 Old 07-01-2019, 11:19 AM   #1
hernandez1455's Avatar
Posts: 6   (View Stats)
hernandez1455 is an unknown quantity at this point
Default JMF Port injection set up?
Hi so im currently building my Gen Pu. I want to go port injection but i cant find any write ups/set ups that use the in tank fuel pump instead of using a separate fuel pump and tank for the port injection. And anyone point me to the correct way on doing this?
hernandez1455 is offline   Reply With Quote
 Old 07-01-2019, 12:30 PM   #2
Fstrnyou's Avatar
Posts: 2,480   (View Stats)
Upgrade in-tank pump.
Install TEE fitting pre-HPFP.
Run return line to....umm....somewhere.
That's a start.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-02-2019, 03:26 AM   #3
TRBLSM's Avatar
Posts: 73   (View Stats)
TRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond repute
Theres a few ways to go about it but heres a couple of links which you may find useful:
https://mazdaspeeds.org/index.php?th...up.2579/page-2
How to: Install a speed perf6rmanc3 PI Kit on your gen2
For my own PI setup ive done the following:
Walbro 460 mounted in tank (drilled a hole in the tophat for a new feed line connected to pump, stock feed line is now the return)
New feed goes to a Y block and splits into 2 lines (1 to HPFP, the other to the PI rail)
Fuel Pressure Reg mounted on the rail with retur line going back to the tank
2006 True Red 3 MPS - Top Mounted 5858 in progress
TRBLSM is offline   Reply With Quote
 Old 07-02-2019, 07:31 AM   #4
Jeff23spl's Avatar
Posts: 2,086   (View Stats)
How is the w460 reliability so far?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
My Port Injection Set Up SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 121 02-28-2019 08:14 AM
5th/6th port injection maddocx240 Mazdaspeed3/6 General Discussion 11 12-31-2017 11:09 AM
Port Injection for 2012 Realgib3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 12-19-2011 02:11 PM
Port Injection Question 6-Speed-6 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 07:02 PM
Page generated in 0.25177 seconds with 23 queries
