![]() | | #1 | ![]() |
![]() Join Date: May 2012 Location: Cary, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
Groaned at 6 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score I am looking at the JBR Power Path Stage I or II. This is for the 2013 that we have. My questions are, what has the experience been with regards to the TIP making contact with the ECU cover, wiring harness etc? My guess is, it’s similar to Cobb, which I have never been thrilled about. When I was running mine I mitigated the issue by installing the JBR small battery tray, but I am not looking to go to that level right now. Also, for those that are running a JBR S1 or S2, have you stayed with the OTS maps from Stratified? I am firm believer in a custom etune, but I want to careful how much $$ I spend right now. Thanks!
__________________ 2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox) Coming soon: 2nd etune 2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!) |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
Groaned at 123 Times in 84 Posts
| Not Ranked : 0 score Get the OTS from Freektune. I'd personally go for the 3" full intake if it were my car.
__________________ https://www.youtube.com/user/JustinBieberVEVO |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Justin@Freektune (12-03-2014) |
(Thread Starter) | Not Ranked : 0 score That's a good suggestion. The only thing is, my immediate goal right now is to eliminate the mouse house under the hood. If I can meet that goal with something fun for her car while I am at it, that works. But getting into a battery tray, battery, custom tune, etc. is too much right now. I just thought with the JBR S2, I could put the SRI on right away, and run an OTS map. Then once I have a garage, and all my tools, I could put the TIP on. However, if the JBR TIP does the same thing as the Cobb does (rubbing), I might just go with the stage I. Ultimate power is not something she needs. :-)
![]() | | #4 | ![]() |
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2012 Location: Richmond, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 31 Times in 14 Posts
| Neutral : -1 score I bought the ecu relocater kit from track time, pretty easy install and will give you lots if clearance BUTi can tell you it WON'T Work w the factory airbox
__________________ ΜΟΛΩΝ ΛΑΒΕ 2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's 2015 F150 Platinum 2012 MS3 Liquid Silver Autotech HPFP Cobb AP & CBE Corksport FTB Enkei Raijin 18x8 et45 JBR 3.0WP, RSB, RMM & SSP II Stratified Tune TrackMasters hood prop and ecu reloc. TurboSmart BOV |
| The Following User Says Thank You to RACER_X For This Useful Post: | JgamB (12-03-2014) |
![]() | | #6 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
| Not Ranked : 0 score I had the Cobb SRI/TIP, JBR 3" WP, and now the CS True 3" Intake, all of them with the stock battery box and ecu location, no rubbing. It came very close, but didn't hit.
__________________ All good things must come to an end... |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah that could make a difference. For the <$100 difference, I guess I could just roll the dice with the Stage II. Install the SRI for now, and once we get a settled, put the TIP on. The quality looks really good with the JBR.
![]() | | #8 | ![]() |
I have also run the Cobb SF and TIP. That one was better fitting for somethings, but the TIP would still rub. Not enough to damage the silicon for the period it was on the car, but if I ran it for years there would no doubt be a hole in it. What I never liked, was the air filter they gave you. Eventually I swapped it out with a Dry flow.
__________________ 2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox) Coming soon: 2nd etune 2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!) | |
![]() | | #9 | ![]() |
Very nice. How tight are the wires in the new location? I know with the battery tray, the location did take up a lot of the play the wires had when they were in the stock location. Even after unclipping some of the hold downs.
![]() | | #10 | ![]() |
| Not Ranked : 0 score I had to put it all back together to stock config I don't have the maps ready for the intake yet, I was just trying to get the area ready for future work. When I had it on, they're was a lot if Room next to the battery box
![]() | | #11 | ![]() |
![]() Join Date: Mar 2013
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
| Not Ranked : 0 score We've run the Stage II with out any issues. The Install is straight forward and without issue and ran great with the OTS Map as well.
__________________ [size="2"]2003 MSP Spicy Orange #1151- "Zoom freakin' Zoom" Injen CAI (black), Yellow Calipers G2 System, Carbon Fiber Tower Brace, Red Line MT-90 Tranny Fluid, Custom FMIC-Big 3 Racing , Motegi F-7 Wheels , wrapped in Yokohama Parada Spec II's 215/40/17, SU Complete set of Motor Mounts, BC Coilovers, Adjustable End Links (front & rear),Power Slot Rotors, Techna Fit SS Brake Lines, Cobalt Friction XR-3 and XR-5 Pads, Russell Speed Bleeders, Mishimoto Radiator, Haltech Platinum Sport 1000, Disco Potato upgrade ATE Super Blue Brake fluid, (Kosei K-1 TS (painted yellow) w/ Kumho V710's 225/45/17) & Enkei RPF-1's 17 X 8 Black w /Toyo 888's 235/40/17 or B F Goodrich R-1's-NASA Time Trials, Apexcone 6000K HID's, AEM UEGO Wideband, AEM Tru-Boost and Electronic Controller & Boost Guage & AEM Digital Oil Pressure Gauge , Turbosmart Black Dual BOV, Custom 3" turbo-back exhaust (Patel Engineering), Findanza Lightweight Flywheel and Exedy Stage 1 Clutch, SS AFC, Wiseco Pistons, K-1 Rods- NASA TTD #327 2003 MazdaSpeed Protege 2013 MOCO Mazdaspeed 3-Crystal White Pearl-Bi-Color w/Tech Package-JBR Stage II SRI, Mishimoto OCC, JBR .250 RSB w/ Tri-Point end links, XPEL Clear Bra, JBR PMM & RMM, JBR MOCO Mud Flaps, Yellowspeed Coilovers, JBR Adjustable Rear Camber Arms, JBR Stage 2 Black Adjustable Short Shifter Plate and Bushings, JBR Shift Knob, EGR Delete, COBB AP, CP-e Flex II RMM, CP-e Triton CBE |
| The Following User Says Thank You to MOCO MS3 For This Useful Post: | TJM216 (12-03-2014) |
![]() | | #12 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cool. Looks like the JBR ended up in the Gen2, so that is really good to know.
![]() | | #13 | ![]() |
| Not Ranked : 0 score Good to hear! You'll enjoy it, no doubt!
![]() | | #14 | ![]() |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score I had rubbing with my JBR intake in a few spots on my Gen1. Nothing that couldn't be rectified, though... T-bolt clamps rubbing against the ECU cover was one. ![]() Above, is how Jamie recommends installing the T-bolt clamps -- this didn't work for me. I ended up flipping the two that connect the TIP to the intake so that the bolts face upwards and ever-so-slightly to the passenger side. Play around with 'em until you find what position gives you the most clearance. Having them face upwards also makes it easier to readjust things. One thing to keep in mind is that there IS wiring above these clamps. Make sure that everything is safe and that there's no chance the T-bolt clamps will make contact. The second spot was the white plastic wiring cover -- which you mentioned you've also experienced. ![]() I removed the nuts holding the bracket and made sure the bracket was situated as far to the driver's side of the car as possible -- every little bit helps. Bend the metal tab for more clearance if needed. The third spot I encountered rubbing was the edge of the air filter with a plastic notch in the front of the car. It ate through my filter wrap ever so slightly. ![]() I ground the plastic tab down with a dremel and that took care of that problem. (Not sure what this tab was for... It's not the tab to keep the stock intake in place. If it's another perch to keep the hood-release cable routed, the clip was missing...) |
![]() | | #15 | ![]() |
I can see having to play around with the T clamps that connect the SRI to the TIP, but if you cannot rotate the SRI to avoid making contact with other stock bits under the hood that is not acceptable. Did you reach out to JBR and ask them about this?
![]() | | #16 | ![]() |
![]() Join Date: Feb 2013 Location: Broken Arrow, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 651
__________________ 2013 Mazdaspeed 3 VRM Cobb AP V2 / JBR SRI / JBR TIP / CP-e xFlex RMM / Forge V1 BPV / AT Internals / eBay TP / Hypnotic Tune in progress 8K Low Beams / Optilux Yellow Fogs / Plastidipped Emblems / Painted Calipers / Rear Wiper Delete / Resonator Delete Thou shall sweep the fucking popcorn and keep dicks out of thy mouth. - Dan 3:16 | |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am wondering if gen2s have a little more clearance between the filter and the inside of the hood, which might allow it to be rotated more? Does your JBR installation make contact with anything? Did you need to mess with the clamps to create clearance on yours?
![]() | | #18 | ![]() |
![]() Join Date: Oct 2012 Location: Cincy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score I can confirm with my 2012 ms3 there is rubbing at the filter (tedious adjusting will fix this) and the tip rubbed into the ecu. The ecu issue was a bear to rectify so I ended up getting different clamps, ones without the bolts. This took care of my issues there. I actually ended up taking the tip off and just use the air intake with the stock tip. I was having a weird noise when letting off the throttle, I took the tip off and it fixed the issue. No idea what it was. Also, when adjusting the filter, you can't go to high(rub on the hood) and you can't go to low(rub at the front of the car). What worked for me was pushing everything tight together more so then what the directions called for.
__________________ 2012 MS3 Silver Metallic - Hypertech - JBR stage 2 Intake |
![]() | | #19 | ![]() |
No signs of rubbing since... If I hadn't had a filter wrap, I probably wouldn't have noticed the front was making contact at all, but the fabric was beginning to wear through... Before shaving the tab, I also played around with zip ties and found I could loop one through the t-bolt clamp by the filter to the frame of the car. This worked, and stopped the filter from hitting the tab, but I wasn't fond of this solution. It's a good intake and you shouldn't regret your purchase. My problems were very minor and easily resolved -- don't confuse anything i've written as a complaint -- our engine bays are cramped, so a little fine-tuning isn't unexpected. | |
![]() | | #20 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score Just remember if it fails its your fault not the manufacturer's fault. Lol
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #21 | ![]() |
Sound issue with the TIP as well. hmmmmmm. I don't know what to say about that. What did it sound like? What I can say is, I have been under the hood of mine enough times, and have installed and uninstalled multiple intakes (with TIPs), and I agree it is tight. My CS TIP cleared the ECU cover with the width of a piece of paper, but it didn't hit. Now the supplied T clamps, that was another story! Trying to work around them hitting the harness clip was a exercise in futility. Cobb was a bit easier on both fronts. Neither, even the Cobb with a larger AEM filter ever gave me grief by touching the hood or anything else. That one is pretty lame. Couldn't the silicon between the MAF housing and the TIP be shorter? Was it easier for you to fit the SRI with the stock TIP?
| The Following User Says Thank You to mhebert2001 For This Useful Post: | Koke382 (12-03-2014) |
![]() | | #22 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score This is why I assisted fabbing an ECU relocate bracket. If you don't want to spend the coin on a small box and battery, it's a simple mod and inexpensive, and it still looks clean. This is with a 3" intake, and it has nearly 1" of clearance in all directions. ![]() The "Track Time" @RACER_X; referred to is actually Trackmasters -
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() | | #23 | ![]() |
| The Following User Says Thank You to mhebert2001 For This Useful Post: | JgamB (12-03-2014) |
![]() | | #24 | ![]() |
Our engines move so damn much with stock mounts that it's really important to have more clearance then not. Yes the fitment with the stock tip is fine and I did use the jbr clamps where the sri meets the stock tip BUT you still have to fudge with those damn clamps to get it to fit without rubbing but there is more clearance to play around with them. Due to the engine movement it's mostly important to get the intake filter situated accordingly as the engine moves forward and backward a ridiculous amount as you can see this on the intercooler plastic cover. Try and get at least 1 1/2" to 2" where the most forward part of the filter would come in contact with the front of the car and you should be good, from there make sure you have clearance with the hood. Any other sides of the filter is not an issue.
__________________ 2012 MS3 Silver Metallic - Hypertech - JBR stage 2 Intake | |
![]() | | #25 | ![]() |
(Thread Starter) | Neutral : +1 score Good info! Your feedback is a good reminder to be patient during the install, and to make sure I budget enough time.
| JBR Power Path St2 will work will with a MS CAI yes no | Marcus | MazdaSpeed 3/6 - Turbo Induction | 2 | 12-13-2013 05:59 AM |
| Power Path Stage II vs K&N/HTP | [R]usty | Gen2 MS3 General Discussion | 23 | 09-19-2013 03:16 PM |
| JBR Power Path Stage 1 SRI | swerv0428 | JAMES BARONE RACING | 0 | 03-08-2013 10:54 AM |
