-   -   a little help with rmm install please. lol (http://www.mazdaspeedforums.org/forum/f544/little-help-rmm-install-please-lol-101516/)
SmoothVanilla 01-06-2012 05:17 PM
so I was getting prepared to install my rmm today and quickly found out that there is no damn way im getting my jack under there lol. Not a big deal, my last car was the same. So I went to canadian tire and bought some ramps. they looked low enough but of course they are not lol. So I came on here and did some research and it seems some ppl have had some errors when trying to jack this bad boy up. My question is if I had an extra jack and a friend, could we both jack up the car on each side at the same time to get the jack stands in place safely? I was reading it wasn't safe to jack up one side at a time, but I don't see why this would not work...so if I am wrong please let me know so I don't die or wreck my car lol. Thanks and again sorry for noob post.
IPuOnU 01-06-2012 05:25 PM
Screw a couple 2x4's together in a waterfall effect, done. Had to do this for a long time cuz I couldn't afford a low-profile jack for my firebird.
Sid3wayS 01-06-2012 05:36 PM
If u had to change a tire would you jack up the whole car or just the 1 side with the 1 jack that is supplied? Just use what u have. Lift up one side place the stand under the carthen go to the other side and repeat.
Scoobs 01-06-2012 05:53 PM
Canadian Tire sells a ramp extender that goes on the standard metal ramps. I have those and it's good enough. They're red in color.
Scoobs 01-06-2012 06:00 PM
Car Ramps, Truck Ramps and Extensions <----------Like these.
Or these! http://www.raceramps.com/
bigriver 01-06-2012 06:04 PM
I used a scissors jack from my truck since it has the long extensions for the crank handle. I slid the jack under the brace next to the oem side jack points and cranked the handle from the front if the car. Then i put the jack stands at the oem side jack points.
I also have low profile Race Ramps which are 67" long and in two pieces on each side.
HavasuSpeed3 01-06-2012 06:07 PM
the way I do it is... use the OEM scissor jack on one side... once it's up, from up front use a floor jack... take scissor jack out and replace with stand... then go to the other side, which is high enough now to skip the scissor jack part. Thats what works for me.
Nliiitend1 01-06-2012 06:09 PM
I just use a couple of pieces of 2x4 that have been angled on one end in front of my ramps to get onto them... This even works with my coilovers.
:dunno:
...and buy one of these too:
Aluminum Floor Jack - 1.5 Ton Aluminum Racing Jack
http://www.harborfreight.com/media/c...mage_11652.jpg
Scoobs 01-06-2012 06:16 PM
:dunno:
I love my low profile jack, gets the job done. Jack stands cost little, but for oil changes ramps are the best. Just make sure they don't slide away on you. Always good to have a spoter,my wife helps me a lot when it comes to working on the cars.
PureDrive 01-06-2012 06:21 PM
This is what I do as well. Surprised me the first time I went to put the car up on my ramps, but luckily I had the wood lying around.
StayBroke 01-06-2012 06:28 PM
if your doing rmm just jack the driver side up with the supplied jack and you can get to it. what i did and it didnt take to long.
Jake5713 01-06-2012 06:50 PM
hope you used jackstands
if not
:chairshot::chairshot::chairshot::chairshot::chair shot::chairshot::chairshot::chairshot::chairshot:
StayBroke 01-06-2012 06:52 PM
fuck it lol
Scoobs 01-06-2012 06:53 PM
Jack stands cost so little and takes a few seconds to put under. If it falls you fail for ever!
Jake5713 01-06-2012 06:58 PM
Originally Posted by chudson91 (Post 1197664)
fuck it lol
you sir are why natural selection is necessary and will ultimately claim you
Nliiitend1 01-06-2012 07:04 PM
if not
Lol.
There's really no need for jackstands with a scissor jack.
You guys crack my shit up. http://forums.focaljet.com/images/smilies/laugh.gif
Jake5713 01-06-2012 07:12 PM
Really
I stand corrected sir
My apologies
I still don't trust it though
I am here: http://maps.google.com/maps?ll=44.739736,-93.107916
-Jake
JmkC 01-06-2012 07:16 PM
Josh really?? @SmoothVanilla
SmoothVanilla 01-06-2012 07:30 PM
all good ideas guys thanks for all the help and zero flame lol. and ROFL at the chair shot.
so is everyone saying I wld be safe to lift one side all the way up and place the jack stand, then repeat on the other side??
Scoobs 01-06-2012 07:34 PM
Part are fun to buy, but tools are great too.
Pendarus 01-06-2012 07:46 PM
I didn't feel like paying for a low profile jack...so I built some ramps out of some 2 x 12's so I could get to the front jack point with my regular jack. Cheaper than other solutions I've found. I've never felt comfortable jacking up a car from the side...I dunno why...just never liked doing it.
http://www.mazdaspeedforums.org/foru...2/#post1182932
Easter Bunny 01-06-2012 07:50 PM
Originally Posted by Nliiitend1 (Post 1197681)
Lol.
Until you rock the car trying to loosen a bolt and the car rocks enough to tip the jack. If you are working under a car the only safe way is ramps or jackstands
SmoothVanilla 01-06-2012 07:51 PM
the place I plan on doing the install has a low pro jack I believe. So I should be able to get that bastard underneath the middle if I have to.
JmkC 01-06-2012 07:53 PM
where is this place
SmoothVanilla 01-06-2012 08:02 PM
one of the companies I do work for has a workshop and they have one of those there. The owner has a shelby and he changes tires and stuff there.
Stingray69 01-06-2012 08:03 PM
I got a low profile jack from harbor freight 1.5 Ton Lightweight Aluminum Racing Jack with Rapid Pump® . This one has a higher lift than the one mentioned above. I cut a small square of 2x4 to put on top of it (to prevent bending the metal) and use the factory jack location. Jack one side high enough to put a piece of 2x6 under each fron wheel. At this point you can put the jack under the center cross member under the X stamped in the cross member. I also painted the X with some orange fingernail polish to find it later. You can raise the front up high enough to put a jack stand under each side at the factory jack location. I am reluctant to use ramps on this car with the stick and low stance. You have bigger balls than me crawling under a 3200 pound gut smasher with a rinkydink scissors jack.
Nliiitend1 01-06-2012 08:11 PM
Fair enough. I suppose I was also envisioning the few times that I've had to get under cars on the side of the road, where I of course had a wheel/tire removed and placed strategically under the edge of the vehicle as a failsafe...
Raider 01-06-2012 08:25 PM
I've witnessed scissor jacks tipping over. Yikes!
Jake5713 01-06-2012 08:26 PM
and I correct myself once more
my first statement stands
SmoothVanilla 01-06-2012 08:34 PM
^^^this is true lol
Nliiitend1 01-06-2012 09:48 PM
Well shit, I've witnessed jackstands tipping over as well. Doesn't make it the norm.
:tongue:
Easter Bunny 01-06-2012 09:49 PM
I have also seen a scissor jack straight up collapse, tire under car is always safer too
Dash08 01-06-2012 11:05 PM
Lifting one side at a time is dangerous?
News to me. Been doing it for years on cars too low for clearance.
Do it. It's fun, you get to see how rigid the car is.
MS3's are cool. The chassis is so solid, the whole side of the car lifts up.
bigriver 01-06-2012 11:19 PM
These work great. Expensive, but cheaper than a trip to the ER
Bob-o 01-06-2012 11:21 PM
http://fatlace.com/lacedup/wp-conten...1.26.10-AM.png
I jack my car up on one side, and its fine.
ArcticSpeed3 01-06-2012 11:43 PM
More pics of this car?
Bob-o 01-07-2012 12:05 AM
He's gone through a couple different set ups, and he has more camber and is low enough to make MSF want to kill, but ask and ye shall receive...
http://farm5.static.flickr.com/4067/...d9d24725_o.jpg
http://farm5.static.flickr.com/4034/...420d31cb_b.jpg
http://farm6.static.flickr.com/5167/...b7b0db97_o.jpg
http://farm6.static.flickr.com/5126/...dee68cb2_o.jpg
http://farm6.static.flickr.com/5249/...73886706_o.jpg
Nliiitend1 01-07-2012 10:46 AM
That white setup just looks fucktarded. I guess I just don't understand how that even approaches being aesthetically pleasing... :dunno:
Jake5713 01-07-2012 11:33 AM
This
Like the wheels
Hate the camber
Ick
I am here: http://maps.google.com/maps?ll=44.739791,-93.107853
-Jake
SmoothVanilla 01-07-2012 03:13 PM
thanks for that pic of the car fucking floating lol. THAT didnt make you nervous the first time you ever did it?
Page generated in 0.23450 seconds with 11 queries
