![]() | | #41 | ![]() |
![]() Join Date: May 2011 Location: Johannesburg, South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 783
| Not Ranked : 0 score
my flange reused the stock gasket. i had a recirc adapter on that i think may have caused it to leak in recirc mode. didnt like the lag and stumbling and backfiring in VTA, or the lag in recirc so I stocked out. might pop it back on when i get tuned later this year (if the stocker leaks).
__________________ 2007 Velocity Red MS6 Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads Parts stockpile... Wiseco 88mm's / Manley H beams Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04 Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth) Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust 5500 ft altitude FTL MSF in South Africa | |
![]() | | #42 | ![]() |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
(Thread Starter) | Not Ranked : 0 score I know this sounds expensive, but the CP-E recirc kit sounds much better. I have a full blown gasket on mine that works really well. It seems like what you had was a busted piece of shit
__________________ ![]() 2013 Lightening Red BRZ LMT Cosworth Filter Nameless Track Pipe |
| The Following User Says NO Thank You to darkrune For This Un-useful Post: | SofaKingAwesome (04-30-2012) |
![]() | | #44 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
oil catch can fuel pump internals!!!
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // | |
| The Following 4 Users Say Thank You to m4tic For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score Stock BPV until it leaks. no need to waste hundreds on a part to make some noises. Go get a honda.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score You know what, you are right. Preventive maintenance with a reputable company is just a waste and totally retarded. Especially since I am running 20lbs of boost. I wish you were a little man in my head. EDIT: P.S. FYHN
| The Following User Says NO Thank You to darkrune For This Un-useful Post: | faeker (04-30-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
| Not Ranked : 0 score I'm running 20.5 psi on stock bpv.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
| The Following User Says Thank You to bigriver For This Useful Post: | faeker (04-30-2012) |
![]() | | #49 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score What an awesome thread! Another worthless discussion about WHOOSH PSHHHH noises! Stock BPV holds a good bit. @phate has a thread on how to modify it to hold more. ANY of the aftermarket options work fine as well. I like my Forge V2 because it doesn't stand out in the engine bay and it has help up to 30 PSI on the K04 just fine. I associate the SSQV with rice because most people who buy it get it because they thought it sounded cool. This gay.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score If this us a good thread then why are you groaning me bucker?
| The Following 2 Users Say NO Thank You to darkrune For This Un-useful Post: | faeker (04-30-2012), SofaKingAwesome (04-30-2012) |
![]() | | #51 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score There, added a couple more for you.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER ![]() ![]() ![]() |
| The Following User Says NO Thank You to SofaKingAwesome For This Un-useful Post: | darkrune (04-30-2012) |
| HKS SSQV | Guati91 | MazdaSpeed 3/6 - Turbo Induction | 6 | 02-07-2011 11:48 PM |
| hks ssqv on recirc... backfire normal? rather dissapointing sound... | super_pablo_ | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 02-07-2010 10:55 PM |
