Like Tree10Likes
 Old 11-01-2012, 07:35 AM   #41
outshined's Avatar
Posts: 423   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
Originally Posted by DiGi Faggot View Post
I would like to point out to the dumbass known as @outshined That the Ford Focus ST also has the exact same problem with it hitting the firewall that we do.
I checked out the Focus ST RMM from JBR. See the picture in step #3 of the installation instructions that I attached. Just as I suspected, it looks like the stock RMM bottoms out in the metal cavity where it sits in the subframe. This is the SAME exact cause of the 1-2 shift "clunk" that occurs in the MS3. I can assure you that the turbo, down pipe, and/or engine hitting the firewall are not the cause of the noise.
Originally Posted by James Madison
[The Constitution preserves] the advantage of being armed which Americans possess over the people of almost every other nation...(where) the governments are afraid to trust the people with arms.
outshined is offline
 Old 11-01-2012, 08:07 AM   #42
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Originally Posted by outshined View Post
By disconnecting the RMM and moving the engine forward and backward, you are simulating the application of high torque load. You can move it forward and backward by hand through a range that's quite a bit larger than any RMM would otherwise allow.
If you remove the RMM and rock the engine
This is exactly my point. What the hell does disconnecting the RMM prove? I am not saying the stock one does nothing and we might as well remove it. I am saying it doesn't do enough, but it does help. That's what makes you sound retarded. And the little movement you get is NOTHING compared to what the car can and will do when high loads and torque is applied. So quit comparing the two like your arms are some sort of scientific measuring device.
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
GODspeed7 is offline
 Old 11-01-2012, 08:35 AM   #43
jeopardy98's Avatar
Posts: 1,920   (View Stats)
Groans: 112
I think it might be a weak stock RMM.
jeopardy98 is offline
 Old 11-01-2012, 09:37 AM   #44
pwned's Avatar
Posts: 762   (View Stats)
pwned has disabled reputation
People, please stop regurgitating what you read and spreading false information.
It is IMPOSSIBLE for the engine/turbo to hit the firewall with all three engine mounts intact.
Go jack up your car, get underneath, and remove your RMM completely. Rotate the engine fully forward and fully backward. Notice how nothing makes contact with the firewall?
The noise most people hear when they shift hard on the stock RMM is the metal portion of the RMM bottoming out on the subframe when the bushing allows excessive travel. If the RMM is removed, the transmission adapter bracket it attaches to will hit the steering rack LONG before the turbo or down pipe decides to share space with the firewall.
Do you dopes really think that Mazda would have designed the engine bay and mounts to ALLOW the engine to contact the firewall?
I was just going to say this is impossible as well but you beat me too it!
The 1-2 dunk/clunk noise on the 1-2 shift(non agressive driving) is the passenger side axle if you look at my thread i started.
Sold
-12' Ms3 // 305hp 336tq SAE
-13' CWP MS3
JBR 88a Trilogy // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs // JBR Rsb
323hp/351tq SAE
Current..
02 Regal GS-Go fast stuff-286hp/314tq 12.8 @ 108.....248k original motor/trans(Broken........Trans failed at 249,334 12/6/15)
16' Mazda 6 GT (sonic silver)
Last edited by pwned; 11-01-2012 at 09:37 AM. Reason: MSF Database - Automerged Doublepost
pwned is offline
 Old 11-01-2012, 01:43 PM   #45
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
Behind Door #1 - Itsa Axel!
Behind Door #2 - Itsa Subframe
Behind Door #3 - Itsa Hitting the Firewall.
EITHER WAY RESULT IS THE SAME. OP, ITS THE RMM.
DiGi Faggot is offline
 Old 11-01-2012, 02:21 PM   #46
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
I'm pretty sure we can throw axle out because that's referring to the noise made during non-aggressive 1-2 shifts. The OP dumped the clutch trying to spin the tires. I know the solution is just get an aftermarket RMM but I am kinda curious as to what is actually making the noise, subframe or firewall.
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline
 Old 11-02-2012, 05:46 AM   #47
outshined's Avatar
@IWannaGoFast
@duappleganger
This video from CorkSport illustrates exactly what causes the noise, and why the RMM should be the first thing everyone replaces.
 Old 11-02-2012, 06:12 AM   #48
Groans: 148
Uh.. That noise isn't a loud bang... Itsa rattle.
The engine moves quite a bit to the firewall doesn't it? The engine moves a shit ton without mounts, it is hitting the firewall when pushed too hard. Look at the crappy video.
#1 to see what happens when the OP shifts gears.
 Old 11-02-2012, 06:53 AM   #49
outshined's Avatar
When the torque load from the engine increases dramatically, such as during a hard shift, the force of that impact between the RMM and subframe causes a substantial "bang" that could not be mistaken for rattle.
The engine DOES move quite a bit towards the firewall, but those videos don't show you what's happening behind the engine. Believe me, nothing is hitting the firewall. If I have time today I'll snap some pictures with the RMM removed and the engine moved to maximum deflection in each direction so you can see that the turbo and down pipe are not in danger of contacting anything.
 Old 11-02-2012, 07:25 AM   #50
GODspeed7's Avatar
Again you will move the engine with your massive scientific measuring devices (muscles) and show us all the exact lb/ft of torque it will take to move the engine. What you don't realize is that even with the RMM removed and the other 2 in place, you alone will still not be able to move the engine nearly as much as what the torque of the car easily can. Someone get superman here some kryptonite before he starts ripping engines out with his muscles. This conversation is so fucking dumb. Someone please close this @Raider
 Old 11-02-2012, 10:44 AM   #51
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Just Christ, this is still going on?
Fuck this thread and go here:
http://www.mazdaspeedforums.org/foru...cussion-128995
Raider is offline
The Following 3 Users Say Thank You to Raider For This Useful Post:
jeopardy98 (11-03-2012), lilred (11-02-2012), silvapain (11-02-2012)
Test drove one. grunyon Mazdaspeed3/6 General Discussion 6 01-28-2012 02:49 PM
Loud Bang/Clunk noise AnthonyR42 Gen2 MS3 General Discussion 22 07-13-2011 07:23 PM
Page generated in 0.42147 seconds with 27 queries
