Like Tree4Likes
 Old 08-13-2012, 01:21 PM   #1
TexanMS3's Avatar
Posts: 28   (View Stats)
TexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of light
Groaned at 3 Times in 1 Post
Default Issues after drag racing
I searched but did not find the answer to my question. I took my 2012 MS3 to the 1/8 mile to practice my launch for when i go to street heat at the 1/4 mile later this month. I did 5 runs but then when I started my car to leave (because it started to rain) my check engine light came on, car wouldn't go above 1500 rpms and i had vibrations coming from the front. My idle was also weird going as low as 500rpm and as high as 1300 rpms. I had it towed to the dealer and they said my PCM was bad. So they replaced it but now they just told me they started it back up and its running bad again. I never dropped the clutch on the launch, car still went into gear after just only up to 1500 rpm in the gear. Has this or anything similar happened to anyone else? and any thoughts as to what might have caused the engine running bad the second time after they replaced my PCM?
TexanMS3 is offline   Reply With Quote
 Old 08-13-2012, 01:25 PM   #2
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Mods? Pull the code and report back. And get a fucking avatar, I can't stand looking at that iDouche
The Following User Says Thank You to SofaKingAwesome For This Useful Post:
Pointless (08-13-2012)
 Old 08-13-2012, 01:26 PM   #3
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Need code reading... He beats me ^^^
and why does your name have Texan on it, and your from FL
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 08-13-2012, 01:28 PM   #4
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Need code readi.... ah damnit.
The Following User Says Thank You to 3Gee Tee For This Useful Post:
DingoDave (08-19-2012)
 Old 08-13-2012, 01:42 PM   #5
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Where did the ifaggot come from? Where the fuck is PhillyB?
2012 Mazdaspeed3 Black Mica
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
Ckmazdaspeed3 (08-14-2012), radioflyer (08-14-2012)
 Old 08-13-2012, 01:44 PM   #6
TexanMS3's Avatar
I have a CS SRI and TIP and a dual port BOV set to full recirculation. The dealer wouldn't print me out the codes. First time it threw 5 codes all for the PCM but they haven't told me anything about the new issue.
 Old 08-13-2012, 01:46 PM   #7
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Your dealer sucks. Get the codes. If stock @ the dealer, demand regional manager, escalation to a Master Technician.
 Old 08-13-2012, 01:47 PM   #8
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
dealers suck balls, it's still at the stealership? find a reader to borrow. also check for vac leaks
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 08-13-2012, 01:53 PM   #9
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
Sounds like it could be in limp mode maybe, try disconnecting the battery.
 Old 08-13-2012, 01:56 PM   #10
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Ummmmm answer ==> more drag racing,
2012 Black Mica MazdaSpeed3
Street creds:
The Following 2 Users Say Thank You to fortressofcomfort For This Useful Post:
Ckmazdaspeed3 (08-14-2012), TexanMS3 (08-13-2012)
 Old 08-13-2012, 02:02 PM   #11
TexanMS3's Avatar
I'm headed to the dealer. I'll try to get the codes to see what's wrong with it. And I'm from Texas but do live in fl. That explains my username.
 Old 08-13-2012, 03:55 PM   #12
TexanMS3's Avatar
They said Mazda told them to replace the battery because the levels were weak and then it was running fine and then it didn't run fine again and they even reflagged the PCM again and still ran like shit. Now they are saying it isn't throwing any codes but doesn't it take some time after you flash the PCM for the codes to pop back up? I forgot to get the codes that it threw the first time. I'll get those tomorrow when they call me. I was just dumbfounded that they can't diagnose my car
 Old 08-13-2012, 03:59 PM   #13
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
God damnit drive up to Jacksonville, I'll fix your car.
Your dealer sounds like they suck.
timjs is offline   Reply With Quote
 Old 08-13-2012, 04:05 PM   #14
TexanMS3's Avatar
If my car had any power I might take you up on that offer. I think I can walk faster than my speed 3 right now
 Old 08-13-2012, 06:00 PM   #15
GODspeed7's Avatar
And this is why everyone hates the dealers on this site. Bunch of educated idiots. If its not in a book that specifically has it drawn out in color they can't fix shit. But yet will be the first ones to void a warranty over something that has nothing to do with the real problem. "your intake fried your PCM"
Mazdalover01 likes this.
The Following 6 Users Say Thank You to GODspeed7 For This Useful Post:
Ckmazdaspeed3 (08-14-2012), fortressofcomfort (08-13-2012), Ms3_Miami (08-14-2012), radioflyer (08-14-2012), uncorked11 (08-14-2012), xI Leveler Ix (08-14-2012)
 Old 08-13-2012, 06:38 PM   #16
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Groans: 106
Not all are this way, but this dealership sounds like it. One of the first things I do is I wright down the DTC and what it is so the customer may know. I think you screwed something up at the drag strip, but if they re flashed your pcm will not have any dtc except for some U codes from the pcm being erased then loaded back up. And as far as I know there has not been any reflash updates. I would suggest going to another mazda dealership if possible, if it even means being towed. Also I would ask them which tech has been looking at the car, if it is one of the certified mazda techs or a actually master mazda tech?
go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle
suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55
motherfnmonsta is offline   Reply With Quote
The Following User Says Thank You to motherfnmonsta For This Useful Post:
 Old 08-13-2012, 07:15 PM   #17
IPuOnU's Avatar
Posts: 399   (View Stats)
IPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the world
Your from Tampa? Check nator FL for better dealers.
2010 CBM Speed 3 (Daily)
Muffler Delete
Sure Aeros
TRZ Poly RMM
14.11 @ 100 2.1 60'
1986 Firetird
350 Chevy (2 Bolt Main)
Stock Bottom End
Edelbrock E-tec 200 Heads (Port, Polish, Decked)
JE Pistons
Ford 9" Rear End 4.30 Gears
Stock Suspension
11.29@113.8 mph, 1.54 60'
IPuOnU is offline   Reply With Quote
The Following User Says Thank You to IPuOnU For This Useful Post:
Raider (08-15-2012)
 Old 08-14-2012, 06:00 AM   #18
jnt
jnt's Avatar
Posts: 39   (View Stats)
jnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond reputejnt has a reputation beyond repute
My guess is t bolt clamp rubbed the ecu wiring harness and screwed some wires, or the recirc hose come off your blowoff valve, that could explain the bad idle. Hope it gets worked out what ever it is, all the best.
jnt is offline   Reply With Quote
The Following 5 Users Say Thank You to jnt For This Useful Post:
atvfreek (08-14-2012), evolizzee (08-17-2012), G26 (08-14-2012), Ms3_Miami (08-14-2012), TexanMS3 (08-14-2012)
 Old 08-14-2012, 06:07 AM   #19
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Groaned at 18 Times in 4 Posts
^^This.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
The Following User Says Thank You to Ray Danger 2020 For This Useful Post:
 Old 08-14-2012, 06:13 AM   #20
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
I'll offer a crazy option.
How are you motor mounts? I saw a car one time that nobody could diagnose.
The motor mount was bad and car was interpreting the extra movement/banging as knock and pulling so much timing the car ran like shit.
Reset the ECU and the car would run fine for a day and start running poorly.
I wouldn't say your dealer is all bad, at least they are working on a modded car, many won't do that.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
 Old 08-14-2012, 09:02 AM   #21
TexanMS3's Avatar
I'm hoping it's something as simple as a motor mount. Hopefully I'll find out today. The dealers around here say that as long as they can say that my mod is the sole reason my car messed up then it's covered under warranty still. I just don't want to have to pay out of pocket. Next month I'm ordering autotech fuel pump internals, HFCS downpipe, CBE, and a Cobb AP.
 Old 08-14-2012, 09:06 AM   #22
atvfreek's Avatar
Posts: 7,787   (View Stats)
I bet you the wires are rubbed through by the PCM. The turbo inlet sits very close and I have seen the clamps do damage to the harness.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 08-14-2012, 09:08 AM   #23
Groans: 106
actually had a member from this sight bring me there car in for idle issue and had a dtc for a idle issue, and his t bolt from his cobb intake actually did rub into the wiring harness going into the pcm, and I repaired the wire and issue has been fixed. And op if that is the case that they did this do not let them hose you over by trying to say o you will need a new engine harness bla bla bla ask them to repair it. It only should take a hr at most to do. I did the one on the car mention above in about 40 min. And if this issue is what I think it is I know why they replaced your pcm, cause the lazy fucks where to lazy to tear apart your wiring harness and start looking at the wires for damage, and if everything checked out ok like the iac,tps 1&2, and the app 1&2 they say to replace the pcm after inspecting wire harness for damage if there no damage seen.
 Old 08-14-2012, 09:14 AM   #24
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Plus one to that also. With the amount of engine movement with ur stock mounts, it is very likely.
Mine even started to do this, luckily it only got as far as cutting the black tape over the harness.
Before I cut the bolt on the clamp shorter
The Following User Says Thank You to G26 For This Useful Post:
 Old 08-14-2012, 10:00 AM   #25
Wide tire man
dbrier's Avatar
Does anyone have a picture where this wire damage happens?
 Old 08-14-2012, 10:20 AM   #26
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
This is from the CS website, and the clamp isn't the same one from their kit, but if you don't clock the T-bolt correctly at the elbow between the MAF housing and TIP, the threaded end will jam straight into the wires at the harness connector on PCM. I made this mistake when I was installing my intake and had to correct it before I could reinstall the battery box.
EDIT: Added a second photo showing how close the T-bolt clamp is to the harness, red arrow.
2004 MSM TiGrey
The Following 2 Users Say Thank You to Crarrs For This Useful Post:
3Gee Tee (08-14-2012), atvfreek (08-14-2012)
 Old 08-14-2012, 10:39 AM   #27
Wide tire man
dbrier's Avatar
Thanks!
I will be doing an intake in the future and this is good to know.
 Old 08-14-2012, 05:52 PM   #28
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
I actually used the factory clamp because the CS replacement one was definitely going to do some damage. glad i did.
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
 Old 08-14-2012, 07:14 PM   #29
TexanMS3's Avatar
So the clamp that holds the filter to the MAF sensor housing rubbed through some wires in my wire harness and now that the dealer knows about it I have to replace it or I won't have a warranty anymore... $1452 and once that gets fixed then I get to find out if my PCM is good or bad. I think it's good tho. If I would have known that was the issue I would have fixed that myself and not included the dealer
 Old 08-14-2012, 07:19 PM   #30
zmarko's Avatar
Posts: 147   (View Stats)
zmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond repute
Read post #23 (I'll quote it below in case you haven't read it). Looks like he works at a dealer and is giving you some pretty solid advice.
-Marko 2012 Speed 3
zmarko is offline   Reply With Quote
 Old 08-14-2012, 07:23 PM   #31
TexanMS3's Avatar
No doubt it was solid advice and if I hadn't taken it to the dealer I would have had it fixed for cheaper but I don't want to void my warranty so now I'm forced
 Old 08-14-2012, 07:44 PM   #32
Standsideways's Avatar
Posts: 363   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
take this as a $1400 lesson, seriously.
if you can install an intake and turbo inlet you should be able to deal with problems like this, and dont take it in to the dealer unless it is surely fucked.
dealerships work on a system, they now want to do the entire harness because that is what the computer tells them to do, that's how it works unfortunately.
it literally would cost you PENNNIES or NOTHING with the help of your FL NATOR guys(wich are always hard at work modding speeds)
start reading and learning!
Standsideways is offline   Reply With Quote
 Old 08-14-2012, 08:15 PM   #33
Groans: 106
Ya you are getting hosed man I am sorry that this dealership is doing this to you. I told my service manager about what happen here and even he asked me if I could just repair the wire instead of replacing a whole harness, and to be honest I rather repair just the damaged wire instead of going through the hassle of replacing a freaking harness. And as far as the pcm that should be on them they are the ones that miss diagnosed the pcm so they should eat that not you. If the tech knew what he was doing he would of checked the wiring from the app,tps to the pcm. I am curious to how much damage this clamp did do?
Liquid3Speed (08-15-2012)
 Old 08-14-2012, 08:27 PM   #34
hung380's Avatar
Posts: 127   (View Stats)
hung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond repute
Can't you just buy the cable and do it yourself? Similar thing happened to my other car so I told the dealer I'll replace the cable myself. Cable was 200 and dealer wanted for 300 labor. I saves 300.. just a thought
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
hung380 is offline   Reply With Quote
 Old 08-14-2012, 08:29 PM   #35
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Put putting around, you dont feel the effect of pulled timing like at wot. I can get 8° kr all day accelerating or cruising and not feel a thing... I can hold 8° for minutes! Jelly? U should be
 Old 08-14-2012, 08:30 PM   #36
TexanMS3's Avatar
I would but I ran out of mikes for a free tow and it's over 30 miles away. I am getting a "discount" and in all honesty I'm really tired of dealing with it so I'll just pay them and lesson learned. I will be much more careful when doing my next mods
 Old 08-14-2012, 09:08 PM   #37
Groans: 106
ask them to take a pic of the damage and to email it to you so you can share please.
 Old 08-14-2012, 11:49 PM   #38
TexanMS3's Avatar
I'll call them tomorrow and ask them to take a picture before and during the process so y'all can see what it looks like under the good and then the real damage that can be displayed
 Old 08-15-2012, 04:52 AM   #39
jnt
jnt's Avatar
Man that's too bad, it's probably best to never get towed to the dealership or take the car there if you are not sure whats up, then it gives you time to diagnos the problem yourself or post on this great forum so you can go to the dealership armed with information. Hope it all pans out ok for you. Cheers.
 Old 08-15-2012, 05:06 AM   #40
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
Which dealership? Not like I go to any for repairs, (lol @my sig) but its good to know what dealerships people got dicked over at.
Drag Racing! Haltech Drag Racing 10 10-31-2013 09:15 AM
Went drag racing last night... spheed3 Drag Racing 8 05-06-2009 09:04 AM
Page generated in 0.57114 seconds with 44 queries
