![]() | | #41 | ![]() |
| Not Ranked : 0 score
__________________ | |
![]() | | #42 | ![]() |
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
| Not Ranked : 0 score It is basically useless on the stock turbo because you can max the k04 out without upgrading to an aftermarket TMIC. Plus methanol does a much better job of cooling. Chemical intercooling > air to air but if you have a dyno disproving this please share.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph |
![]() | | #43 | ![]() |
Groans: 60
I really would like to see some try an E85/gt3076/hpfp internals/AP build. If you sourced the turbo used you could do the build for under $1700 and make well over 300hp even with the other parts being stock.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph | |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Going to have a car with that exact setup on the dyno next month!!!
![]() | | #45 | ![]() |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
__________________ ![]() Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
![]() | | #46 | ![]() |
![]() Join Date: Oct 2011 Location: Sarasota, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
(Thread Starter) | Not Ranked : 0 score So due to the restrictions of the k04 an upgraded TMIC will work best with a larger turbo due to flow?
__________________ Mods in order: CS SRI/TIP//JBR RMM//JBR Bushings//COBB AP//AT Internals//CS RP//UR DP//JBR Short Shift Plate//DIZZY TUNE// CS FMIC // UR CBE // Forge V2 BPV// BNR S3//3 Bar Map sensor Next Mod: meth or E85 |
![]() | | #47 | ![]() |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score Upgraded tmic or fmic either way better than stock ic
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
![]() | | #48 | ![]() |
Groans: 60
| Not Ranked : 0 score In for results!
![]() | | #49 | ![]() |
| Banned ![]() Join Date: Mar 2012 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
Groaned at 34 Times in 12 Posts
| Not Ranked : 0 score im going to say go TMIC for quicker turbo spool and better cooling than stock ETS makes good ones, FMIC if your going full out HARDCORE and dont mind the install but there will be lil more turbo lag says I. |
![]() | | #50 | ![]() |
Groans: 669
| Not Ranked : 0 score It's been proven above and in other threads that an aftermarket TMIC has the same amount of cooling as the stock one. They just have less pressure drop. I have a FMIC and I can tell you this lag you speak of is inexistent if you properly tune it out (and it was maybe 200 RPM more han stock originally).
| The Following User Says Thank You to adlpb For This Useful Post: | rfinkle2 (03-24-2012) |
![]() | | #51 | ![]() |
Groans: 298
| Not Ranked : 0 score Phate and Silvapain, is there anything that is contributed by air density with cooler bat's via meth injection? There has to be some benefit to the increased charge density. I'm not saying meth injection makes the equivalent power of e85, but I do think a meth injected car running e85 will make more power than an e85 only car. |
![]() | | #52 | ![]() |
This is why I'm so curious about the pre-turbo. It should increase the air mass into the turbo. How much, though, I'm not sure. I have a feeling it won't be significant enough to sate my desire for winter power in the summer.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #53 | ![]() |
Groans: 298
| Not Ranked : 0 score Strange, but I can't argue facts. Thanks Phate. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | phate (03-24-2012) |
![]() | | #54 | ![]() |
My opinion is ~300 g/s is all the K04 will put out period, and to get more Oxygen into the combustion chamber N2O is required. Tapadatass
![]() | | #55 | ![]() |
| Not Ranked : 0 score Beat by my slow-ass typing skills on the iPhone. Tapadatass
![]() | | #56 | ![]() |
![]() Join Date: Feb 2012 Location: Oswego, NY
Rep Power: 0 ![]() ![]() Thanks: 49
Groaned at 12 Times in 8 Posts
| Not Ranked : 0 score Any recommended setups for a daily driver. my buddy ( in his 40's) was thinking about running a meth setup to help keep his intake valves clean and lower the bat. Mind you he is stock(07 ms3). |
![]() | | #57 | ![]() |
Groans: 669
| Not Ranked : 0 score Unless he has a method to tune/monitor, I wouldn't recommend it.
![]() | | #58 | ![]() |
| Not Ranked : 0 score You think an AP with a tune? Mild tune or could it be more aggressive ? |
![]() | | #59 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score It would need a custom tune for the meth.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following User Says Thank You to G26 For This Useful Post: | Jrs7686 (06-27-2012) |
![]() | | #60 | ![]() |
![]() | | #61 | ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Just read the whole thread. Good info in here. I went stage 2 and tuned yesterday and suffice to say that shit gets hot and needs to be cooled down if I want to see 300 whp (or close to it). You can fry a fucking egg on the TMIC after a couple pulls. Thinking of getting a Snow Performance Stage 2 kit now and tuning for it for safety and performance. I'll be happy to get 290+ - 300+ on a safe reliable tune with wmi. Sounds doable? Seems like meth drops the BAT by about 40 fahrenheit. I'm in Canada... so I have to consider winter temps as well. edit: Mods include: - CPE TMIC - CPE DP (catted) with stock CBE still - CS SRI with TIH - Denso ITV 22 plugs - Autotech HPFP internals
__________________ [SIGPIC][/SIGPIC] |
![]() | | #62 | ![]() |
Groans: 669
__________________ ![]() Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq | |
| The Following User Says Thank You to adlpb For This Useful Post: | Elusivellama (07-15-2012) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score One thing I'm still not clear on is the safety net of meth kits. Is there a safety net? Suppose you run out of meth for whatever reason (pump fails, nozzle fails), what is there to prevent your meth-tune from causing your engine to eat itself? Serious question, not rhetorical.
![]() | | #64 | ![]() |
![]() Join Date: Jan 2012 Location: Littleton, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 675
| Not Ranked : 0 score How friendly would a dealer be if they saw a meth kit?
__________________ Mods: SOLD and Blown up by Dantes: 2007 MS6 ATP GTX3071R EWG hot side, Autotech HPFP internals, Ebay DP, Cobb AP, Cx-racing FMIC, CPE BT inlet, SSP 3.25" MAF, Turbine tech front motor mount, etc... 2008 Mini Cooper S- Ask Voltron about Minis, he has one too. |
![]() | | #65 | ![]() |
| Not Ranked : 0 score ![]() ^ this friendly
![]() | | #66 | ![]() |
I've said this many times on here: the only meth kit I would run is Aquamist. It uses a real controller and injector instead of just an orifice. Both the Snow and Devil's Own kits can leak and cause hydrolock. Tapadatass
![]() | | #67 | ![]() |
![]() | | #68 | ![]() |
Indepth study of WAI injection systems -restart - NASIOC Reading it now
__________________ [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to Elusivellama For This Useful Post: | silvapain (07-15-2012) |
![]() | | #69 | ![]() |
![]() Join Date: Mar 2011 Location: Elyria, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Reviving a little bit of an old thread, but has anyone tried the cryo2 kits? They have an inline bulb that will cool intake temp and theoretically provide denser air if mounted before the maf increasing g/s overall then the liquid co2 would be used for tmic/fmic dump that would significantly drop bat's... Still a refillable item/ cost... But no risk of hydrolock and can still have a controller for bursts or wot runs... Hmmm
__________________ CS LED kit, Aux input, Sure TIP, Sure SRI v2, Sure RMM, Turbosmart BPV, IVT22's, Prosport Boost gauge, JBarone SSP v2 and counterweight, H&R Drop Springs, Bilstein Shocks, Cobb AP, Sure M6, Sure Juggernaught, Sure Dreadnaught, Whiteline RSB, DSS axle, AT internals, Sure Charge Tubes. Currently getting DIZZY tuned! |
![]() | | #70 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score you do know that co2 isnt combustible right?
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
| C.S. TMIC + Meth | kritz | 2010 MS3 - Fuel, Nitrous & Water Injection | 3 | 09-26-2011 10:36 AM |
| TMIC w/Meth vs. FMIC w/Meth | adlpb | 2010 MS3 - Turbo Induction | 95 | 09-10-2011 05:32 PM |
| HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC | Chimmike | MazdaSpeed 3/6 - Turbo Induction | 6 | 07-04-2011 03:18 PM |
