Sent from my D6603 using Tapatalk |
We are such amateurs I think I'm going to sign up to one of those mechanic schools so I can learn how to change oil for $10 an hour. |
I trust the factory pre gapping... If i do have an issue i replace them. My car has been good. I will rest here. Obv we disagree. Thats ok. But you dont just insult the other peorson because thats no argument. Thats childish... Sent from my D6603 using Tapatalk |
Should i run ngk 1 step colder with just an AP the rest is bone stock? |
@Bautista; Stock plug, at the recommended gap. |
In b4 spark blowout. |
One step colder when your tuner recommends you to, or when you are running closer to 325HP or better. |
This thread is ridiculous. Not checking that gap is just silly. Why would you NOT check the gap to ensure it's correct? You don't need NASA to calibrate your feeler gaige or check the gap.. Youll know easily enough if you're in the ballpark or need to adjust. Not checking the condition or accuracy of any part that is to be installed is just idiotic. |
This thread is great. Vitamin probably isn't pushing the power the rest of you guys are and thus does not see bad gap affect his logs. Hell, I've just got bolt ons, e33 and meth...still check and gap my plugs. |
Yesterday i decided to pull my plugs just for the fuck of it and used a feeler gauge.(even tho never missfired and i constantly monitor A/F, knock and boost and boosted air temp.) what i found to ky surprise is that the plugs were all gapped at 28. Even tho i believe they market them as oem 32 gap. Did not have to adjust and was pleasantly surprised that thr gap was spot on. I did waste time i feel like. Because stevenW is right. I am running almost stock set up. Sent from my D6603 using Tapatalk |
| All times are GMT -7. The time now is 04:12 AM. |
