Notices
 Old 09-24-2012, 08:17 AM   #1
hypercar's Avatar
Posts: 3   (View Stats)
hypercar is an unknown quantity at this point
Default Groaning noise when going slow - ideas?
Hi, I'm looking for some advise regarding my new 2012 speed3. It sometimes groans quite loudly when I'm going slowly - pulling into a parking stall, going through a drive through line, pulling into my garage, stop and go traffic. All I can tell is it comes from the front of the car and when it comes on it can be quite loud (it happened with a passenger in the car while pulling into a parking stall and they thought I'd scrapped up against the car next to us). It sounds like metal on metal, like something is turning but sure doesn't want to! I've tried to capture it on video but it's completely random. In gear, out of gear, cluth in, clutch out, on the brakes, off the brakes, turning, going straight...I never know when it's goint to appear but it's usually a couple times every trip. I will be coasting up to a stop sign and grroooaaann. Then I'll get to the next 10 stop signs/red lights and nothing. I went for a ride with my dealer's shop foreman to try and have him hear it but of course it wouldn't make the sound with him in the car and without hearing it he wasn't sure where to start looking and has asked me to give it a another 1000kms or so and see what happens. Any thoughts would be appreciated.
hypercar is offline   Reply With Quote
 Old 09-24-2012, 08:24 AM   #2
Pseud0logik's Avatar
Posts: 2,010   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groans: 76
Groaned at 31 Times in 28 Posts
This might sound elementary, but have you checked to make sure your lug nuts are tight?
Pseud0logik is offline   Reply With Quote
 Old 09-24-2012, 09:11 AM   #3
indiscretion
leon78's Avatar
Posts: 1,906   (View Stats)
Groaned at 22 Times in 15 Posts
Open hood and make sure all the heat shields are tight....jack car up and make sure every thing you can get your hands on is tight.
2013 Scion FR-S (Whiteout)
White 17x9 Rota Grids w/ 245's_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP.
leon78 is online now   Reply With Quote
 Old 09-24-2012, 09:21 AM   #4
manilaMS12's Avatar
Posts: 951   (View Stats)
manilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the worldmanilaMS12 is the leader of the world
Groaned at 17 Times in 11 Posts
The car is groaning at you because it wants to go moar fast
'12 MS3 Black Mica w/ Tech
Power: COBB AP > HTP 3.5" > ATP DP (CATLESS) > AUTOTECH INTERNALS > GFB RESPONS > NGK PLUGS
OTHER: JBR 88DURO RMM > SSP >BUSHINGS > KNOB > RSB
VOODOO TOON in progress (Thanks to fortressofcomfort)
manilaMS12 is offline   Reply With Quote
The Following 4 Users Say Thank You to manilaMS12 For This Useful Post:
fortressofcomfort (09-25-2012), GunGuru727 (09-24-2012), Koke382 (01-07-2013), SarcasticOne (09-25-2012)
 Old 09-24-2012, 09:30 AM   #5
MazdaBoy2.3's Avatar
Posts: 2,248   (View Stats)
MazdaBoy2.3 has disabled reputation
Maybe the plastic of the inner wheel well was knocked loose.
2010 Black Mica
Corksport: RP, SRI/TIP, Cold Airbox, RMM Inserts, Mudflaps
JBR: SSP & Bushings
SURE: Boost Tubes
COBB: Accessport
Other: AT Internals, 35% Tint, DDM 6k HID, NGK Plugs
My car is being rfinkle(d) with! VD: 263hp/319tq
MazdaBoy2.3 is offline   Reply With Quote
 Old 09-24-2012, 12:58 PM   #6
edubs978's Avatar
Posts: 36   (View Stats)
edubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond reputeedubs978 has a reputation beyond repute
OP It could be your Limited Slip Diff making some groaning noises. Ever since the weather has been getting cooler in New England and I switched to Motorcraft fluid I can hear my diff when making low speed turns.
Post a video and I'll confirm if its the same groan. If it is its nothing to be worried about.
2011 Black Mica MS3 - JBR 88 (cause my wife loves the vibrations), MTX-75 Fluid, DDM 5k HID's
edubs978 is offline   Reply With Quote
 Old 09-24-2012, 02:31 PM   #7
BlackBandit's Avatar
Posts: 179   (View Stats)
BlackBandit has disabled reputation
Hub bearing maybe?
2010 Black Mica - Tech Package
Corksport: SRI/TIP - TMIC - RMM - SSP and Bushings - Led Conversions inside and out - DP - Coilovers- Rear Camber Arms
Denso: ITV+22 Plugs
Stratified - EBCS - E-tune.
Cobb: AP
Custom 3" CBE
Autotech: HPFP Internals
Drag: Bronze DR31 18x8 +48
Toyo Proxes T1-Sport 245/35/18
Awating Install: - CS RSB - Front and Rear adjustable End Links
BlackBandit is offline   Reply With Quote
 Old 09-24-2012, 02:35 PM   #8
Spoofmastafly's Avatar
Posts: 1,289   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Is the car stock? Have you done any work to it yourself?
Spoofmastafly is online now   Reply With Quote
 Old 09-24-2012, 02:35 PM   #9
hypercar's Avatar
Thanks for the replies. I will tighten what I can get my hands on. I've been trying to record the noise on video for weeks without success. The car will do it's groan thing and if it's possible I whip out my phone and try and replicate exactly what I just did, but the groan will be gone! I'm also going to try bedding in the brakes (I hope that's the right term, read about it in a brake issue thread) as the car only has 1100 kms on it. Although the car will make the noise when I'm not even using the brakes I guess it can't hurt.
 Old 09-24-2012, 02:49 PM   #10
hypercar's Avatar
Can I ask another favor forum members? If the car continues to make this noise I am going to ask the dealership to take a look at it when I bring it in for the first oil change which I plan to do early anyway. But I know nothing about cars (literally, nothing). What is a reasonable level of inspection for me to ask of the dealer given I can't replicate the noise for them? Can I say, 'Can you see if everything is ok with the brakes?' or 'Can you take a look at the wheel bearings?'. I've read the LSD can get noisy but what would the dealership do to inspect it?
What would you guys ask them to do? Where would you start?
My dealership seems pretty willing to help. As I said the foreman was more than willing to take a ride with me but I couldn't replicate the sound in 30 minutes of driving with him (figures, right?!). I'd just like to sound a little educated befor I bring it in!
 Old 09-24-2012, 08:04 PM   #11
embibb's Avatar
Posts: 53   (View Stats)
embibb is just really niceembibb is just really niceembibb is just really niceembibb is just really niceembibb is just really nice
Groaned at 4 Times in 1 Post
I had the same experience and it turned out to be front wheel bearings.
[SIGPIC][/SIGPIC]2012 Pearl Wht with Tech, 2002 PR5 with history...
Cobb TIH, SRI,Atech HPFP, JBR heavy shift knob, JBR RMM, Sola Roof Rack, Ceramic Tint, ClearBra
embibb is offline   Reply With Quote
 Old 09-24-2012, 09:21 PM   #12
CornBread's Avatar
Posts: 112   (View Stats)
CornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond reputeCornBread has a reputation beyond repute
Groaned at 17 Times in 7 Posts
front brakes? if you touch the pedal harder does it quit?
could be brake dust causing the groan
mine does it too. 2012 with 6k on the clock. think it is narrowed to brakes
CornBread is online now   Reply With Quote
 Old 09-25-2012, 12:42 AM   #13
desertmike680's Avatar
Posts: 64   (View Stats)
desertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to beholddesertmike680 is a splendid one to behold
Groaned at 44 Times in 12 Posts
Mine does the same thing. I've narrowed it down to brakes more or less. My 2012 currently has 13k on it (bought it last Oct), and when you give it gas and let your foot off of the accelerator, it constantly squeaks when the clutch is engaged and the engine shifts back and forth. I took it to the dealer and guess what they said....unable to duplicate issue. Imagine that. I'm not even going to bother taking my car to the dealer. Not worth my time.
2012 Velocity Red with Tech/Sure SRI/Sure TIP/Forge BPV/(Not sure what the hell I'm moding next, might spend money on hookers instead)
desertmike680 is offline   Reply With Quote
 Old 09-25-2012, 12:47 AM   #14
snailD's Avatar
Posts: 2,026   (View Stats)
i think i know exactly what your talking about. its almost like a metal dragging sound? this happened to me a few times when i first bought the car, then went away and i forgot about it. it just happened at the track in front of an official the other day and they thought my car was broken. i stopped and inched forward and the noise was gone.
i was told its probably a little pebble getting stuck and said fuck it. i havent crashed yet
GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22
EBAY DP wCAT/ CP-E RMM 75D/ HKS BPV/CP-E FP
COBB EBCS/ PG FMIC/ TR8 CORE
13.2 @113.6 @ 4500ft ASL [443/409]SAE CORRECTED
snailD is online now   Reply With Quote
 Old 09-25-2012, 04:40 AM   #15
gearhead750's Avatar
Posts: 387   (View Stats)
gearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the world
Groans: 30
I was going to start a thread on this today, but I searched and found this. Within the past few days my 2012 is making the same noise. It's coming from the front drivers side wheel and only happens intermittently. It's fairly loud and sounds like two empty coffee cans clanging together. It's driving me absolutely fucking nuts. It does sound like a loose heat shield, but I've checked everything I can get my hands on and can't find anything loose. Someone make it go away please.
Thanks 4G63 for the avatar!!!
Originally Posted by DarkHeartMS6 View Post
I didnt think there was a person on this planet as stupid as you... Congratulations, you proved me wrong. WTF is a Mazda RX-7 if not one of the best "tuner" cars as you put it.. out there. Jump off the honda dick, pull the Golf R cock out of your mouth... replace it with a gun and end this world of your stupidity! Please, before you cause a retard apocolyptic end to our world
gearhead750 is offline   Reply With Quote
 Old 09-25-2012, 04:48 AM   #16
Mr. Skin of MSF
Darth_Nuruodo's Avatar
Posts: 1,499   (View Stats)
Groans: 69
Groaned at 25 Times in 19 Posts
I can't help with the problem, I just wanted to say you're doing it right.
2012 LSM Mazdaspeed 3
Cobb AP -- JBR Adjustable SSP and Counterweight -- 3" SRI + TIP -- gutted mid-pipe -- JBR 88duro Mount Trilogy -- Kozmic Motorsports EGR block-off -- Synaptic DV -- Magnaflow CBE -- DDM 55w 5000K low beams and 35w 12000K fogs
Donate brownie:
I love this place.
I'm convinced that when Jesus comes down from Heaven for the Rapture, the first thing he's going to do is donate $25 to become MSF VIP. Easiest way to know who to leave behind.
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
Darth_Nuruodo is online now   Reply With Quote
 Old 09-25-2012, 09:21 AM   #17
fortressofcomfort's Avatar
Posts: 867   (View Stats)
^^ this. I had a couple incidents where it sounded like metal on metal for a couple miles but went away and has not returned. When the car was pretty new. I'm almost sure it was the brake compound not playing nicely in that particular weather combination.
Loose lug nuts will sound like a helicopter at high speeds and possibly a clunk at low speeds. If its metal on metal sounding then I second (or third or fourth) the brakes and its ok. If it doesn't go away after oh say 10 miles of driving then I would get it looked at.
2012 Black Mica MazdaSpeed3
Street creds:
 Old 09-25-2012, 12:05 PM   #18
Mclovin80's Avatar
Posts: 232   (View Stats)
Mclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the world
What about the power steering pump? My 2007 Sierra used to wine at low speeds especially on cold mornings until I flushed and replaced the power steering fluid.
Mclovin80 is online now   Reply With Quote
 Old 09-25-2012, 12:14 PM   #19
TRex's Avatar
Posts: 3,048   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 102 Times in 66 Posts
gen ones have a pretty well documented case of rattle coming from the tensioner pulley (located on the passenger side of the engine)
look it up
rattle should increase slightly with rpms or blipping the throttle, try it out in the garage for the easiest way to hear it
TRex is offline   Reply With Quote
The Following User Says Thank You to TRex For This Useful Post:
 Old 09-29-2012, 09:37 AM   #20
BeeZaa's Avatar
Posts: 257   (View Stats)
BeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the world
I have this same EXACT issue. It's just as you describe it, doesn't happen all the time, but when it does it sounds terrible. I first suspected it to be a wheel bearing, but I need new brakes and rotors so now Im just hoping its that. I am gonna change those next week. Please someone update this thread if you figure it out.
2010 Mazdaspeed 3 Black Mica - Evo X Wheels(Enkei's 18x8.5 +38) - H&R Springs - CS SRI - CS TIP - CNT DP - ETS TMIC - Turbosmart BPV - KMD Internals - Gen2 Cobb AP(Using ATR) - TRZ Dogbone Delrin RMM - 5k HID low beams - E4 Shift Knob - Jbarone Shifter Bushings - Ford Motorcraft Tranny Fluid - Rotella 5w40 Oil.
BeeZaa is online now   Reply With Quote
 Old 09-29-2012, 10:16 AM   #21
Groans: 30
I think it's the heat shield behind the rotor. I pushed in on mine and it made the same sound I've been hearing when I went over bumps (sometimes) It made a little click when I pushed on it some more, like it went into place or something. No more sound and it's not loose at all. Maybe something (like a pebble mentioned above) got caught up in there. Who knows.
 Old 09-30-2012, 01:46 PM   #22
PokeyHokie's Avatar
Posts: 49   (View Stats)
PokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud ofPokeyHokie has much to be proud of
THIS. A got a rock between the shield and rotor when the car had 200 miles on it -- I almost shit my fucking pants. Sounded just like what OP's describing. I pulled over and beat on the shield with the back of a screwdriver and a rock fell out and the sound has never happened again.
PokeyHokie is offline   Reply With Quote
 Old 01-07-2013, 02:28 PM   #23
rtekkam's Avatar
Posts: 92   (View Stats)
rtekkam is a name known to allrtekkam is a name known to allrtekkam is a name known to allrtekkam is a name known to allrtekkam is a name known to allrtekkam is a name known to all
Default Bearings
Not sure the noise you are referring to is during low speed when turning left/right or reversing with the wheel turned left/right. I had this noise for a while.took it in today. Mazda dealer of course could not replicate the noise..so one day i drove it for an hour and when the noise was apparent had the technician drive in with me..he had no idea about the noise. So when you do get the noise take it in and have them hear it.
it only is apparent (when after driving for like 1/2 hr). today the delaler did that and replicated the noise. they called Mazda and apparently this is a known issue is is a wheel bearing issue. This is covered by the powertrain warranty. New parts to be installed.
rtekkam is offline   Reply With Quote
 Old 01-07-2013, 02:52 PM   #24
Rkrise216's Avatar
Posts: 174   (View Stats)
Rkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the world
The genpu has a very noise power steering pump could me that.
Rkrise216 is offline   Reply With Quote
 Old 01-07-2013, 02:55 PM   #25
Ambush Predator
Yatta's Avatar
Posts: 540   (View Stats)
Yatta has disabled reputation
Had groaning on my new 12 pu, it was around 15-25 mph, a slight pull left or right on the wheel would increase it sometimes, application of brakes would stop it, turned out to be a rock (small) stuck in the left front caliper, when the rotor got hot it would rub... as it was one day new I took it to the dealership, they also were a bit astonished at the noise (raced many, never heard this before) but happy/pleased when they found the rock..
odds are funny but I had another noise come from my better halves audi, it was a rock between dust shield and rotor....
Colorado winter driving I suppose.
 Old 01-07-2013, 05:13 PM   #26
GunGuru727's Avatar
Posts: 3,009   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 33
Well sometimes, I have to slow down and I happen to make a groaning noise or I may last all of 5min.
Does this help?
2011 Mustang SVT GT500
Steeda Pulley - Steeda Belt Tensioner - Steeda Axel-Back Exhaust
K&N Air Filter - MGW Shifter Assembly - Lowering Springs - SteedaTune
Ford Racing Strut Tower Brace
2010 NASA Space Shuttle Silver GenPu
E85FreekTune
EWG GTX3071r - 401HP/386TRQ SAE
K04 - 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 01-07-2013, 05:22 PM   #27
himurax13's Avatar
Posts: 2,189   (View Stats)
Groans: 34
Sweet Jesus, I was getting ready to post something about this. I just recently replaced my front swaybar bushing and one of my strut bearings do to other noises. This one has eluded me as well.
Ohnononono pinoyboi.
Listen my adobo cooking friend. You will move to NJ. I shall take you under my wing. You will void that warranty. Your wife will be very upset with you that you spend every Tuesday night with us, and you use all your extra monies to buy all the parts I shall find for you. You will sushi roll and ffs up and down the GSP with us. You will end up on YouTube and in the street racing videos. And last, but not least, you will allow us access to employee pricing on all parts thru your dealership.
Are you sure you still want to come to NJ? We go hard here.....be warned.
I too once was a naive ayshun with a stock pu. Then I met these fuckers. My wife hates me now Tuesday nights. My neighbors hate my car for the uber cool cold start. My garage is a fucking mess. My warranty went out the window. My life has not been the same since April. I should have bought a Mazda2.
himurax13 is online now   Reply With Quote
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 06:32 PM
Front end groaning/warranty work cesaros Gen2 MS3 General Discussion 21 03-27-2012 05:09 AM
Just some ideas forcedinduktion 2010 MS3 - Wheels & Tires 1 02-27-2011 04:09 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 04:00 PM
Page generated in 0.47631 seconds with 43 queries
