Like Tree5Likes
 Old 02-13-2013, 07:57 AM   #41
90210's Avatar
Posts: 271   (View Stats)
90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world
Originally Posted by beachshoer View Post
I win. Just rolled 110000 TODAY. Yes 110k miles. Bought new with two miles Nov 09.
36666 miles a year!
Are you the highest mileage gen pu on the forum ?
Aside from the transmission issue mentioned above, any other issues you guys are seeing, out of the normal maintenance realm ?
90210 is offline   Reply With Quote
 Old 02-13-2013, 08:11 AM   #42
beachshoer's Avatar
Posts: 2,039   (View Stats)
beachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the world
I gotta be. Just rolled 116k miles this week. I know there's a couple right behind me though.
Still no maintenance issues. I did break a seat bracket recently though. But that's cause of my fat ass and G's I put on it when racing. Just a random tack broke on the bracket.
2010 BM MS3
BNR S3
HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs
H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines
Works emotions cr-kai 18x7.5 ventus v12s for the street
TRM C3s 17x9 Hankook RS3s for track days
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
ETS TMIC JBR RSB JBR SSP JBR knob AT internals
1999 Miata
gtx2867 1.9L VVT built like a brick shithouse
2001 Miata LS
RB FSB Hawk HP+ pads Dunlop ZII
beachshoer is offline   Reply With Quote
 Old 02-13-2013, 08:25 AM   #43
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
Got mine august 2011 and just hit 42,000
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 02-13-2013, 10:05 AM   #44
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
I'm still on track to do 20k a year, over 5k on it since I got it in October with 13k
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
 Old 02-13-2013, 10:19 AM   #45
90210's Avatar
Thank you kindly for the quick response. I would like to keep mine till Gen Three MS3 comes out.
 Old 02-17-2013, 03:35 PM   #46
wirechaser83's Avatar
Posts: 5   (View Stats)
wirechaser83 will become famous soon enoughwirechaser83 will become famous soon enough
Originally Posted by Boatcop1 View Post
So I bought my MS3 this past Feb and tomorrow I will be rolling over 16,000 miles! There was a few lengthy trips in there but mostly it's my commute to work, 55 miles each way literally ALL highway! I live 2 miles from Interstate 95 and work 5 min off I95. Adds up to 500 miles a week! I change the oil every 4-5k with Rotella T6.
I'm about to start modding as you can see in my sig. Am I shooting myself in the foot or will I be good to go with the DI engine? I'm going to install an OCC and EGR delete to help preserve the valves.
I don't know if it matters but I typically just set the cruise at 75-77 mph. My car Truely is an all highway milage car. Looking for any advice from any of the tuners on here about anything else I can do to keep the car running long and healthy.
I will be at this job for 2 more years so it's safe to assume I will be around 45k miles by then and fully bolted.
Thanks for any input.
I drive 48 miles on my highway commute to work every day. I would get another beater vehicle to drive, but this car is just too darn fun to drive! I am in the same boat as you with no mods yet. Post what you do to it in the future.
wirechaser83 is offline   Reply With Quote
 Old 02-22-2013, 01:10 PM   #47
jseams's Avatar
Posts: 1,414   (View Stats)
I've had my car going on 8 months now and just broke 4100 miles... =p
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
 Old 02-22-2013, 01:21 PM   #48
The Nut's Avatar
Posts: 1,571   (View Stats)
The Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the world
Groaned at 38 Times in 20 Posts
I'm a few weeks away from my 1 yr. mark and I just rolled 8,000 miles. And that's with the 1000 miles I put on it on my honeymoon. If the price of gas would calm the fuck down I might be more inclined to do some more late night cruises and day trips. I really need to get some tuning done and lean out my fuel trims. I know I'm wasting the fuck out of some gas....so, thanks for putting up with my random rant.
2012 BLACK MICA w/TECH
Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches
Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18
Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob
Stereo: Full Custom Mobile Audio/Video Entertainment System
91 & Corn diagnostics by:
The Nut is offline   Reply With Quote
 Old 02-22-2013, 01:25 PM   #49
zatara's Avatar
Posts: 1,505   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
just broke 25,000 miles and I've had the car since November 2010...
2010 Mazdaspeed 3 Black Mica
CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB
Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear
zatara is offline   Reply With Quote
 Old 02-22-2013, 01:32 PM   #50
blueridgerider's Avatar
Posts: 3   (View Stats)
blueridgerider is an unknown quantity at this point
I have about an 80 mile (roundtrip) commute up the mountain in the morning and down the mountain in the evening. I will not put near that many miles on the car though. Lots of the winter I drive my 4WD and lots of the good weather I split between the car and my motorcycle.
blueridgerider is offline   Reply With Quote
 Old 02-22-2013, 01:42 PM   #51
zatara's Avatar
I just work from home, so there is no commute for me except from my bedroom to my office. If I didn't drive back and forth between NYC and Maine every couple of months I'd probably have a lot less in terms of miles too.
 Old 02-22-2013, 06:46 PM   #52
Limeybastard's Avatar
Posts: 578   (View Stats)
7.7k miles bought in November 2012. Average 25k if not more a year. Will trade up when at 75k probably and get and STi. Lol zoids.
2013 W/tech
 Old 02-23-2013, 08:40 AM   #53
L3THAL6's Avatar
Posts: 168   (View Stats)
L3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the world
Groaned at 6 Times in 1 Post
I bought my car on Jan 26 2013, as of today I have 2950 miles.
113.5 miles per day which adds up to 42,000 miles per year D=
I have been taking a lot of trips recently though, normally I don't drive this much.
L3THAL6 is offline   Reply With Quote
 Old 02-23-2013, 10:49 AM   #54
90210's Avatar
Nice. Mikeasge should be seen as a badge of honor. 3 weeks I have driven 1550 miles.
I bought mine Jan 29,2013
 Old 11-07-2013, 06:51 PM   #55
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
got mine 27th of October of this year. at 3300 miles. so looks like I'll be at about 36k a year. anyone notice a drop in gas mileage after using t6?
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
 Old 11-09-2013, 08:02 AM   #56
Switters's Avatar
Posts: 126   (View Stats)
Switters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond repute
Got mine in March, just rolled over 10,500. I've started to drive the wife's car though, 05 RSX auto, 30 mpg.
13 BM MS3 Tech-current
JBR
07 CBM MS3 GT-traded
JBRTRMotorsportCorksportHTPTRZDashhawk
fierce invalids home from hot climates.
Switters is offline   Reply With Quote
 Old 11-09-2013, 10:53 AM   #57
El_Diablo's Avatar
Groans: 769
I ended up doing 18k in a year. My driving ended up decreasing somewhat.
If you figure an average speed of 38mph which is what my screen typically lands on thats over 470 hours that I spent in my car last year or over 19 and a half days! Jeez....
 Old 11-09-2013, 02:59 PM   #58
BigBoostMS3's Avatar
Posts: 1,429   (View Stats)
BigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the worldBigBoostMS3 is the leader of the world
I've put 30k on my car since march of this year... been driving a ton commuting to school.
Scott
Mazda Dragon Camp - Event Coordinator
// PTE 5858 // FREEKbuilt & tuned \\ M-1 Meth\\
www.TorqueSteerStickers.com
BigBoostMS3 is offline   Reply With Quote
 Old 11-13-2013, 04:59 PM   #59
Rallyer222's Avatar
Posts: 164   (View Stats)
Rallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud ofRallyer222 has much to be proud of
you guys make me feel good about my 2k miles a month
Rallyer222 is offline   Reply With Quote
 Old 11-13-2013, 08:03 PM   #60
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Purchased 8/2012 with 25k miles. Sitting at 78.9k now
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following User Says Thank You to sho For This Useful Post:
El_Diablo (11-14-2013)
 Old 11-13-2013, 09:17 PM   #61
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Bought myne feb 2012 with 62k and im at 104k now lol now even 2 years with the car
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
Koke382 is offline   Reply With Quote
 Old 11-13-2013, 09:35 PM   #62
budzinski's Avatar
Posts: 274   (View Stats)
budzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the worldbudzinski is the leader of the world
Wow y'all do some serious driving.. Mines 4 months and just broke 1700 miles.. Got it with 90 miles from another city dealer trade.. Guess working less then a mile from work helps a lot lol
2014 mustang gt with recaros and track pack
2013 cwp speed 3 w/ tech (sold)
2012 mustang gt premium(sold)
2011 wrx base(sold)
budzinski is offline   Reply With Quote
The Following User Says Thank You to budzinski For This Useful Post:
Koke382 (11-13-2013)
 Old 11-13-2013, 10:11 PM   #63
ThatGuy's Avatar
Posts: 153   (View Stats)
ThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond repute
Default God damn do I put on some mileage!!
sent from my peepee
Damn!!!! I thought I was bad. Bought mine in august with 25 miles and I'm at 6k right now!
Well, how have those miles treated you? Any serious issues or all mods and maintenance?
I'm impressed
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
ThatGuy is offline   Reply With Quote
 Old 11-14-2013, 06:49 AM   #64
El_Diablo's Avatar
Groans: 769
I love the low mileage guys because that just means I'll still be able to find a low mileage car if I ever want another MS3 or an MS6, lol.
The Following 2 Users Say Thank You to El_Diablo For This Useful Post:
budzinski (11-14-2013), ThatGuy (11-14-2013)
 Old 11-14-2013, 07:05 AM   #65
Cujo's Avatar
Posts: 1,192   (View Stats)
Cujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the world
Groaned at 6 Times in 4 Posts
@beachshoer what are you at now?
2012 Mazdaspeed3 Black Mica
Cobb AP // Stratified S-OTS+ Stage 2 Tune // Autotech Internals // CorkSport 3" Intake // CX Racing FMIC // NGK Iridium One Step Colder Plugs // JBR Throttle Body Gasket Kit & Coolant Bypass // SURE Return (w/ Dremel mod) // GFB Respons BOV // UR V2 Metal Catted DP // SURE Flow M3 // UR Catback Exhaust // StopTech Front Slotted Rotors + Performance Brake Pads // TWM Phantom Shift Knob // TWM Leather Shift Boot // CorkSport Adjustable Shortshifter // SURE Anchors // Tanabe NF210 Springs // JBR Tru-Torsion.125 Rear Sway Bar // Tanabe Sustec Tower Strut Bar // Tanabe Sustec Front Under Brace // JBR 88a RMM // Rally Armor Mudflaps // CorkSport Hood Scoop // CorkSport Battery Box // CorkSport LED Light Kit // CorkSport LED Fogs // GTA Car Kits iPod Adapter // Weathertech Floor Mats // Motorcraft Unicorn Tranny Juice // Pentosin Super DOT 4 Brake Fluid // Purple Effect Stock Rims // Falken Ziex ZE 329 // Plastidip'd Fog Light Bezels
Waiting for install: StopTech Rear Slotted Rotors + Performance Brake Pads, StopTech SS Brake Lines
Soon: Custom Tune by Stratified // Guardian Angel // BT, CorkSport Puppy or BNRs3???
Cujo is offline   Reply With Quote
 Old 11-14-2013, 07:08 AM   #66
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Bought mine April 31st with 300 miles, passed 20k on my way home last night...stupid 50 miles commute.
daafisch is offline   Reply With Quote
 Old 11-14-2013, 07:14 AM   #67
usgiorgi's Avatar
Posts: 649   (View Stats)
usgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the world
Groaned at 44 Times in 10 Posts
I did 17.5K last year. However that's down from 32K a year I was doing past few years from commuting to work and school. 50miles each way. I did 10k miles in a little over 2 months with my volvo.
2009 Nissan 370Z. Turbo and BOV sounds made by the driver via mouth.
SOLD: 2011 Speed3. Black mica w/tech package Cobb SRI, COBB AP, AT internals, OBX racepipe, Corksport RMM, LOUDASS STRAIGHTPIPE CPE TIP
usgiorgi is offline   Reply With Quote
 Old 11-14-2013, 07:19 PM   #68
beachshoer's Avatar
Will be rolling 140k miles sometime Sat.
Suck it bitches. Highest mileage PU in the world.
2010 BM MS3
BNR S3
STRATIFIED TUNED
1999 Miata
2001 Miata LS
The Following User Says Thank You to beachshoer For This Useful Post:
Cujo (11-14-2013)
 Old 11-15-2013, 06:18 AM   #69
Dat8687's Avatar
Posts: 257   (View Stats)
Dat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond repute
Groaned at 60 Times in 22 Posts
Holy skittlez... The most I put on a car is about 8-10k a year. I look at resale first and foremost if Im gonna be using a car to drive everywhere its gonna be a beater not something I plan on getting rid of later
Dat8687 is offline   Reply With Quote
 Old 11-16-2013, 07:52 PM   #70
Koke382's Avatar
Groans: 32
I don't plan on reselling ive put too much effort into my car to sell. Plan to be an old man boostin in an old ms3
sent from my peepee
1993 Red Na6
 Old 11-16-2013, 08:00 PM   #71
Erick13Speed3's Avatar
Posts: 353   (View Stats)
Erick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the world
Had mine a little over a month, about to hit 2000 miles. Bought it with about 300 miles on it, trying to slow it down a bit though
Erick13Speed3 is offline   Reply With Quote
 Old 11-22-2013, 04:53 AM   #72
PUGENE's Avatar
Posts: 1,902   (View Stats)
Groans: 61
Rolled 40k a week or two ago...bought it in March of 2012 w/ 13.5k miles.
Precision: PTE 5858
Tial: 44mm EWG
CPE: Stage 2 RMM//Manifold
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
POWERED BY PURPLE DRANK
PUGENE is offline   Reply With Quote
Damn! 9900rpm Drag Racing 45 06-27-2011 05:29 PM
Page generated in 0.48784 seconds with 44 queries
