![]() | | #41 | ![]() |
![]() Join Date: Apr 2011 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
| Not Ranked : 0 score
B.) I only base my statement on the fact that the other two top tier brands (petro and esso) have some degree of E in their 91 blend. I have filled up and logged with all 4 brands of gasoline. Petro/esso cause upwards of 3 KR, shell and husky result in 0 KR, same tune, same mods, same road, almost the same temps running at night. Husky 94 is a few cents more than shell 91. Sent from my iPhone using Tapatalk
__________________ '11 CWP Speed3 More torque than your right arm. | |
![]() | | #42 | ![]() |
Groans: 298
It depends on who wrote it and what you read, but the lowest I've seen ethanol quoted as being octane wise is 105. Mixing any amount of a fluid with a higher octane rating should technically bring the octane rating of the lower rated fluid up (as a whole mixture wise). In the end, who knows what the hell those guys are putting in the tanks. LOL! | |
![]() | | #43 | ![]() |
| The Following User Says Thank You to MS309 For This Useful Post: | rfinkle2 (01-26-2012) |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
Groaned at 57 Times in 47 Posts
| Not Ranked : 0 score Ethanol doesn't reduce knock when it's in pump gas from the station. 93 octane is 93 octane.
__________________ |
| The Following User Says Thank You to triplejumper18 For This Useful Post: | f-castrillo (01-28-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Mar 2011 Location: Bradenton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score What ever has station I happen to be by when I need to fill up, whether that be racetrack, chevron, Hess, BP, shell(when I grocery shop I get extra off). Same goes for my firebird. 93 only. Every once in a while will throw in a can of sea foam to clear her up if she is idling funny. Fuel is fuel is fuel. It all burns, 99% of the companies will use similar additives with different names.Not like they are national secrets.
__________________ 2010 CBM Speed 3 (Daily) Muffler Delete Sure Aeros TRZ Poly RMM 14.11 @ 100 2.1 60' 1986 Firetird 350 Chevy (2 Bolt Main) Stock Bottom End Edelbrock E-tec 200 Heads (Port, Polish, Decked) JE Pistons Ford 9" Rear End 4.30 Gears Stock Suspension 11.29@113.8 mph, 1.54 60' |
![]() | | #46 | ![]() |
![]() Join Date: Jun 2011 Location: MIAMI FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
| Not Ranked : 0 score I use shell 93 since the day i bought car no problems. yea buddy v-power
__________________ 2011 lsm w/tech pack K&N sri/hks w/recirc kit / AP+autotech internals /UR racepipe/ cobb TIH /downpipe/ tigs/ rear mount inserts/ngk ltr7ix "IM LOVING IT" |
![]() | | #47 | ![]() |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
| Not Ranked : 0 score Back in the day Sunoco and Shell gasoline seemed better than all the others. Nowadays can't say for sure. I am a firm believer of the RedLine SL-1 fuel cleaner. Not sure how well it will work on these DI cars but have always used it ever 15k or so on my other cars. People also seem to like the Techron cleaner and when I do use that it works well also.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
| The Following User Says Thank You to fortressofcomfort For This Useful Post: | rfinkle2 (01-28-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Jan 2011 Location: pittsburgh, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
Groans: 32
| Not Ranked : 0 score i ONLY use BP 93, i hardly ever knock part throttle and sometimes knock at wot, but i probably just need to swap my itv22s in
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech |
| The Following User Says Thank You to nick779 For This Useful Post: | rfinkle2 (01-28-2012) |
![]() | | #49 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Only Mobil for me. It's generally 10-16 cents more expensive..doesn't that mean its the best?
__________________ ![]() |
| The Following User Says Thank You to helmetface For This Useful Post: | rfinkle2 (01-28-2012) |
| Top 3 Tire Brands | JMVP726 | 2010 MS3 - Wheels & Tires | 9 | 05-10-2011 07:52 PM |
| The Top 10-ish Orphan Car Brands | Haltech | Automotive News | 0 | 12-01-2008 06:40 PM |
