts
| Not Ranked : 0 score Okay... A few days ago I changed my MT fluid and noticed this. I had not seen it when I installed my SRI. I took this picture and posted it in shout and got all kinds of shit for asking about it. At least now I know I am not the only one.
__________________ 2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice) OBAMA SUCKS Stratified Tune by Lex |
![]() | | #45 | ![]() |
You can reverse the way the piping fits the fascia intake; it'll still fit the tabs and shit and it'll point damn near dead on to the cone filter. A little super glue and mine has not fallen off yet (and I've had my car up to very high speeds). So fix it up and then run some logs and tell the others you are getting IATs within a few degrees of ambient (after you heat soak a while and then take off from a stop/red light of course)
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... | |
![]() | | #46 | ![]() |
__________________ 2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice) OBAMA SUCKS Stratified Tune by Lex | |
![]() | | #47 | ![]() |
Again PV = nRT. Your BATs are directly proportional to your IATs.
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | Darth_Nuruodo (06-06-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
![]() | | #49 | ![]() |
| Not Ranked : 0 score So heres some hard numbers for you guys, i have an ultra gauge so this is every day live data im going off of not random data logs. Being in South Houston my IATs were typically +~5 ambient in the 80*s and ~7-10 in the 90*s, and coolant temp is typically always about 192.x Today with it being 90 outside i saw IATs of ~93.x and coolant temp of 186.x I'd say this is a pretty effective means of cooling.
| The Following User Says Thank You to Voltwings For This Useful Post: | SLOWHATCH (06-02-2012) |
![]() | | #50 | ![]() |
I also have an old analog temp probe thingy that can read 4 different temps at once. I might whip that out.
![]() | | #51 | ![]() |
| Not Ranked : 0 score mk im doing brakes right now so it will probably more in the evening when i do this so it may or may not be cooler. Also i wouldnt say i knew how fast they dropped before but i may be able to tell if theyre dropping quicker now. The road im going to brake the pads in on has a stop sign maybe every 50 yards or so, so we'll see how this goes.
![]() | | #52 | ![]() |
| Not Ranked : 0 score So I re-read this today from having read it last night. I am not as certain about removing it as I was last night but if I do not remove it I will try to manipulate it to blow more toward the intake. For those who have removed this piece and are seeing improvements, did you also remover th cowling on the rear of the engine bay?
![]() | | #53 | ![]() |
![]() Join Date: Jan 2012 Location: Fort Worth TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score After looking into the side of the engine bay I noticed it only has one electric cooling fan and the other side looks like it has vents that open when air is getting pushed in. That's crazy. Guess that one fan can cool off the radiator pretty nicely. Anywho, I removed the air intake shroud and ill see if it helps out any.
__________________ 2012 Velocity Red Mica w/Tech / JBR rear motor mount & SSP with weight / Cobb AP w/ CS stage 2 intake / auto tech internals / eBay one piece down pipe race pipe / turbo smart BPV / raceland coilovers / Motegi 18x8 et 40 with 235-40-18 tires |
![]() | | #54 | ![]() |
Voltwings.. I'm not trying to disprove anything... I really want to know the answer. I've done similar experiments on other cars and the results have been mostly.... inconclusive. I would imagine at a steady speed that everything under the hood reaches a certain stable degree over ambient. It's the stopping and starting in hot weather that everyone hates. I mean, I guess you hate it. Turbo car + hot day = shite. Now imagine if you had an auto tranny behind that thing ? On a slight derailment.... why are there no controls (Red) in ATR to turn on the fan at a very low temp? I'd like, in a track map, to just run the fan basically constantly, or at least at underhood temps > 120*F or so.
![]() | | #55 | ![]() |
| Not Ranked : 0 score Oh no by all means i'm aware that this is a factual forum, "it feels fast" doesn't mean anything unless backed up with numbers, i take no offense to your "skepticism" as soon as Brake check calls me back (had to have the rotors machined) ill be all over getting some harder numbers for you guys.
![]() | | #56 | ![]() |
Let's say I have 4 "probes" that are basically little 3mm barrels of metal attached to leads. #1 I could obviously dangle in front of the outlet of the super glued tube dude. This would be convection (air contacting metal; I would expect this to be ambient or within a couple degrees). #2 I could tape? to the cone air filter, maybe 90* out of the natural flow of air from the "duct". This metal on metal would be what induction (metal on metal)? I would expect this to be 5-10* higher than #1 because underhood temps will eventually have its effects on the metal of the cone air filter #2.5 is virtual... it is the IAT sensor on our APs #3 I could dangle at the inlet at the fascia (convection again) This better read ambient. #4 I could tape? to the front of the intake manifold, where the fascia would blow air onto. This would be another metal to metal connection. I would expect this to fluctuate somewhere between the current temperature of the coolant (195 *F) and the current boosted air temps (5-8* over IAT up to god only know how much boost you are running #4.5 would be virtual.... our boosted air temp reading from the AP. My hypothesis is that most temps at all points are the same except for #4 which will be WAY up there. I could drive around as is, doing heat soaked and non heat soaked trials, and then I could completely block off the super dooper intake pooper and see what happens. I guess a third trial would be to cut my fascia intake all the fuck up but I have a hunch, for my style of stop and go driving and waiting in pit lanes, that leaving the fascia free to flow air into the vicinity of the cone air filter will be superior and I don't want to go on the wanted-to-bys looking for a stock fascia intake. What you think?
![]() | | #57 | ![]() |
![]() | | #58 | ![]() |
Groans: 274
In normal every day driving my bat's are usually 10-15* over ambient. Today after removing that ducting and the foam behind it, my bats were steadily 8-12* over ambient. Now I have done several things to combat heat soak including 1. Raising my ETS TMIC as far as I could (roughly .5") 2. Removed the weather stripping on the hood cowl. 3. JBR Intake manifold TIG 4. Coolant By-pass mod 5. This one doesn't matter but I run WMI and only makes a difference when in boost. 6. I can't think of anything else | |
![]() | | #59 | ![]() |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score @SLOWHATCH Not to go off subject here but how did you raise the tmic? Did you just use washers on the underside?
__________________ TEAM LUXURY ![]() |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I still say the BATs over IATs is way more of a function of the ideal gas law than any amount of charge cooling you could possibly and practically put into these cars. This is why E85 is such a popular option. It changes the balance of the ideal gas law and makes BATs basically a non-function. Once again: PV = nRT. Sorry if you missed physics. Put it to you this way. Flash a stage 1 (16psi) map on your car. I bet your BATs never get more than 15-20* over your IATs. Now flash your own wack-o map (we all have one) that runs 19psi. Now your BATs are 30-40* over IATs near the top of the rev range. This is because we are pushing the K04 to the brink of its efficiency. The amount you compress the air is the #1 indicator of BATs. Yes IATs and cooling the charge help absolutlely but you will always be fighting your BATs when you push the turbo outside its efficiency range. $.02 Gotta find that old proby thing. I still say this whole thread has alot to do with how you drive your car.
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | f-castrillo (06-02-2012) |
![]() | | #61 | ![]() |
![]() Join Date: Feb 2012 Location: Bear,Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,312
| Not Ranked : 0 score Mine has been off for awile,but I run E-85 mix so I dont hafta worry about high BAT
__________________ [SIGPIC][/SIGPIC]//GT3076r EWG///GUARDIAN ANGEL///JMF INTAKE MANI///COBB EBC///LONG TUBE MANI///RICH TUNE///CPE PRE FILTER///CPE INTAKE and TIP COMBO///CPE TMM AND RMM///TURBO SMART BPV///CPE BIG ASS FMIC WITH CRASH BAR///COOLANT BYPASS///NGK-1 PLUGS///CPE HPFP/// LONG TUBE DP///CPE TRITON CBE///SURE PMM///SURE RSB///AEROFORCE GUAGES///JBR OCC///RALLY ARMOR FLAPS///6000 k HID LOWS AND FOGS///YELLOW-SPEED COILOVERS///KONIG WHEELS WITH 245/40/18 MICHELIN PS2 TIRES /KILLER BUILT TRANS WITH ACT 6 PUCK AND PRO LIGHT FLYWHEEL ////////// NATOR DELAWARE/////////////////////// STICKERS WON'T MAKE YOUR CAR FASTER .BUT HANGING WITH GUYS WITH NATOR STICKERS WILL 321 hp 359 tq Nator Pa. DYNO DAY 10/13/12 WITH KO4 TURBO 369 hp 368 tq NO meth or e85 ... MNM dyno day ...... |
| The Following User Says Thank You to danieldolina70 For This Useful Post: | fortressofcomfort (06-02-2012) |
![]() | | #62 | ![]() |
| Not Ranked : 0 score Thats a pretty good idea to raise the tmic. I also saw that someone put heat reflective tape under the tmic. I think i'm gonna try both. Summer is getting close...
| The Following User Says Thank You to xb2ms3 For This Useful Post: | danieldolina70 (06-03-2012) |
![]() | | #63 | ![]() |
Also @fortressofcomfort it got later than i had hoped by the time i was done and i wasnt able to get concrete numbers for you but i did do a small test. in 90* ambients i let the car idle till IATs were about 110. Drove down my street (200 meters or so) and they had cooled to maybe 96* going 25 mph 3rd gear. stopped at the stop sign, IATS back up to 99, about 20 seconds later of what i would call normal driving (however according to my friends i drive like a grandma ) i was back down to 5 over ambient, and another 10 - 15 seconds showed 3 over ambient. While this mod may not cool any faster, as this may or may not have just proven, it has proven to lower my average IAT, as well as Coolant temp. Now my ultragauge does not monitor BATs which i know is more so to the point of this thread, however the two are related so lowering one is almost sure to lower the other yes?
![]() | | #64 | ![]() |
| Not Ranked : 0 score YES! Now we have some numbers to work with. Thank you. It may take me a few days and a roll of duct tape but we'll figure this out once and for all. Based solely on your observations today it further backs up my conclusions found with other cars I've experimented on.... that the results are inconclusive lol (that one way isn't better than the other way, that none of us has any real good idea as to what kind of patterns the air follow under the hood once underway). Thanks man.
![]() | | #65 | ![]() |
Groans: 274
Basically some thick washers. Except I had my dad make them at his work on a CNC machine. They are 5 or 6 mm each, cant remember. They were made to fit perfectly over my wheel studs and were previously used as wheel spacers. I'm attaching a log here to show my bat's vs intake temp. Pretty weak log, but you get the idea. This is after driving the car for about 20 minutes, sat for 20 minutes then cruised 5 minutes to highway with a few stop lights in between. Seems it recovered pretty quick imo, but my results could be skewed by the wmi. Edit: I take back the "weak log" statement lol, I guess I just managed to get some grip instead of wheel spin. Attached vd log for pure amusement. Last edited by SLOWHATCH; 06-02-2012 at 09:33 PM. | |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | Sid3wayS (06-03-2012) |
![]() | | #66 | ![]() |
![]() | | #67 | ![]() |
![]() Join Date: Aug 2011 Location: Littleton, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 5 Times in 2 Posts
I live in hot ass Dallas, TX and just ordered my Lex tune tonight
__________________ 2011 Silver MS3 CS SRI and TIP // Cobb AP // Autotech internals // Cobb downpipe // CP-e TMIC // Cobb BPV // Resonator delete // JBR RMM // JBR RSB // NGK spark plugs // e85 Stratified Tuned | |
![]() | | #68 | ![]() |
Does the e85 actually drop BAT? Or does it just make high BAT's irrelevant because of it decreasing the likelihood of knock?
| The Following User Says Thank You to zedekias For This Useful Post: | danieldolina70 (06-03-2012) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Hey all, I've got the entire front clip/headlight assy's, stryofoam shit, etc. off of my car investigating this fucking question. I guarantee you you will be surprised at some of my findings. Let's just say nothing conclusive yet but many many nooks and crevices are to beheld. I have taken over 12 pictures of tubing, the interfaces the tubes see (that you cannot possibly see without taking much of the front clip off), what is there/seen when the tubing is removed, holes you probably never thought existed, etc. Stay tuned... I think this one will be good. Here's a hint.... the solution involves yellow sidewalk chalk from my daughter's toolbox.
| The Following 6 Users Say Thank You to fortressofcomfort For This Useful Post: | AdrenalineMS3 (06-03-2012), Caboose (06-04-2012), f-castrillo (06-03-2012), kylec_2003 (06-03-2012), SLOWHATCH (06-03-2012), Voltron (06-03-2012) |
![]() | | #70 | ![]() |
I guess he is going to be helping us both with them
![]() | | #71 | ![]() |
| Not Ranked : 0 score From what i've been told high BAT will take away some HP but running a E-85 mix will let me increase timing ,so it makes up for the higher BAT,,
![]() | | #72 | ![]() |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score This thread took off lol. Anyways, it seems theres alot of different opinions on whether or not this actually works or not. In any case, mines off like I had posted, and I seemed to have lowered my bats at cruising. In any event, there's a e85 station in NY about 10 minutes from me, and a meth kit calling my name sometime this month. |
| The Following 3 Users Say Thank You to Voltron For This Useful Post: |
![]() | | #73 | ![]() |
Groans: 77
| Not Ranked : 0 score @fortressofcomfort, damn dude, you are one technical ass motherfucker, you made me Second guess pulling that shit off lol. But it's staying off cause I'll call it weight reduction. @Bosox I left that piece on when I did my Sri, and found it on my undertray when I changed my oil haha. And btw, I was lookin at your sig, what's all this mazdaspeed stuff you haz? Body kit? Wing? I'm curious. Pics please. Thanks. @xb2ms3 Dougie.....I haz idea. come over tonight, Ill hold it and you punt mine across the lot towards the Evo that haunts me. Last edited by Voltron; 06-03-2012 at 07:45 AM. |
![]() | | #74 | ![]() |
| Not Ranked : 0 score @Bosox I left that piece on when I did my Sri, and found it on my undertray when I changed my oil haha. And btw, I was lookin at your sig, what's all this mazdaspeed stuff you haz? Body kit? Wing? I'm curious. Pics please. Thanks. I was seeing how long it would be before someone noticed that
![]() | | #75 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
LOL nevermind I saw my own fail...
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
![]() | | #76 | ![]() |
Groans: 77
| Not Ranked : 0 score Ok, so I noticed. Pics. @Bosox |
| The Following User Says Thank You to Voltron For This Useful Post: | btstarcher (06-03-2012) |
![]() | | #77 | ![]() |
![]() | | #78 | ![]() |
Groans: 77
| Not Ranked : 0 score Meh comes up blank. |
![]() | | #79 | ![]() |
Groans: 274
![]() | | #80 | ![]() |
| Not Ranked : 0 score OK, here comes mr. Empirical. I have taken 32 pictures of me dismantling my car and showing you every single "over radiator/condensor" passthrough in detail. I have lots to add (and still not much conclusion as I'm still testing) but if you are tracking this thread go ahead and look at these. Explanations of the pics will be forthcoming. Thanks.
| CP-E TMIC - What's your BAT's should I have with this? | Domino81 | MazdaSpeed 3/6 - Turbo Induction | 10 | 03-13-2012 05:40 PM |
| Cant get my BAT's down | mghtymouse380 | 2010 MS3 - Turbo Induction | 75 | 07-06-2011 07:21 AM |
| Please post your BAT's | Campo | MazdaSpeed 3/6 - Turbo Induction | 36 | 10-01-2009 10:36 AM |
| Another GB, lower your BAT's and fix your oil burning issues! | ptperformance | Mazdaspeed3/6 General Discussion | 2 | 08-24-2009 12:14 PM |
| hows your BAT's like? | johnac08 | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 02-19-2009 12:53 PM |
