Like Tree6Likes
 Old 01-25-2012, 04:02 PM   #41
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
Originally Posted by Mizzle View Post
I call bullshit on your source and logic.
a.) Who said they don't have E in their 91?
b.) Ethanol reduces knock.
A.) it says so on the shell pumps. Says specifically that their 91 octane contains no E. I shall take a picture next time I fill up.
B.) I only base my statement on the fact that the other two top tier brands (petro and esso) have some degree of E in their 91 blend.
I have filled up and logged with all 4 brands of gasoline. Petro/esso cause upwards of 3 KR, shell and husky result in 0 KR, same tune, same mods, same road, almost the same temps running at night.
Husky 94 is a few cents more than shell 91.
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
 Old 01-25-2012, 04:23 PM   #42
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Ethanol is usually a great octane booster, and in most cases should help to keep knock away.
It depends on who wrote it and what you read, but the lowest I've seen ethanol quoted as being octane wise is 105.
Mixing any amount of a fluid with a higher octane rating should technically bring the octane rating of the lower rated fluid up (as a whole mixture wise).
In the end, who knows what the hell those guys are putting in the tanks. LOL!
 Old 01-25-2012, 09:24 PM   #43
MS309's Avatar
LOL whatever works man.
'11 CWP Speed3
The Following User Says Thank You to MS309 For This Useful Post:
rfinkle2 (01-26-2012)
 Old 01-26-2012, 08:16 AM   #44
triplejumper18's Avatar
Posts: 2,569   (View Stats)
triplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the worldtriplejumper18 is the leader of the world
Groans: 196
Groaned at 57 Times in 47 Posts
Ethanol doesn't reduce knock when it's in pump gas from the station. 93 octane is 93 octane.
triplejumper18 is offline   Reply With Quote
The Following User Says Thank You to triplejumper18 For This Useful Post:
f-castrillo (01-28-2012)
 Old 01-26-2012, 08:55 AM   #45
IPuOnU's Avatar
Posts: 399   (View Stats)
IPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the world
What ever has station I happen to be by when I need to fill up, whether that be racetrack, chevron, Hess, BP, shell(when I grocery shop I get extra off). Same goes for my firebird. 93 only. Every once in a while will throw in a can of sea foam to clear her up if she is idling funny. Fuel is fuel is fuel. It all burns, 99% of the companies will use similar additives with different names.Not like they are national secrets.
2010 CBM Speed 3 (Daily)
Muffler Delete
Sure Aeros
TRZ Poly RMM
14.11 @ 100 2.1 60'
1986 Firetird
350 Chevy (2 Bolt Main)
Stock Bottom End
Edelbrock E-tec 200 Heads (Port, Polish, Decked)
JE Pistons
Ford 9" Rear End 4.30 Gears
Stock Suspension
11.29@113.8 mph, 1.54 60'
IPuOnU is offline   Reply With Quote
 Old 01-27-2012, 09:43 PM   #46
richkidone's Avatar
Posts: 108   (View Stats)
richkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant future
I use shell 93 since the day i bought car no problems.
yea buddy v-power
2011 lsm w/tech pack K&N sri/hks w/recirc kit / AP+autotech internals /UR racepipe/ cobb TIH /downpipe/ tigs/ rear mount inserts/ngk ltr7ix
"IM LOVING IT"
richkidone is offline   Reply With Quote
 Old 01-27-2012, 10:44 PM   #47
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Back in the day Sunoco and Shell gasoline seemed better than all the others. Nowadays can't say for sure.
I am a firm believer of the RedLine SL-1 fuel cleaner. Not sure how well it will work on these DI cars but have always used it ever 15k or so on my other cars. People also seem to like the Techron cleaner and when I do use that it works well also.
2012 Black Mica MazdaSpeed3
Street creds:
The Following User Says Thank You to fortressofcomfort For This Useful Post:
rfinkle2 (01-28-2012)
 Old 01-28-2012, 11:08 AM   #48
nick779's Avatar
Posts: 215   (View Stats)
nick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud of
Groans: 32
i ONLY use BP 93, i hardly ever knock part throttle and sometimes knock at wot, but i probably just need to swap my itv22s in
'11 Speed 3 Black Mica (Sold unfortunately, going back to school)
'12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it
Licensed PA State Inspection and Emissions Tech
nick779 is offline   Reply With Quote
The Following User Says Thank You to nick779 For This Useful Post:
 Old 01-28-2012, 04:03 PM   #49
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Only Mobil for me.
It's generally 10-16 cents more expensive..doesn't that mean its the best?
The Following User Says Thank You to helmetface For This Useful Post:
Top 3 Tire Brands JMVP726 2010 MS3 - Wheels & Tires 9 05-10-2011 07:52 PM
The Top 10-ish Orphan Car Brands Haltech Automotive News 0 12-01-2008 06:40 PM
Page generated in 0.29886 seconds with 27 queries
