-   -   high elevation 1/4 mile (http://www.mazdaspeedforums.org/forum/f544/high-elevation-1-4-mile-189091/)
icee753 05-31-2015 05:32 PM
Hey guys I live in albuquerque new mexico, our track is about 5200 ft. I wonder what times some of you guys are getting at higher elevation? And what mods you've see. The biggest gains with? I have seen some stuff out there and done some research but it's all pretty old and not a whole lot of info. So far my best is only a 14.5 @ 98 mph :/ mods are rmm insert, hpfp, UR testpipe, Corksport sri and tip. Let's your times and traps
JgamB 05-31-2015 05:44 PM
Take a look here http://www.mazdaspeedforums.org/foru...mile-times-18/
Most entries have altitude or DA.
snailD 05-31-2015 05:49 PM
i did a 14.0 or 14.1 (can't remember which one) on pump gas and 13.6 on e85 in utah at 4500ft ASL. I had a Catless DP, CS intake/tip, res delete on the exhaust and fmic with tr8 core and tuned
icee753 05-31-2015 06:10 PM
Thanks I've seen this but only a small percentage are at high elevation
Was this on your stock turbo? I can't seem to get my dam 60' down :/
snailD 05-31-2015 10:09 PM
yes, with a 2.1-2.2 60ft i believe
PapaSmurf 06-01-2015 01:17 AM
I never ran stock turbo up here, but you will see .5-.7 tenths slower then sea level is what ive noticed.
The more power/bigger turbo you run the less of a difference you will see.
texasboy21 06-01-2015 08:48 AM
Are you tuned? With the amount of mods you'll need a tune to take full advantage of the upgrades. 14.5 is on par with a stock vehicle at sea level, do I would guess that the marginal gain you see by running your mods untuned, offsets the losses due to elevation.
Fwiw I ran a 14.6 at 99mph untuned with an intake.
2012 Mazda 3 Mazdaspeed3 1/4 mile Drag Racing timeslip specs 0-60 - DragTimes.com
Rich990 06-01-2015 10:03 AM
13.2 this weekend with the 6MPS. 10660ft DA, 4000ft actual altitude.
mods in my sig.
icee753 06-01-2015 04:05 PM
wow thats some great driving there! i may need some better tires. do you know what your trap was?
i do have a tune im pushing 19-20 psi what elevation are you at?
im confused it looks like you have 2 speed3's which was it?
mods in my sig.
icee753 06-01-2015 04:42 PM
here's my embarrassing slip :worried:
Rich990 06-05-2015 06:55 AM
It was my MS6.
Those 2x MS3's were my previous cars.
icee753 06-07-2015 12:00 PM
Originally Posted by Rich990 (Post 2892956)
It was my MS6.
O ok I'm looking for ms3 cars to compare thanks for the info though
snailD 06-07-2015 09:39 PM
i did this today. http://www.mazdaspeedforums.org/foru...ft-asl-189365/
icee753 06-08-2015 04:32 PM
Originally Posted by snailD (Post 2894584)
dam man good job with some E85 youll be close to 12's! what RPM is you LC set at? you could probably drop you pressure if you want better traction and launch hire for less wheel hop depending on what your launching on now
snailD 06-08-2015 05:40 PM
well its a hard sidewall tire so going to super low pressures wont help. i started at 3200 which is what i use for autocross, but i bogged, then i spun at 4000 then it was probably about right at 3800 but i had to let off a little because of wheel hop
icee753 06-08-2015 09:23 PM
What kind of tires are you running? Are you on stock suspension?
Page generated in 0.18356 seconds with 11 queries
