 Old 04-03-2019, 06:31 AM   #1
yangliu's Avatar
Posts: 12   (View Stats)
yangliu is an unknown quantity at this point
Default jerky 1st gear acceleration with light throttle
just do a gentle taking off (around 20% acc pedal) from stop traffic light. It is not always just intermittently having this annoying issue.
car suddenly lose power for a second then back to acceleration, then lose power again and back again.
i checked logs, during the problem:
1. acc pedal drop to 0, but actual i didn't lift my foot off the pedal, just keep pressing the pedal. it seems ECU forced stop the acc pedal?
2. "closed loop" went to 1024 which usually means going into open loop
3. "desired HPFP pressure" went to 292PSI which usually means injector is off.
i attached an ap3 logs file. i highlight the problem logs:
line 74-83
line 122-130
line 193-200
i attached my tune map (you need to load the map with australian version of ATR (i uploaded to google drive, just download the zip file then unzip and run "Accesstuner_AU_MS3_BASE_09.exe")
my ATR download link:
https://drive.google.com/drive/folde...ul7n66u2XbOgW2
my mod list:
JBR 3.0" intake
one step colder plugs
autotech HPFP internal
cobb catted dumppipe
streetunit TMIC
BNR S3
injector seals
JBR 88duro RMM
DM PMM+TMM
EGR blocked
Forge V1 bpv with red spring
much appreciate!!
File Type: ptm 98 Yang 2.09 (3inch MAF cal, 3Bar, BNR_S3).ptm (43.9 KB, 1 views)
yangliu is offline   Reply With Quote
 Old 04-03-2019, 10:36 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,858
If I had to guess, it has to do with the larger-diameter intake and (perhaps) a bad MAF calibration for that intake. I have had similar low-speed, low-throttle jerkiness on a couple of my self-tuned maps, but have always been able to fix the problem by cleaning up the MAF calibration.
Vansquish is online now   Reply With Quote
 Old 04-03-2019, 03:06 PM   #3
yangliu's Avatar
I just load the base 3.0inch maf data and try to dial in again.
MAF calibrations for bigger intakes
 Old 04-03-2019, 05:57 PM   #4
Vansquish's Avatar
Groans: 1,858
Forget what I said earlier. I hadn't looked at the logs yet, and it looks like you're having some issues with your accelerator pedal position sensor or (or possibly and) your throttle position sensor. One, the other, or both appear to be reading incorrectly (I would guess that it's your accelerator pedal position sensor).
 Old 04-03-2019, 06:08 PM   #5
yangliu's Avatar
yeah, im thinking the same thing, ECU thinks I left my foot off pedal...mostly could be accelerator pedal position sensor. but the strange thing is this issue only happens on 1st gear with light throttle. i would try disconnect acc pedal position sensor can clean the plug first too see.
 Old 04-15-2019, 08:41 AM   #6
crankshaft's Avatar
Posts: 573   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Are you sure it isn't the AC compressor? I have noticed that you REALLY feel it in this car, especially light throttle first gear.
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 04-20-2019, 02:22 AM   #7
yangliu's Avatar
from logs acc pedal position sensor drop to 0, i don't think it is related AC compressor. I already changed acc gas pedal assembly, will see if this issue happens again or not.
another issue i found, sometimes when take off, around 10% acc pedal and RPM raise to 1500-2000rpm but engine load will drop to around 0.20 and the whole car is shaking. i need to depress clutch pedal to stop it and press more gas and release clutch pedal to resolve.
i raised engine load a bit from 1000rpm-2500rpm at 6.25-12.5 throttle in Throttle - Requested load A,B,C table. will update about this issue later.
Car jerks in 1st/2nd gear at light throttle NRBt Mazdaspeed3/6 General Discussion 21 04-10-2015 06:46 AM
Jerky / poor acceleration suddenly?? Help! Absolut1l MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 02-16-2013 06:35 AM
car jerking light throttle 3rd gear Kydizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 12-15-2011 12:32 AM
jerky throttle fix..... bbjoy MazdaSpeed 3/6 - ECU Computer Tuning 1 05-11-2010 08:15 PM
Jerky part throttle acceleration dread
Cobb ATR Support
38 04-25-2009 08:19 AM
Page generated in 0.27763 seconds with 23 queries
