Like Tree10Likes
 Old 08-05-2012, 10:37 PM   #1
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
Default GenPus do NOT loose boost at 5500
I hold 15.5psi till 6K RPMs, whats all this talk about falling on its face at 5500RPMs?
*bone stock
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 08-05-2012, 10:40 PM   #2
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Most cars hold that boost to red line once tuned....
Try running 19-20psi of boost to redline, bit harder
Try looking at power figures, you'll see what people mean then
And logs > video of OEM boost gauge
kritz likes this.
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
The Following 17 Users Say Thank You to SarcasticOne For This Useful Post:
3Gee Tee (08-06-2012), charlesfist (08-06-2012), CWP_MS3 (08-06-2012), Darksun280 (08-06-2012), doubleflusher (08-06-2012), J'sSpeed3 (08-11-2012), kritz (08-06-2012), Macncheese (08-06-2012), Monotonous ONE (08-07-2012), MS3inDC (08-07-2012), NJSPEED3 (08-06-2012), Onelovesoccer (08-06-2012), Pointless (08-06-2012), Pseud0logik (08-09-2012), rfinkle2 (08-06-2012), Sid3wayS (08-06-2012), SLOWHATCH (08-05-2012)
 Old 08-05-2012, 10:42 PM   #3
texasboy21's Avatar
And yes, slow Mazda is slow.
2003 A4 1.8TQ
The Following 2 Users Say Thank You to texasboy21 For This Useful Post:
J'sSpeed3 (08-11-2012), Macncheese (08-06-2012)
 Old 08-05-2012, 10:45 PM   #4
snailD's Avatar
Posts: 3,039   (View Stats)
ok so here is the thing. that boost gauge reads 1psi high so it looks like you always hit full boost. second thing is that everyone on here says power drops off significantly around 5500 because the throttle starts to close on the stock tune. you can feel the power loss im sure, and when the throttle starts closing the boost will stop dropping. at the end you saw the bar go down, take another 1psi off that and you were probably at 13psi ish
The Following 2 Users Say Thank You to snailD For This Useful Post:
Pope (08-07-2012), rfinkle2 (08-06-2012)
 Old 08-05-2012, 10:49 PM   #5
Big_Burd's Avatar
Posts: 831   (View Stats)
Big_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the world
Groans: 118
Groaned at 26 Times in 15 Posts
Lol, genpu
did not know you guys had a little boost bar that really tells you nothing.
Big_Burd is offline   Reply With Quote
The Following 9 Users Say Thank You to Big_Burd For This Useful Post:
3Gee Tee (08-06-2012), Darksun280 (08-06-2012), doubleflusher (08-06-2012), Elusivellama (08-06-2012), J'sSpeed3 (08-11-2012), kritz (08-06-2012), snailD (08-05-2012), SofaKingAwesome (08-06-2012), Tokay444 (08-06-2012)
 Old 08-05-2012, 10:53 PM   #6
insomniacucr's Avatar
Posts: 114   (View Stats)
insomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud of
You can turn it off if you don't want to look at it.
insomniacucr is offline   Reply With Quote
The Following User Says Thank You to insomniacucr For This Useful Post:
snailD (08-05-2012)
 Old 08-05-2012, 11:14 PM   #7
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Hmm, I run between 22 to 24 at redline.
Grikathehun likes this.
Pickles Tune in progress
 Old 08-06-2012, 06:04 AM   #8
texasboy21's Avatar
Word, thinks guys! I am **trying** to remain stock and keep the warranty, although I have started a collection of parts...
I did not know the gauge read a little high, and yes there is definitely a loss of power. Moar boost to come! Thanks for the input and keeping it civil!
2003 A4 1.8TQ
 Old 08-06-2012, 06:37 AM   #9
Posts: 7,290   (View Stats)
Note: Tach reads higher than actual RPMs as well.
Nator is what it does.
The Following 5 Users Say Thank You to kritz For This Useful Post:
Darksun280 (08-06-2012), doubleflusher (08-06-2012), JTMS3 (08-09-2012), MS3inDC (08-07-2012), Weazsel (08-06-2012)
 Old 08-06-2012, 06:47 AM   #10
GODspeed7's Avatar
Posts: 3,456   (View Stats)
This^^^ on mine it's about 250-300 rpm high.
2012 Mazdaspeed3 Black Mica
 Old 08-06-2012, 06:52 AM   #11
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Note: don't believe anything on that mazda tach except the gas needle.
Sent from my XT894 using Tapatalk 2
The Following 11 Users Say Thank You to NJSPEED3 For This Useful Post:
dantes5823 (08-06-2012), Darksun280 (08-06-2012), doubleflusher (08-06-2012), J'sSpeed3 (08-11-2012), JTMS3 (08-09-2012), MS3G35 (08-06-2012), MS3inDC (08-07-2012), Payne Racing 67 (12-10-2012), Pointless (08-06-2012), Voltron (08-07-2012), Zbrit00x (08-06-2012)
 Old 08-06-2012, 06:58 AM   #12
GODspeed7's Avatar
Shit and a little e85 will make that sketchy as well...
The Following 5 Users Say Thank You to GODspeed7 For This Useful Post:
rfinkle2 (08-06-2012), Sid3wayS (08-06-2012), snailD (08-06-2012), Voltron (08-07-2012), Voltwings (08-06-2012)
 Old 08-06-2012, 06:59 AM   #13
Elusivellama's Avatar
Posts: 351   (View Stats)
Elusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the world
Originally Posted by Big_Burd View Post
Lol, genpu
I remembered the sales guy telling me in an excited voice "AAAND it has a boost gauge!! 15psi wow!"
Today my boost gauge exists to tell me when I'm NOT in boost while grocery getting and while driving sedately on the highway. Ironic.
eb2292, ThizSpeed3 and Grikathehun like this.
Elusivellama is offline   Reply With Quote
 Old 08-06-2012, 07:04 AM   #14
crankshaft's Avatar
Posts: 576   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
That's not right either. When mine says empty, I have 3 gallons left.
The MPG meter is a joke as well. Is it that hard to get this shit right?
Has anyone actually run out of gas? How much of the tank is unusable?
Traded in: 2012 MS3, CWP
2019 Dodge Charger Scat Pack
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 08-06-2012, 07:09 AM   #15
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Holding boost and making it efficiently are 2 entirely different subjects.
I wouldn't rev above 5500 rpm on the stock tune. The knock sensor on your factory tune is off above 5700 rpm.
Standsideways likes this.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
ASHMS3 (08-07-2012), moomooz12 (08-07-2012), Payne Racing 67 (12-10-2012)
 Old 08-06-2012, 07:11 AM   #16
The fuel gauge exists in its current state because of dumbasses who ignore gas stations and drive their car until 'E' is reached, and proceed to strand themselves on some deserted stretch of highway. Upon return to civilization they sue the shit out of the automaker for not magically providing them an extra 2 gallons of gas. The MPG readouts are optimistic at best, and flat out delusional at worst. Again, the current implementation exists because of dumbasses who want to feel good about saving the Earth - the same programming was probably used for the MS3 since it shares the same part with the regular 3.
The Following User Says Thank You to Elusivellama For This Useful Post:
 Old 08-06-2012, 07:36 AM   #17
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
+1
Stock gauge is not good for accurate readings. It reads pretty close from -5 to around 10 then gets optimistic.
Buy an ultragauge for a cheap monitoring device
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
The Following User Says Thank You to ztnedman1 For This Useful Post:
snailD (08-06-2012)
 Old 08-06-2012, 07:41 AM   #18
gearhead750's Avatar
Posts: 383   (View Stats)
gearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the world
Groans: 30
Yet another Genpoooo fail thread. If some of you guys would just read a little you'd make the rest of the poo crew look a lot better.
Big_Burd and CWP_MS3 like this.
Thanks 4G63 for the avatar!!!
Originally Posted by DarkHeartMS6 View Post
I didnt think there was a person on this planet as stupid as you... Congratulations, you proved me wrong. WTF is a Mazda RX-7 if not one of the best "tuner" cars as you put it.. out there. Jump off the honda dick, pull the Golf R cock out of your mouth... replace it with a gun and end this world of your stupidity! Please, before you cause a retard apocolyptic end to our world
gearhead750 is offline   Reply With Quote
The Following 9 Users Say Thank You to gearhead750 For This Useful Post:
09speedaddict (08-10-2012), ASHMS3 (08-07-2012), Big_Burd (08-07-2012), CWP_MS3 (08-06-2012), MS3G35 (08-06-2012), MS3inDC (08-07-2012), Pointless (08-06-2012), uncorked11 (08-10-2012), Voltron (08-07-2012)
 Old 08-06-2012, 07:50 AM   #19
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Stock fail-gauge is fail.
The Following User Says Thank You to 3Gee Tee For This Useful Post:
ASHMS3 (08-07-2012)
 Old 08-06-2012, 07:58 AM   #20
dantes5823's Avatar
Posts: 6,576   (View Stats)
Im not gonna argue about the gauge being right or wrong. But im just wondering this. Doesnt that read off the ecu that reads off the map sensor? The same sensor that the ap reads. Or is it just a lag type thing?
 Old 08-06-2012, 08:03 AM   #21
rfinkle2's Avatar
Groans: 298
It probably does read the map sensor, but the # of bars and the visual scaling of that gauge could be way off.
I understand what you mean as far as it SHOULD be accurate, but who knows how they have the led's set up, the height of each led etc.
ASHMS3 (08-07-2012), dantes5823 (08-06-2012), snailD (08-06-2012)
 Old 08-06-2012, 08:03 AM   #22
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
Lose*
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following 3 Users Say Thank You to ckMS3 For This Useful Post:
captain slow (08-06-2012), Nliiitend1 (08-06-2012), SofaKingAwesome (08-06-2012)
 Old 08-06-2012, 08:09 AM   #23
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
lol 25 viewing, this isn't gonna be pretty.
 Old 08-06-2012, 01:12 PM   #24
3Gee Tee's Avatar
Confident thread title is not confident.
The Following 3 Users Say Thank You to 3Gee Tee For This Useful Post:
ckMS3 (08-07-2012), gearhead750 (08-06-2012), snailD (08-06-2012)
 Old 08-06-2012, 01:27 PM   #25
captain slow's Avatar
Posts: 5,559   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 398
Groaned at 50 Times in 34 Posts
Don't know what you're talking about but my Genwon doesn't have loose boost either. My boost is mad tight yo.
2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!!
2014 5.0 Gotta Have It Green w/Track Pack
captain slow is offline   Reply With Quote
The Following User Says Thank You to captain slow For This Useful Post:
ckMS3 (08-07-2012)
 Old 08-06-2012, 01:28 PM   #26
ThizSpeed3's Avatar
Posts: 253   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
Groaned at 13 Times in 3 Posts
drive it, worry about psi after warranty
ThizSpeed3 is offline   Reply With Quote
 Old 08-06-2012, 01:35 PM   #27
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
It doesn't really have anything to do with boost levels.
The power curve just flattens out after 5500 on a stock tune. Basically, the motor just stops pulling.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
ckMS3 (08-07-2012), texasboy21 (08-06-2012)
 Old 08-07-2012, 11:41 AM   #28
mrbeal's Avatar
Posts: 18   (View Stats)
mrbeal is an unknown quantity at this point
Groaned at 9 Times in 3 Posts
I'm curious... why would redline be where it is if you will damage the motor if you rev to it? Seems to me Mazda would have to replace a ton of engines under warranty if this were the case. I understand the power falling off at 5500 but revving to redline is half the fun of driving a stick. Buying a car with a redline of 6700 and NOT being told by the dealer that revving to 6700 will damage the engine seems irresponsible to me. And, if they do tell you not to rev that high why in the world is redline at 6700?? Also, if the fuel pump can or can't handle the job why would they sell it that way?
Mazda "Lets sell a car with a redline of 6700 that we know will damage the engine if it's revved that high and a fuel pump that may or may not supply enough fuel to the engine and will damage said engine if the pump isnt up to the task..." not to mention the rear motor mount. WTF!! Seems to me Mazda is up to no good and anyone who buys a Speed3 knowing these things is a fool. I've found this forum to be extremely un-helpful and just plain rude. You fools are going to have to do with one less "brownie" here... some people just want to go to a site and educate themselves, maybe learn about something they don't know about. Well, you have pretty much educated me out of buying a Speed3. Just the fact that there are so many ignorant people on here buying cars that they know will be damaged if driven just blows my mind. Please, DON'T respond! Assholes
Steve
If you jog in a jogging suit and smoke in a smoking jacket, WHY would anyone wear a windbreaker??
mrbeal is offline   Reply With Quote
The Following 7 Users Say NO Thank You to mrbeal For This Un-useful Post:
captain slow (08-07-2012), Dash08 (08-07-2012), gearhead750 (08-07-2012), himurax13 (08-16-2012), Nathan 6 (08-10-2012), Pope (08-15-2012), uncorked11 (08-10-2012)
 Old 08-07-2012, 11:48 AM   #29
3Gee Tee's Avatar
eb2292 (08-15-2012)
 Old 08-07-2012, 11:51 AM   #30
Tripple OG
NJSPEED3's Avatar
Groans: 113
Typical poo stuff going on here.
The Following 4 Users Say Thank You to NJSPEED3 For This Useful Post:
ckMS3 (08-07-2012), moomooz12 (08-07-2012), rfinkle2 (08-10-2012), Voltron (08-07-2012)
 Old 08-07-2012, 11:55 AM   #31
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Gandalf... he's always right.
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 08-07-2012, 11:57 AM   #32
SRTie4k's Avatar
Posts: 1,715   (View Stats)
There is absolutely nothing wrong with going WOT to redline on the stock tune. It's not going to blow your engine up.
But that doesn't change the fact that on the stock tune the car still loses power between 5500 and redline. Peak power occurs right around 5500.
 Old 08-07-2012, 11:58 AM   #33
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
Is it just me or is this about to get good?
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 08-07-2012, 11:59 AM   #34
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
Rob hit it right on the head, the last 2 bars cover from 7 to 15 psi, iirc. Kinda hard to get a good reading off of that. Install a boost gauge or get an AP or other monitoring device, and be done with it.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
The Following User Says Thank You to ASHMS3 For This Useful Post:
rfinkle2 (08-07-2012)
 Old 08-07-2012, 12:05 PM   #35
Pope's Avatar
Posts: 683   (View Stats)
Pope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the worldPope is the leader of the world
Groans: 51
Groaned at 40 Times in 28 Posts
i hate when people say they dont wanna void the warrenty with after market parts, please learn some info about how after market parts do not void the warrenty
1.5 millions posts here. Every question you ever had about this car, has been answered...
I suggest you start reading the forum in depth. This community is nothing like you have ever joined before.
its sexiest..
its perverted
its racist
its all performance
And somehow, it all manages to work.
Pope is offline   Reply With Quote
The Following User Says Thank You to Pope For This Useful Post:
 Old 08-07-2012, 12:11 PM   #36
snailD's Avatar
well if you can't handle it here there is another forum that will be a lot more kind to you, mazdas247.
with that said finkle didn't say it was going to blow up, but the computer doesn't read engine knock past 5,750 which if something was wrong with your car, your engine wouldnt be able to protect itself up there. also there is no point going to redline if there is no power at redline.... why not shift just after 5500 where the power drops off?
wait, i just read you didn't buy a speed yet. maybe you shouldnt then?
The Following User Says Thank You to snailD For This Useful Post:
 Old 08-07-2012, 12:28 PM   #37
Groans: 398
Well aren't you just a little bitch...
The Following 2 Users Say Thank You to captain slow For This Useful Post:
3Gee Tee (08-07-2012), Voltron (08-07-2012)
 Old 08-07-2012, 12:49 PM   #38
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
My Vtak engages at 5500. Wassup. And then if I dont let off, at 9k I flip into the backseat from all the powa.
The Following 2 Users Say Thank You to Voltron For This Useful Post:
3Gee Tee (08-07-2012), rfinkle2 (08-10-2012)
 Old 08-07-2012, 12:52 PM   #39
3Gee Tee's Avatar
^ Lol I miss my 8600 rpm redline too.
But I prefer torque.
 Old 08-07-2012, 12:53 PM   #40
Voltron's Avatar
Groans: 77
Sweet. One less idiot Pu owner out there.
Lets see some pics of white Genpus 2010_MS3 Gen2 MS3 General Discussion 22 10-06-2011 08:59 PM
occ - gen1's genpus miatas whatever phillyb Mazdaspeed3/6 General Discussion 1 05-06-2011 05:59 AM
Genpus, MSF calendar photo submission thread bnoon Gen2 MS3 General Discussion 0 04-17-2011 10:33 AM
Page generated in 0.61975 seconds with 48 queries
