-   -   gutted dp or catless? (http://www.mazdaspeedforums.org/forum/f544/gutted-downpipe-catless-84038/)
bmannn 06-22-2011 08:57 AM
I have good fuel pressure . always over 1600 at wot. I live in nj. so like the idea of looking like I have a cat. Can I just gut the stock down pipe? would I see any gains? or should I just get a replacment catless dp?
I do plan on a corksport top mount , ap , and hpfp .
03scgt 06-22-2011 08:59 AM
http://www.mazdaspeedforums.org/foru...ownpipe-48370/
mghtymouse380 06-22-2011 09:24 AM
Go catless. I have the EBAY 3" and it is a solid piece. And it makes the exhaust sound awesome. Less than $200. Highly recommend it.
JacksonMS30 06-22-2011 09:26 AM
I have been rocking the nator style downpipe for nearly a year with no problems.
adlpb 06-22-2011 09:28 AM
I'm pretty sure any catless DP will give you CEL's on a Gen2. Gen1's can run catless all day and have no issues. According to the CS and UR, the gains are minimal (2-3 hp). Also, you don't have to deal with the smell. It is louder though, so if you like that, CEL's and the smell go for it. Otherwise, go catted (Cobb, cp-e, or UR...CS catted DP still triggers CEL).
JacksonMS30 06-22-2011 09:30 AM
You won't get a cel if you use the sparkplug non foulers for the rear O2 sensor. I have had a gutted stock downpipe on for nearly a year and have yet to get a cel with the non foulers in place. And no I'm not just defeating it with the AP.
I will eventually get a true downpipe though as it will be better flowing because of the larger diameter.
Monotonous ONE 06-22-2011 09:33 AM
either option is cool
personally id go catless 3 inch
but if your on a budget...gut that shit...theres some serious gains to be had.
9900rpm 06-22-2011 09:48 AM
Don't gut it. You will eventually need it for inspection. I know NJ is like 4 or 5 years, but still. Also, when you sell the car, it will be hard to sell if you don't have a cat to go with it, and them shits are expensive, even used. You may be saving money now, but come later, you're fucked.
Catless FTW. If the CEL bothers you then you shouldn't be modding the car anyway. Catless is good because if you decide on running race gas later, you can.
specvspeedfreak 06-22-2011 09:55 AM
im going gutted after internals.. I have oem cat from my gen1 laying around...i probably wouldn't do it if that wasn't the case..
bmannn 06-22-2011 11:14 AM
I dont care about cel. I have an egr code from delete anyway. thanks for the info. I will just go catless dp. and save the factory dp for inspection
Page generated in 0.17192 seconds with 11 queries
