Laser Jammers Can anyone validate how well laser jammers work? I'm looking into a couple different brands, specifically the Escort Qi45 or some shit like that. Just wondering if anyone owns a jammer and has it ever saved your ass? Thanks in advance. |
The only ones worth a shit are Blinders. The new ones that use laser diode LED's should be excellent, but even the older models worked except for the close range "punch through." I think he's an approved vendor here. Check out RadarRoy for independent test. I haven't been there in awhile, but there was good information there. |
I've got the M27 Blinder kit. I absolutely guarantee it works. 70 in a 50 when I was hit. Had the warning up so loud that by the time the wife came down off the headliner I was under 50 and turned it off. Left the LEO sitting up on the on ramp looking at his gun/me/gun/me. Wish I'd have had a vid camera. Priceless. |
haha nice ^^ the thing that worries me is that if a copper catches you speeding and your laser jammer actually does work. if he is a dick and thinks you were over the limit or even worse using a jammer he will just pull you over anyway |
FYI, they are AV here, too. |
Do you need a radar detector in addition to that, or is there a radar detector integrated with that particular jammer system? I know some are separate. I've read that jammers are only illegal in a handful of states. Why turn it off it its not illegal in your state? Doesn't sound like there's much they can do about it. Quote:
You turn it off after you slow quickly down to the speed limit to make the LEO think it was an error on his part or in his equipment. If you jam the entire time, then it'd pretty obvious what's going on. The cops know about jammers and will pull you over if you blatantly jam their gun; it becomes even more obvious after you drive by and they can suddenly lock on to the side and rear of your vehicle. While they are not technically illegal in most states you can be cited for various violations up to and including obstruction of justice. Whether or not they hold up in court is another thing altogether. The system I've used has a "parking aid" mode which works as a rudimentary perimeter alarm. I'm sure you can imagine what that could be used for when approached by a curious and/or pissed off cop... |
For those who are interested; you can look up your state to see their laws on jammers and radar detectors, if you don't already know. Helpful Information About Radar Busters - RadarBusters.com |
Here is a link to a good jammer test: Radar Detector Tests and Reviews by Guys of LIDAR - LASER |
FWIW I looked at some test results; that Escort Qi45 didn't perform nearly as well as the Blinders. Here's a test of the Escort: Review: Escort Passport Qi45 radar detector Here's a test of the Blinders (old test; the new ones should perform even better): Active Laser Jamming Tests - RadarBusters.com |
Or am I missing something? More or less, I can't go pissing away a fuck ton of money that I don't have. And realistically, not that I'm proud to say it or anything, but I'm never going to drive the speed limit. Its impossible for me to drive the speed limit, every where, every time. |
That's a good one too. I'm pretty hyped about the new Laser Diode LED's used in the Blinders; much higher output. |
Subbed! |
I wish....I can't afford them. Besides, not much Lidar in Arkansas. I can only quote tests/reviews. |
As some others have indicated, you need a multi-band detector like the V-1 or STI Driver. I was in MI and was under the impression that detectors were illegal there, so I had gotten an STI Driver (invisible to detector detectors). Yeah, it was going off, too, but not nearly as loudly as the Blinder. I run the V-1 most of the time cause I'm used to the arrows. |
I'll be pulling a QI45 off my car this week.... |
I'm just trying to understand because you stated that you need a radar detector, but that the blinder was going off, which to me would mean that you technically don't need a radar detector to have a functioning Blinder jammer. Unless I'm missing the fact that the Blinder can't function without a radar detector for one reason or another. |
I have run with a Laser Interceptor for years and have had many saves. In fact two in the last 2 days, today I got the look at laser gun, my car, laser gun. I was obviously over the limit 90 something with decent traffic. When I had this on my BMW X5 it worked from less than 200ft. The Laser Interceptor works independently from a radar detector with audible warnings so it could be used stand alone, but I run with a V1 as well. |
You have any issues with the damn Infinity cars with the active cruise control that uses laser for measuring distance? I have jamming for the rear as well and it drives me nuts when these dudes are behind me. Just hope its reeking havoc for them when I am jamming them. |
You need a radar detector to detect....uhhh.....radar. These laser jammers only jam laser. Jamming laser isn't illegal in most states. Jamming radar is. |
I've read that the laser jammers have no effect on adaptive cruise control systems. I imagine they are not in the same spectrum as law enforcement grade lasers, although they'll still set off the warning. |
The reason the wife overreacted was I had the volume of the Blinder set too high. So, in a nutshell, if all you are worried about is laser, go with the Blinder, it will warn you. Everything else, KA, K, Pop, etc., you need something additional. |
I doubt all the troopers in MD are using laser; that shit is expensive! |
I've been running an Escort 8500 x50 for a little while and I'm looking at buying a laser jammer because the State Patrol and my local town have both recently switched the LIDAR. What do you guys think of the Escort radar detectors? I bought it because it was the #1 on Amazon a few months back. It's been great but now I'm interested in what the V1 and such can do. |
Laser interceptor releases updates often. Dont know about blinders. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
| All times are GMT -7. The time now is 04:43 AM. |
