JBR Trilogy - holy vibration/noise I expected a noticeable jump in noise/vibration when installing the JBR Trilogy (80a) set, but jesus it's insane at the moment. I went from stock mounts to 3-way 80a all at once, so that probably explains that. My question is - how long (on average) does it take for these to quiet down? I understand that they will never be as quiet as stock (which is fine), but I'd imagine they "settle" at some point... Also - if this thread is in the wrong sub-forum I apologize - didn't really know where to put this. |
They don't really ever settle. Should have gone with the Damond Motorsports threesome mounts. The DM mounts are still louder than stock, but much quieter than the JBR trilogy. @Farhan@DM; makes some great parts. |
They'll always be miserable. Mine were for the 2 years I had them in. |
after about 1000 miles , but you will still get some vibe though 2000 rpm to 3000 rpm but should not be as bad? |
I just turn my music up and all the rattles go away |
I have em on my gen1, and they do settle down a lot. Just need to drive it. Most searching will snap that it takes time to settle. |
Try driving with the windows down, that seemed to help lower NVH when I was still on the DM RMM. |
Welcome to the wonderful world of "racecar problems" |
I have the DM side mounts with CPE S2 rmm (same basic idea as DM rmm). Even if you go with these over the JBR it will still rattle your teeth loose compared to stock. Basically, you need to determine how dedicated you are to having a "racecar" toy. For the average modder I think a nice rmm and corksport tmm insert does perfect and has very minimal vibes. |
His racecar dedication has been confirmed with installing All mounts all at once. Quite stifled that someone would buy and install all three with researching the nvh issues, especially with the jbr trilogy, and complain about it. |
Buy some basic tools and don't make expensive mistakes. I don't even wanna know what you were charged for labor. Just install your own stuff for now on. |
I've been to hoboken many times. You could replace your motor mount in a tight parking space. |
I just don't wanna see you make the same mistake in the future. Once you research a mod and can wrap your head around it, you'll realize its pretty straight forward and doesn't require much space or even tools... It can save you money and save u from situations exactly like this. |
I DD my Speed in the summer and don't mind having the JBR trilogy at all. With the windows down I can't hear any rattles. Personally, if I were you, I might have gotten the DM mounts over JBR, but JBR isn't bad either. The only reason I went with JBR over DM is because DM mounts didn't exist yet haha. Keep the mounts, embrace the vibes, and grin from ear to ear every time you mash the throttle. |
Try living in Chicago. There's probably more speed/red light cameras than people Sent from my iPhone using Tapatalk |
Get rid of the JBR mounts and get Damond Motorsports Mounts. You won't regret it at all. I was fully mounted with CP-e, felt great, then swapped those for DM mounts. The car feels awesome, solid, and stock like to me. |
I would just swap the passenger for the Damond and the rear for the CP-E. That would quiet it down quite a lot. edit: @mrand01; forgot to mention, I've been in a Gen2 MS3 with all JBR 80 duro mounts and they do quiet down quite a lot after a while, but this takes a couple weeks for most people. |
Eventually, if you are like me, you just do not notice em. |
| All times are GMT -7. The time now is 03:52 AM. |
