-   -   Leak of burnoff??? (http://www.mazdaspeedforums.org/forum/f544/leak-burnoff-152864/)
jguthrie03 08-14-2013 12:17 PM
Leak of burnoff???
I just installed my dp/tp and now I am getting smoke where the downpipe connects to the turbo. I can't tell if it is leaking or that is the PB blaster burning off. Did any body else have a similar problem? I used the stock gasket because it looked to be in good shape. Car only has 11k on it.
If it is visibly leaking there, would that throw a CEL or no?
Mortose 08-14-2013 12:19 PM
wait a day or two. See if its still there.
Code Monkey 08-14-2013 12:20 PM
I had a burning smell as well, lasted a few days, then it was gone. Hopefully it is the PB blaster burning off.
4RGED 08-14-2013 12:21 PM
ive put 4 diff DP's on my car, done that every time for about 2 days after install, its just the lube burning off
jguthrie03 08-14-2013 12:26 PM
It really looks like a leak to me. With my hood up it comes out around the intercooler. With the hood down its coming out of the scoop.
It doesn't sound like it is leaking however. I would assume a leak that large would be able to be heard. Thoughts?
Mortose 08-14-2013 12:27 PM
does it smell like exhuast, or like PB blaster? like everyone said, its most likely the lube burning off. mine did the same thing for about a day.
jguthrie03 08-14-2013 12:30 PM
It doesn't really have a smell. I would say more like exhaust but that's probably me being paranoid. If it was a leak, how long after the car is shut off would it still come out? I'm assuming there isn't much pressure since I am catless and it would stop immediately. I could be wrong though.
crankshaft 08-14-2013 02:39 PM
It's the PB blaster, coating on the new part, skin oil that you put on it, etc etc.
Give it a few heat cycles, then report back.
manila 08-14-2013 02:57 PM
PB Blaster
Goodrich27 08-16-2013 05:59 PM
I just installed cs rp and cbe sprayed pb blaster all over that mother. Did it two days ago and the burnt rubber smell is just now starting to fade.
Sent from my iPhone using Tapatalk - now Free
jguthrie03 08-16-2013 06:04 PM
Yeah, turns out it was the pb blaster.
Page generated in 0.17453 seconds with 11 queries
