Installed COBB SRI..first mod, not bad Just installed the COBB short ram intake earlier today in the 1 hour i had in between school and work. Gotta give a shout out to @eric@edgeautosport, those guys do a great job getting you what you need, took exactly 48 hours for the box to be sitting at my front door. DEFINITELY recommend them to anyone on the forum. Opened it, came double boxed with super safe packaging. Took me about 45 minutes to have everything in and running. Restarted ecu and started it up. Start up sounded about the same as before, after waiting for it to warm up i revved it and noticed a HUGE change in sound of the breathing of the engine, the spooling of the turbo, and the stock BPV was MUCH louder than expected. No CEL at anypoint so far. Drove it around, definitely a minor change in power, not going to run it too long without the AP and internals (which are being ordered withing the next 2 weeks). What were your guys' thoughts and discoveries after installing your SRI? LOVING mine so far. |
Glad to here no CEL, I just ordered the Cobb sr and AP!! |
Much more important to have internals with the AP, rather than that SRI. |
I'm pretty sure the intake causes CELs, you might not get one right away but you will eventually. You are on the right track though :) Enjoy your mods, the AP and fuel pump will make a huge difference in comparison though. |
SRI i a good start, and then next is the big leap, and you know where you will get the AP and FP internals from already. Learning step by step, newbie. Nice. |
yeah I'm pretty impressed :) |
RMM or inserts make this car feel a buttload better. And as far the my sri/tip, i didn't really notice too much of a difference other than the sound. |
http://www.mazdaspeedforums.org/foru...-combo-122505/ I am sure. |
CEL will be hit or miss. Go ahead and get a RMM. Makes you feel more connected to the car. Sent from my DROIDX using Tapatalk 2 |
Make sure the hose clamp doest rub against the wire bundle of the ECU thats in the left if your battery. Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 Quote:
Maybe there is too much oil on the filters in these cases Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
EDIT: yes you do, but every car is different. |
I have the Cobb intake and turbo inlet pipe on my MS6. Fuel trims did not change one bit (no MAF calibration, just factory parameters) so of course no CEL. As should be, considering Cobb states their MAF housing is molded like the factory unit so airflow is measured the same. I love mine, and picked up ~15-20 g/s of max airflow after install with identical fuel trims and no other changes. |
Get it OFF that cover. It WILL fuck up the ECU wiring. Common, and $$$$ if it does. |
Fixed. |
got bored so i made a funny video of before and after SRI. Enjoy hahahah.. http://www.youtube.com/watch?v=9d4mJ...ature=youtu.be |
glad that you fixed it, I have had to repair one members wire harness on here cause of that, lucky for him I was able to lay new wire in place of the damaged wire and make it look nice and clean like from the factory. But I have read where some dealerships will bight you in the ass and say you need a whole new freaking harness. |
pay attention to stuff like that as you mod. look at how it will interact with everything else.. make sure all the new frieds play nicely. |
lol the video was pretty good. good job. |
AP AND HPFP COMING IN ONE WEEEEK! so stoked. |
I didn't watch the video but are you talking about the "Cobb SF + TIH clamp rubbing against the wiring harness" problem? If not I would figure out what I'm talking about. If not ignore my laziness please. My Cobb SF actually broke. The lower mount, where it bolts to the battery tray, broke in two. I can also see a "line" in the hood "fiber mesh" lining where the SF must have been rubbing the underside of the hood. Throw in a couple good wrong gear, "the engine hit the firewall" shifts on the stock motor mounts and it will snap. So the fix it to either bend your entire bracket down on the Cobb SF to give it plenty of room to clear the hood. Or get an aftermarket RMM. Or do neither and just say fuck it let it happen and now it just wiggles around a bit in the engine bay, like I did. But yeah the intake sounds good. I also have an original dyno sheet from a real dyno (well a dynapack at least) and I gained 23whp and 43wlbs/ft of torque from the Cobb SF, TIH, and an AP set to stage 1, same day, same dyno. (I promptly switched to safe mode and installed internals after experiencing FACEFULL OF STEERING WHEEL or is it FACEFULL OF WINDSHIELD or whatever 3 miles after leaving the douchebag shop that thought they knew the MS3/MZR/DISI shit which he obviously didn't). Oh yes, while I'm here: to @Cobb Tuning can you please send me a new SF SRI mounting plate to replace my broken one? I mean its more of a bit of a defect in the design than me screwing it up, yknow? You know you can do it. I promise I'll either get a RMM soon or line the new plate up better this time. |
I went 7 or 8k miles before I got an ap, then started self tuning on stock internals....(yep) now 17k miles and the only cell I've had was for my catless dp after install of it before my retune. Would prolly groan you for your misleading crap if i was not on my phone. OP you'll be fine. Sent from StalknTalk |
I installed the Cobb SRI and Turbo XS BOV on my car at 3,000 miles. I have 33k on the car now and have only had one CEL. And that was my fault as the intake was not fully seated when I installed it. These are my only mods to the car and it has been trouble free. |
COBB Tuning - MAZDASPEED3 SF Intake Kit |
I installed cobb sf/ap ots stage1, fp is gud under wot 1-3, 4th is another story it drops down to about 1550 between 3k-4k after that its ok again... Saving up for intarnals |
| All times are GMT -7. The time now is 05:21 AM. |
