![]() | | #1 | ![]() |
![]() Join Date: Mar 2011 Location: Shawnee, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,101
Groans: 48
__________________ AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score When I get into work I will pull the tsb up for u. Sent from my Android using Forum Runner
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
Groans: 106
| Not Ranked : 0 score This is all that is said in the tsb about water or condensation in the head lamp. I my self have not dealt with this, so not sure what techline is making techs to do to confirm head lamp replacement. I just know that these things are not cheap around 800 bucks each and that is the non hid one's, Page 1 of 1 CONSUMER NOTICE : The information and instructions in this bulletin are intended for use by skilled technicians.Mazda technicians utilize the proper tools/equipment and take training to correctly and safely maintain Mazdavehicles. These instructions should not be performed by “do-it-yourselfers.” Customers should not assume this bulletin applies to their vehicle or that their vehicle will develop the described concern. To determine if the information applies,customers should contact their nearest authorized Mazda dealership. Mazda North American Op EXCESSIVE CONDENSATION OR WATER WITHIN THE HEADLAMP ASSEMBLY - CAUTION Bulletin No: 09-003/13 Last Issued: 03/04/2013 Service Bulletin Mazda North American Operations Irvine, CA 92618-2922 MULTI-MODEL - EXCESSIVE CONDENSATION OR WATER WITHIN THE HEADLAMP ASSEMBLY - CAUTION BULLETIN NOTE • This bulletin supersedes the previous bulletin 09-0 05/11 issued on 02/07/11. The APPLICABLE MODEL(S)/ VINS have been revised. • Changes are noted below in Red beside the change bar. APPLICABLE MODEL(S)/VINS DESCRIPTION When dealing with customer complaints of excessive condensation and/or water within the headlamp unit, first determine if all the bulb sockets are present and correctly installed. In mo st cases you will find that the Bulb Seal No. 1 (A) or HID Bulb Seal No. 1 (B) and Bulb Seal No. 2 (C) socket covers have not been correctly installed or are missing due to improper prior repairs (i.e., customer replacing the headlamp bulbs or body shop not transferring them when replacing the headlamp unit(s) due to a collision). Any damage caused by missing socket covers, HID module seal (D), or missing bumper brackets (E) is not covered by warranty policy
| The Following 2 Users Say Thank You to motherfnmonsta For This Useful Post: | Royer366 (03-04-2014), Stingray69 (08-14-2013) |
![]() | | #4 | ![]() |
Groans: 48
(Thread Starter) | Not Ranked : 0 score I have the HID headlamps so it must be north of $800. Talked to the service advisor today he was not aware of this procedure but basically said he has to go through the motions. Naturally I have not seen condensation in the light lately. I will post up what they say tomorrow. Thanks @motherfnmonsta;
![]() | | #5 | ![]() |
Groans: 106
The labor is not the expensive part on replacing head lamps, I can do those in my sleep it is just the cost of the housing, and here is the kicker, it is just the housing there is no harness, no ballast no bulbs or nothing.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 | |
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | Stingray69 (08-14-2013) |
![]() | | #6 | ![]() |
Groans: 48
(Thread Starter) | Not Ranked : 0 score Got car back from dealer. They did not replace the headlight. They claim that Mazda said a certain amount of condensation is normal. Supposedly if they turn the high beam on for 30 minutes and it goes away it is not a problem. I asked why if it is normal why don't both headlights have it. They did not have a good answer. Just like @motherfnmonsta; said, they are worried about not being payed for the headlight after they send it back to Mazda.
![]() | | #7 | ![]() |
![]() Join Date: Jul 2010 Location: Victoria B.C.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 20 Times in 14 Posts
__________________ 2008 MazdaSpeed 3 Exhaust - Mazdaspeed & Ebay Downpipe Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM Random - Pontiac G8 Horns 2013 Ford Edge Sport AWD, the family car... | |
![]() | | #8 | ![]() |
![]() Join Date: Jun 2012 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
| Not Ranked : 0 score Resurrecting from the dead lol. @motherfnmonsta; has been extremely helpful in the past about this. And he's right about the dealerships being super stingy on headlamp assemblies. Even the service manager that I'm practically drinking buddies with won't help me out with a headlamp condensation issue. It's on only one headlamp, and not the other. I got a new MS3 and the HID lamps seem to be sealed pretty frikin tight. They haven't been touched since I bought the car, and when I take in for a customer wash at my Mazda dealership, I noticed the condensation. It has never been a problem before, even with heavy rain. @motherfnmonsta; do you have any ideas for what to check? Where this water might be getting in through? I've left my lights on and it only steams up the light, it doesn't dry up the water. When it cools, the water is formed into large drops that run down the lamp. I would imagine this isn't the same as that misty condensation that some people might experience, right?
__________________ 2011 GenPu LSM w/ Tech Plague Stock until paid off - Because marriage *Turning Brownie is like being at the bottom of the caste system; you're an "untouchable".* |
![]() | | #9 | ![]() |
Groans: 106
| Not Ranked : 0 score Sounds like you got a leak some where. I would explain wat you just told us to the service manager and ask him to pour water over the headlamp like you ate washing the car to duplicate. I would also try and get corporate or the dsm involved to. sent while tapping that ass
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | BloodySpeed3 (10-30-2013) |
![]() | | #10 | ![]() |
Groans: 48
(Thread Starter) | Not Ranked : 0 score Good luck, I have gone round and round with the stealership and still have the problem. The best solution I have found is drive the car, you can't see it from the drivers seat. Good news, this is the only issue I have had at 40k. Bad news is they are not willing to acknowledge it is a problem or fix it.
![]() | | #11 | ![]() |
That really sucks.. mine just scratched 20k. I'm gonna give it a shot. I might be the lucky one, who knows :? If they do decide to fix/replace, I'll post here.
__________________ 2011 GenPu LSM w/ Tech Plague Stock until paid off - Because marriage *Turning Brownie is like being at the bottom of the caste system; you're an "untouchable".* | |
![]() | | #12 | ![]() |
![]() Join Date: Feb 2012 Location: Clark, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score I actually had the issue happen to me as well. 2010 ms3, first time i had the issue around 20k miles they said there wasn't enough condensation built up for them to replace. Luckily it just got a lot worse before my 3/36 expired and they did actually replace it. I work for Nissan and as far as Nissans go, they say a slight mist is normal. But if there is an actual drop it's deemed warrantable.
__________________ 2010 MS3 purchased 02/11/12 (11,9xx miles) II Headlight Armor yellow fogs II CS RMM insert II CS SRI/TIP II DDM HID Kit low beams 4300k II Plasti-dipped rear valence II Eibach prokit II OEM Rear bumper guard II OEM roof rack II Thule 44" fairing II Privat Akzent 18x8.5+40 II 235/40 Falken Ziex II UltraGauge II Cobb AccessPort II OBX test pipe II AT Fuel Pump Internals II HKS bov VTA II CP-E TMIC II ATP Long Downpipe II CS Shift Plate II Koni Yellows II Re-tune in progress! Engine oil : Rotella T6 Oil filter : Motorcraft |
| Headlight Condensation | Airman3454 | Gen2 MS3 General Discussion | 33 | 10-24-2015 09:10 AM |
| Video: Motor Trend goes head-to-head-to-head in Cadillac ATS 3.6, BMW 335i and Mercedes C350 Sport | Haltech | Automotive News | 1 | 11-25-2012 04:13 AM |
| Video: Chevy Corvette Z06 Centennial goes head-to-head with Cadillac CTS-V Coupe in Burnout Super Test | Haltech | Automotive News | 0 | 01-25-2012 01:30 PM |
| Headlight condensation | NvrSumR | Mazdaspeed3/6 General Discussion | 2 | 05-18-2011 08:55 AM |
| Detroits Best vs. the World in a Head-to-Head Test Drive | Haltech | Automotive News | 0 | 04-04-2011 05:00 AM |
