![]() | | #81 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score
but it will probably just be more duct tape, paper clips and zip ties | ||
![]() | | #82 | ![]() |
![]() Join Date: Jun 2010 Location: Toronto, Ontario, Canada
Rep Power: 297 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 899
Groans: 52
__________________ 2010 Black Mica MS3 Mods to date: Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071 Mods to come: Driver Mod || Snow Performance Meth Kit | |
![]() | | #83 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
Groans: 28
| Neutral : +1 score Since I had nothing better to do today, I took the time to get to the bottom of the fitment issues. Not that anyone will care or read this but, at least I know handled the situation quickly and without pointing fingers at the installer. This is what I found... The factory mounting location where the intake attaches to is fairly flimsy. The 3 cars I checked today it was in a slightly different spot and it did not line up perfectly with the mounting bracket on our intake. After a little manipulation of the factory mounting point it lined up nicely. Now on to battery box issue... 2 out of the 3 cars I checked today the intake cleared the battery box by a 1/16 or so, the 3rd no go. I could only get one of the battery box bolts in without pushing hard on the intake to get the remaining 2 bolts in. I took the intake back out and over to the fixture it was welded up in, it fit perfect. I took an old intake I had and put it in the fixture and it fit the fixture too, so I ruled out the fixture as the issue. After giving things some thought I started taking measurements. The motor in the 3rd car was over towards the drivers side a tad bit over 3/8 of an inch compared to the other 2 cars. I put 2 jacks under the motor, loosened the TMM and PMM and wiggled the motor motor over towards the passenger side and viola, the intake fits with a 1/6 of and inch clearance. There is close to 7/8 of an inch of side to side allowance in the mounting holes of both the PMM and TMM. This explains the why some fit and some don't. Once everything was buttoned back up the intake fit perfect and cleared the the OEM BPV with only the included spacer by more than a 1/2" I believe it's safe to assume that fatigue of the side mounts could also increase the chance of the intake coming in contact with the battery box. I must agree with HTP, this is gonna be a tight fit for every MS3 and may not fit perfectly with every setup. Happy Holidays. |
| The Following 37 Users Say Thank You to JBR For This Useful Post: | 08.5MS3 (12-25-2012), 3Gee Tee (12-24-2012), 8.5MS3 (12-25-2012), aldekei (12-24-2012), anavrinIV (12-24-2012), ArcticSpeed3 (12-24-2012), atvfreek (12-24-2012), BigRedSpecial (01-03-2013), BlueStreak (12-24-2012), dantes5823 (12-24-2012), Davey (05-18-2016), Easter Bunny (12-27-2012), exentix (12-24-2012), fywdyl (12-24-2012), jdub0802 (12-24-2012), LatinKraze (01-26-2013), lilred (12-24-2012), Menace1 (05-02-2013), Monotonous ONE (12-25-2012), msantana101 (01-08-2013), MZRSPEED (12-26-2012), Pendarus (12-28-2012), PokeyHokie (01-08-2013), qkrthnu2 (04-18-2015), QwkEVO (12-25-2012), Raider (12-24-2012), rcalt25 (12-24-2012), robry (12-27-2012), Sid3wayS (12-24-2012), SLOWHATCH (02-11-2013), smoogs12 (12-24-2012), specvspeedfreak (12-24-2012), SpeedNess (12-24-2012), stevehuff (12-27-2012), Tokay444 (12-24-2012), trancehead (06-03-2013), Zdraveca (12-24-2012) |
![]() | | #84 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following 4 Users Say Thank You to GODspeed7 For This Useful Post: |
![]() | | #85 | ![]() |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
| Not Ranked : 0 score im another canadian brother, running the jbr intake on my k04 relocated the ecu to the top of the fuse box. 1 bolt in the battery box, the intake still touches it. I put some adhesive foam rubber between the box and the intake so that it wouldnt rub the finish off im running a forge bpv with a short rectangular extension piece between the bracket on the engine, and the bracket on the intake, the filter still touches my bpv. Without it, the filter would not fit as the intake would be sitting higher. Im not sure it would fit with the stock bpv i have washers and tube spacers sitting in my garage, ive just been a lazy ass. I think im just going to remove all the bolts on the battery box, i dont think its going to go anywhere, so that it will be as far as possible to the side. Or i could even drill new holes, use longer bolts to fasten it down. another thing, the screws were coated, as well as the mating surface where the maf sits on. There was a substantial leak around the maf, assuming because of the coating. I just used sensor safe caulk gasket on the mating surface. nothing has really been straight forward, but the quality is there, and now that my itty bitty asian tuner is back from holidays, we will start to tune for the larger intake
__________________ |
| The Following 6 Users Say Thank You to breakfasteatre For This Useful Post: | BlueStreak (12-24-2012), Easter Bunny (12-27-2012), fywdyl (12-24-2012), MarineMazda (12-24-2012), Mr Wilson (12-27-2012), Tokay444 (12-24-2012) |
![]() | | #86 | ![]() |
![]() Join Date: Dec 2011 Location: howard, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,479
Groans: 46
Groaned at 15 Times in 6 Posts
| Not Ranked : 0 score Perhaps mine fit so well since I was literally still breaking in my pmm. Either way, your awesome for taking the time to address the issue so quickly during the holidays. Now stop working so much and enjoy your day.
| The Following 2 Users Say Thank You to exentix For This Useful Post: | Easter Bunny (12-27-2012), HTP (12-24-2012) |
![]() | | #87 | ![]() |
| Not Ranked : 0 score coincidentally, im running jbr mounts
![]() | | #88 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2010
Rep Power: 675 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Agreed. :-) Merry Christmas JBR and everyone. Enjoy the holiday! |
| The Following 6 Users Say Thank You to HTP For This Useful Post: | ArcticSpeed3 (12-24-2012), atvfreek (12-24-2012), dantes5823 (12-24-2012), Dmurray06 (12-24-2012), robry (12-27-2012), Tokay444 (12-24-2012) |
![]() | | #89 | ![]() |
Groans: 793
| Not Ranked : 0 score Kudos JBR.
![]() | | #90 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score Slightly off topic, but @HTP; is your sig from Zoolander, because i always end up reading it in Ben Stiller's voice haha
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | dantes5823 (12-24-2012) |
![]() | | #91 | ![]() |
Matt | |
| The Following 4 Users Say Thank You to HTP For This Useful Post: |
![]() | | #92 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
Groaned at 54 Times in 27 Posts
Thanks for looking into this...You didn't have to do it today of all days Merry Christmas.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite | |
![]() | | #93 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score I'm sorry, I just couldn't read all of the posts for this discussion. Please understand that while I'm chipping in my .02 My JBR intake is in contact with my bpv. I don't know what that means. The side of the filter nearest the bpv is partially crushed. It makes more power than either my k&n SRI or my 3" cp-e CAI. It's probably not ideal but I haven't had the time to fix it recently. Again, airflow is much much better than the two intakes I've had on it recently so it doesn't matter so much to me. I bought the air straightener separate from treadstone. Some coaxing and it fit. I have no idea what it would be like w/o the straightener as it has been installed for the entire time I've had the intake on. I only have rough fuel trims dialed in. They fluctuate about +/- 3% of where they were after 50 miles of driving. They could be w/in 3% of 0 ltft, but they're w/in 5% and that's good enough for me not to care. With the stock battery, there isn't a lot of room between the intake tract and the battery box. I don't know what this means, if anything. You might be able to fit a 3.5" intake in there without removing the ECU, but it seems like it would be a pretty tight fit. Either way I'm not gonna sell the JBR 3.5" I've got. It works, and it's only $15 more than the corksport SRI+TIH, less when you add in shipping. More when you add in the double-sided tape for the ECU relocation. Honestly, I don't think you'd go wrong with either one (HTP or JBR), given you had the ability to tune for it. IMO as long as it's one piece you're good. FWIW I do really like the wrinkle coating on my JBR. |
![]() | | #94 | ![]() |
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,698
Groaned at 42 Times in 15 Posts
| Not Ranked : 0 score Mine fits fine as long as you remove the ecu... i just have mine currently sitting on top of the fuse box with no tape or velcro because it doesnt move at all what so ever. The mounting tab is iffy, ive had it on and now its currently not attatched because where end of the intake curves where the coupler attatches its an odd shape and just does not go on very well as there isnt much material there to get the clamp on. But its on there, and works havent had any major issues with it..
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! Last edited by InFeXIoN; 12-27-2012 at 02:19 PM. |
![]() | | #95 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
Groaned at 12 Times in 8 Posts
| Not Ranked : 0 score i used search and found this thread. I'm planning on upgrade my Cpe TIP unit to a full "pipe" unit. I know this thread is all about the MS3 fitment. But will the HTP TIP (3" or 4") or JBR TIP fit on a MS6 with the stock battery in the stock location? |
![]() | | #96 | ![]() |
Groans: 326
| Not Ranked : 0 score No |
