Like Tree10Likes
 Old 08-02-2012, 01:56 PM   #41
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
clearly he didn't use the search button. literally an insane amount of threads on internals. also, this forum isn't hard to understand. read the fucking stickies because all these beginner questions are in stickies. by asking something answered over and over and over again, it shows you have no intention of looking shit up. which means you want shit spoon fed to you. which is not what you are going to get here.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline   Reply With Quote
 Old 08-02-2012, 02:02 PM   #42
cshunter's Avatar
Posts: 1,312   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groans: 28
/facepalm
Sent from StalknTalk
2013 CWP That's slow
2012 LSM Totaled by an asshole red light runner
Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )
Previous: MILTUNED E85 K04
cshunter is offline   Reply With Quote
 Old 08-04-2012, 03:32 AM   #43
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
Groaned at 4 Times in 2 Posts
Autotechs... Plenty of info all over the forums to support it.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
 Old 08-04-2012, 05:44 AM   #44
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Originally Posted by Sweetsandman
He probably used the search button so he wouldn't get flamed...then he gets flamed anyways...sure can't wait to pick up my Speed3 on Saturday so I can try to understand this forum.
Sent from my DROID BIONIC using Tapatalk 2
He probably didn't use the search button smartass, because if he did he would have found the answer. Why is it always the noobs that stick up for each other? Probably because anyone who actually does spend time in here and search knows when someone is full of shit. "I tried using the search but I can't figure out what BOV is best"
2012 Mazdaspeed3 Black Mica
 Old 08-04-2012, 09:34 AM   #45
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Noobs need to get thick skin and grow some balls to stick around here...you'll learn if you stick around. Just for giggles there's a intro for Noobs thread, actually a couple, on separate topics with these questions that have been asked a million times, a 100 million different ways. Maybe @Raider can point you in the direction you need, he lead the revolution on non searching skill Noobs.
Sent from my Galaxy Nexus
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
 Old 08-04-2012, 10:03 AM   #46
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
So is AT the best???
Lol I keed.
 Old 08-04-2012, 10:14 AM   #47
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
Everyone knows that the best performance is gained by modifying a pressure washer and using that as a fuel pump instead.
More seriously, this is a question that was answered for me before I even made an account, which says something given that you only have a finite number of posts before you're forced to register. Brownie cannibalism, both disturbing and offensive to all involved.
bislag is offline   Reply With Quote
 Old 08-10-2012, 12:27 PM   #48
bigspender's Avatar
Posts: 854   (View Stats)
bigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the world
Groaned at 46 Times in 21 Posts
Originally Posted by marvster69 View Post
not sure why I bother to get on here. There are always so many assholes with asshole answers when people just ask a question. Thanks for everyone who always are dicks on here when people ask questions. I wont ask again. Thanks for everything. Such great people on these forums.
thanks to those who actually post helpful replies and are not jerks.
This is why I don't donate or post. I lurk. Too many faggots that take dick.
bigspender is offline   Reply With Quote
The Following 2 Users Say NO Thank You to bigspender For This Un-useful Post:
jack_hammer (08-11-2012), Onelovesoccer (08-10-2012)
Issue with HPFP AutoTech Internals spoof3r 2010 MS3 - Fuel, Nitrous & Water Injection 12 10-03-2017 05:34 PM
Page generated in 0.33996 seconds with 27 queries
