 Old 02-17-2014, 12:44 AM   #1
Ms32013's Avatar
Posts: 2   (View Stats)
Ms32013 is an unknown quantity at this point
Default H&R Springs
I just installed the H&R lowering spring set. (Bought just the coils) My rear is lower than the front. Did self install and got it aligned right after and everything is pretty good except for the front being 3/4 in higher than the rear. Anything that I can do to fix it?
-Corey
Ms32013 is offline   Reply With Quote
 Old 02-17-2014, 05:14 AM   #2
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world
nope. that's how they are
1996 Miata
SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs.
SOLD: 2009 Mazda 6i GT. 6-Speed MT.
6Y MAZDA is offline   Reply With Quote
 Old 02-19-2014, 08:46 AM   #3
MS3G35's Avatar
Posts: 1,536   (View Stats)
MS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the world
Groans: 80
They will settle over time. Mine sits pretty level.
CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS
285whp/321wtq-93
E85 tune in progress
MS3G35 is offline   Reply With Quote
 Old 02-19-2014, 08:58 AM   #4
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
They are like that too level out the car. But in theory you would want the front a little lower than the rear imo. If you would've bought a used set it would take the gap out a little. I had the Same problem when I had h&r springs. Its a eye sore.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
 Old 02-19-2014, 12:08 PM   #5
swsmailman's Avatar
Posts: 1,118   (View Stats)
swsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the worldswsmailman is the leader of the world
Yea mine are the same way and have been installed for about 3 weeks or so about, they are looking more level though. So give it some time.
2013 Liquid Silver MazdaSpeed
Installed Parts:: HTP 3" SRI, Autotech Internals, CP-e Catless DP, CP-e TMIC, FreekTuned, H&R Springs, JBR RSB, Cobb AP V3, JBR 88 RMM, JBR Battery Box, EGR Delete, various CorkSport styling parts, and other things
Not Installed Parts:: JBR Stage 2 OCC
Future Parts:: JBR 80 PMM/TSM, Coilovers, and much more
swsmailman is offline   Reply With Quote
KONI Yellows w/ Cobb springs & stock springs Fobio MazdaSpeed 3/6 - Suspension & Brakes 9 08-20-2012 08:24 PM
h&r springs on the way tmmueller 2010 MS3 - Suspension & Brakes 15 11-24-2011 06:29 PM
H&R Springs V.S. Roadmagnet Springs michaeljp MazdaSpeed 3/6 - Suspension & Brakes 16 02-22-2010 09:07 AM
springs haskms3 MazdaSpeed 3/6 - Appearance 5 02-02-2010 12:32 AM
Page generated in 0.25620 seconds with 24 queries
