Install help in Austin Was wondering if anyone would be willing to help me install a few simple bolt on's SSP, RMM, Shifter bushings...I just don't have a place to do it. no room in the garage and drive way too steep. Not putting the car on jackstands in the street with no trees and 105 degree heat |
Just as an FYI, you don't need to put the car on jack stands for the SSP or the bushings. And the RMM literally takes 10 minutes. I'd help you if I lived nearby. Good luck. |
I wanna find a lift I can use here in town. if you find one let me know... |
I just installed all of that exact stuff from JBR (great job, Jamie!). The SSP and bushings I did in my own garage (you really don't need much room or tools). Then I went down to my parent's house (in Austin, actually) and stole Dad's old ramps. They are just the cheap plastic ones you can get for $50 or $60 bucks, but they worked fine with a ratcheting torque wrench. I'd let you use them, but I'm back up north of Dallas now. Really though, its an incredibly easy job, and you can get away with spending an extra bit of $ to get ramps or a cheap jack and stands. It's not like you won't use them again! |
but exhaust sems like it would be so much easier on a lift.... RMM on 2x12 diy ramps FTW. |
What the hell ever happened to the term "shade tree mechanic"? Its not that hard, you'll be able to do it. Sweating in the heat is good for you and it will make the results feel even better. |
| All times are GMT -7. The time now is 04:04 AM. |
