![]() | | #81 | ![]() |
![]() Join Date: Sep 2013 Location: Quebec
| Not Ranked : 0 score
I have tried the 330cc with 100% water, it was still droping bats without slowing down the car. i was using higher octane mix in the tank to be sure so this test may not be very accurate but i know 330cc won't flood the engine. At the end of the day, there is more than 1 road to higher horsepower. I like my injection kit but it could be better/safer and other may preffer it in the tank but it can be limited also...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
![]() | | #82 | ![]() |
![]() Join Date: Mar 2014 Location: Atlantic Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
(Thread Starter) | Not Ranked : 0 score In doing the WOT runs for the new tune, if the road is clear I just keep sailing through the gears. I'm noticing that the on board tach is way off. The difference between the AP (log) and tach readings seems to get wider at the top end of the higher gears ... by at least a few hundred points ... maybe more. Again, I'm just glancing at the tach at those speeds (and I certainly caught a load of crap for doing that with my initial post) but the on board tach looks like it's reading high by hundreds of RPMS.
__________________ Built |
![]() | | #83 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Yeah on my 2012 I don't hit the rev limiter (6700) until the needle is past 7000. I've been in other 2012+ Pu's that are the same way Sent from my A0001 using Tapatalk
__________________ 2007 Mazdaspeed3 GT |
| The Following User Says Thank You to MD1032 For This Useful Post: | BMC (10-22-2015) |
![]() | | #84 | ![]() |
Start looking at obd2 rpm first and then at the gage, the difference will be larger VS if you look at gage and then at the rpm...
![]() | | #85 | ![]() |
Groans: 111
With the factory programmed error in the tacho, and the factory 215/45/r18 tires for a gen1, 265Kmph on the tacho are about 250Kmph GPS speed which on normal tires it's basically the same as the OBD speed (tacho shows more for very specific reasons). And 250Kmph is 155mph. Once you start modding the top speed has two enemies: 1. heat. More power means more heat. In its factory form, a vehicle can go to its top speed (software limited like in our case, or not) slower therefore needing less power and thus generating less heat; 2. gearbox and the rev limit you can run. At 6700rpm in 6th the speed is about 280-283Kmph with the factory tires. If you increase the rev limit and remove both speed limiters you can go as fast as you can, assuming you're not running into cooling issues.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | BMC (10-22-2015) |
![]() | | #86 | ![]() |
"Start looking at obd2 rpm first and then at the gage, the difference will be larger VS if you look at gage and then at the rpm..." I also don't get how the order of viewing the two readouts will affect the spread. Feel free to explain. I'm here to learn. Thanks.
__________________ Built | |
![]() | | #87 | ![]() |
![]() | | #88 | ![]() |
| Not Ranked : 0 score not sure if you were talking only about RPM error between cluster tach and OBD RPM or RPM vs the car speed. In the first place, the RPM error from cluster to obd will always remain the same regardless of the gear because it read the engine crank speed before the transmission gears. OBD2 reading will be accurate and then transformed to an analog signal for the cluster gage needle. This is where the error comes from. Converter error + needle error. Then, if you use RPM to calculate a theoric car max speed, yes the error will be amplified by the gears ratio as the equation for speed is engine RPM x gear ratio x diff ratio x tires circonfférence. This is why you need to use the real 6700 rpm cut off from obd rpm not the cluster redline. Then i think the car speed display either from OBD or speed cluster is not using the RPM but ABS sensors. So it really read the wheel rotation speed meaning the only thing that could change the obd speed VS the real car speed is the tire size. But again the cluster needle is using a converter with some error margin to display the data from the obd system. For the part about comparing both RPM, it is just that during an high speed driving, you probably look at both rpm separately and everythinh happend fast. The small amount of time you switch your eyes between one display to the other is enough to minimise or amplify the error because the real rpm is shifting up or down... You may compare rpm, in lower gears, at fixed speed, so this will allow more time to look at everything while keeping an eyes on the road ahead. So if that test returns you a 400 rpm error between cluster and cobb AP, the same 400 rpm error will exist in 6th gear at full speed.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | BMC (10-22-2015) |
![]() | | #89 | ![]() |
Groans: 111
Same for the speed, even though the actual car speed has one more variable that alters it, the tire size (including wear, keep in mind that a tire can loose 4-5mm from its radius and it's still usable. However, with new OEM tires inflated to spec (I'm saying OEM tires not OEM size tires, not all tires of the same size are equal at the spec inflation) the OBD speed will be the same as the GPS speed and it's calculated based on some sensor in the gearbox that always looks at the rotation speed of the final drive
On a gen1 at 155mph/250Kmph OBD speed the engine RPM is 5950 or so in 6th. If the speed limits are removed then at 6700rpm the OBD speed would be 281.5kmph or 176mph. If you have the right mods and the engine car cool properly to do a full pull in 6th then with a rev limit of 7000rpm the OBD speed would be 294kmph or 183mph. 300kmph/187mph at 7150rpm and the holy graal of 320kmph/200mph can be reached with these gear boxes at 7600rpm, but at this speed if the engine is still in one piece the gearbox may start shitting metal bits.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |||
![]() | | #90 | ![]() |
![]() | | #91 | ![]() |
It is picky, but at the end of wear, pressure and tires brand, you can also add the fact that the tire would expand a little bit at very high speed and raise it's circonference ...a little...For 200mph, even 176, in my mind, it would need more than 275-300whp to reach it with the actual CX of the car. We should keep in mind the availaible torque, to spin the wheels, drop very quickly at higher rpm, especially with the stock and tiny k04... Using a GPS to double check the speed may not be a bad idea. I am curious to hear more story about max speed but i won't drive it at these speed in my area.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | BMC (10-24-2015) |
![]() | | #92 | ![]() |
B
| The Following User Says Thank You to BMC For This Useful Post: | mituc (10-23-2015) |
| HELP, FAST! | BoostIsBetter | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-20-2009 10:57 AM |
