  • 1 Post By atvfreek
 Old 01-28-2012, 10:21 PM   #1
OG Prostitute
shopety2012's Avatar
Posts: 1,055   (View Stats)
shopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the world
Groaned at 68 Times in 40 Posts
Default Launch Help
Ive searched but maybe i didnt search right? Anyways i cant find anything so im going to post for me and the other track noobs out there... in the quarter mile what is the best way to launch? and what is the best rpm to shift at with basically a stock MS3..
i would also like to know your times and mods to kind of compare... i have a sure short ram intake on my MS3 and my first time ever on the track tonight... i ran a 14.6
HELP
shopety2012 is offline   Reply With Quote
 Old 01-28-2012, 10:47 PM   #2
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Bump, I'm wondering the same thing as I might be hitting the strip in february for the first time.
Sent from my BlackBerry 9300 using Tapatalk
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 01-28-2012, 10:49 PM   #3
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
do you have an AP (accessport) if not. get one now. Set your launch controll to 3200
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
 Old 01-28-2012, 10:49 PM   #4
MS3MYK's Avatar
Posts: 1,967   (View Stats)
MS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the worldMS3MYK is the leader of the world
Launch at 3k but remember to lower the tire pressure to help gain some traction(can't remember what psi though) and shift at 6k since the car falls flat on its face at 5800rpm.
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes
MS3MYK is offline   Reply With Quote
 Old 01-28-2012, 10:50 PM   #5
blakkat's Avatar
Posts: 572   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
feather the clutch from 3000 rpms, and shift at 5500
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
The Following User Says Thank You to blakkat For This Useful Post:
BobbleHead (01-29-2012)
 Old 01-28-2012, 10:52 PM   #6
Schmitty5's Avatar
5500 ? nope. 5800, and technically mazda claims the gen2s dont run out of power till 6000, but I'll back that up witha dyno in a couple weeks.
5500 seems a bit early...
 Old 01-28-2012, 11:26 PM   #7
The Panda's Avatar
Posts: 1,229   (View Stats)
Groaned at 8 Times in 7 Posts
AP launch control you be fine if you dont have mounts dont drop the clutch though....lol
The Panda is offline   Reply With Quote
 Old 01-28-2012, 11:56 PM   #8
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
Wtf is everyone talkin about launch control?
Judging by ur post u must b on stock tires, in which case launch control should only b used to sound fast and get bitches.
To launch this car, even stock, keep ur rpms are 2100, slip the clutch while adding throttle at the same time(not more than 75% throttle), lift shift to 2nd gear at around 5500rpm, then go wot and ffs at 5800 the rest. depending on the weather and track prep u might wanna throttle control second gear if ur spinning too much. practice makes perfect, itl take a couple times to get used to slipping the clutch. But ive nailed multiple 2.1 60fts with that meathod on stock tires/suspension/ motormounts.
Lol @ launch control on stock tires.
Sent from my left nut.
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
The Following 4 Users Say Thank You to 2011speed For This Useful Post:
atvfreek (01-29-2012), fortressofcomfort (01-30-2012), helmetface (01-29-2012), SLOWHATCH (01-29-2012)
 Old 01-29-2012, 12:26 AM   #9
OG Prostitute
Thanks a lot
stock as fuck gay blue pu, still haz juan tranny and evox wheels in shocker yellow tho
currently forging a monster sr20det LS swap killer... brb
used to be the "best looking life partner blue ive seen" - Voltron
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM Dad -- FYCN
 Old 01-29-2012, 07:09 AM   #10
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
2011speed and the other guys gave great advice, and searching username driver311's posts / threads concerning the strip will give you some more great tips.
BobbleHead (01-29-2012), SLOWHATCH (01-29-2012)
 Old 01-29-2012, 08:02 AM   #11
atvfreek's Avatar
Posts: 7,787   (View Stats)
I launch the same way as 2011speed, I hold the throttle steady around 2k, have the clutch pedal raised just a little so its about to engage, then feather the throttle as you release the clutch. Wot in 1st will spin the Shit out of the stock tires and get you nowhere fast. Then shift a little before 6k and max out 4th gear for the finish.
P.s. step on it at the last yellow. If you go on green, you're fucked.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
2011speed (01-29-2012), rfinkle2 (01-29-2012)
 Old 01-29-2012, 08:17 AM   #12
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
LC before slicks = going nowhere fast
 Old 01-29-2012, 08:20 AM   #13
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
I ran 13.8 stock. The trick I found was to hold the rpm about 3000 RPM under light throttle. Then on the signal feather off your clutch and slowly ad more throttle. I wouldn't wot til 2nd or 3rd, depending on conditions. This should get you a decent 60ft. Launching a FWD car is very difficult and although I'm alright at it, @driver311 is probably the best on this forum so I would check his threads to see if he has any advice for street tires.
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
The Following User Says Thank You to BobbleHead For This Useful Post:
 Old 01-29-2012, 08:33 AM   #14
hank25's Avatar
Posts: 71   (View Stats)
hank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant future
Hmm didn't know the ap had launch control. Interesting
Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ
hank25 is offline   Reply With Quote
 Old 01-29-2012, 08:34 AM   #15
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
Well you want to start with tire pressure...that's the key to getting traction. Think...if the tires are at 33ish psi, they're full so they can spin. Now, you lower that to say 17 psi, that's going to create a bit of flatness/softness in the tires. This way they cant completely spin. They'll more hook up.
Next, like everyone said, you need throttle control. Personally I do it like a normal take off, with higher rpm, and slipping the clutch a little more. It's better to take off slightly slower than to break loose, because then you're going to stand still for 2 seconds spinning. Launch control is more for slicks, but if you know how to use it with throttle control it can be done on the stockers. Its about timing.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following 3 Users Say Thank You to Payne Racing 67 For This Useful Post:
dantes5823 (01-30-2012), rfinkle2 (01-29-2012), SLOWHATCH (01-29-2012)
What RPM to launch at? D08SPEED3 MazdaSpeed 3 - Engine, Transmission & Driveline 19 11-29-2010 07:23 AM
Best launch technique with LC? bast525
Cobb ATR Support
16 09-13-2009 08:31 PM
WTF?!?!?! I can't launch!!!! 94jedi Drag Racing 29 07-08-2008 12:28 PM
Page generated in 0.35834 seconds with 32 queries
