Loss of power / responsiveness Hello all, I have strange issue with my 13Pu 3000miles that happened twice already. So first time it happened when car was completely stock. It feels like the kick in the ass when turbo spools is gone…. Also Accel Pedal is not as responsive anymore, car is not as aggressive as before it is not accelerating as quickly and violently as before. So first time i thought ok car is really new and it might need to break-in…. After driving it like that i thought i just got used to the car and decided to install JBR SRI+TIP and car became really responsive again, you could feel kick in the ass when turbo spooled. After that i Flashed it with S-OTS stage 1 map and car felt awesome. So fast forward to 2 days ago, i was driving and then all of a sudden car stopped being responsive and acceleration is not as violent anymore. I reset the battery hoping this will help but had no success, i found one post http://www.mazdaspeedforums.org/foru...iveness-85444/ that describes what is happening to my car. Please help :) |
Step 1, take a datalog. Step 2, post said datalog. 3rd and 4th gear pulls. Got upgraded hpfp? |
1 Attachment(s) Quote:
I was able do do a 3rd gear WOT pull, please take a look at the attached log. Im running stock FP i have Autotech sitting on my table waiting to be installed. Kind REgards, |
By the way this is the link to the datalog that i ran when car felt very crisp. Now when i look at them they are almost identical as far as the speed and time it took to get to 65mph. http://www.mazdaspeedforums.org/foru...ap-wot-164929/ |
you just got used to it... |
What is your targeted boost at? Your boost is pretty low and you start running pretty rich. I am going to guess at a possible boost leak? |
Get a tune. |
It could be due to the temperatures if your desired Load is less than 1.8. The colder temps will allow you to get to a higher load with less turbo spool. I think you should have someone take a look at your map. |
@untitledav; I see you are running lean at the beginning of your run till about 3200RPM. AFR's are 12.94 at 77% throttle position and 14 psi of boost. Don't think that's normal. Try a different map. See if it makes a difference. |
Warmer weather will do this not saying this is your problem but something to remember Sent from my phone whilst bojanglen. |
Don't go WOT under 3k RPM. Boost is very low, and you're running very lean. |
I had S-OTS map loaded for a month already, and had no issues. I will Try Cobb OTS Map, but do you think that OTS map is a good choice for JBR SRI+TIP? |
Get a HPFP and hit up any of the E-tuners on this site. Adding power mods without proper supporting mods and feeding your car one-size-fits-all OTS "tunes" will only get you so far. |
I flashed the car with Cobb Stage 1 OTS 93 and car feels much better than yesterday, boost is going now up to 18PSI But i still think this is strange because S-OTS map felt really strong. This weekend i will install HPFP. By the way what is OTS SF Map?????? Thank you all for your help!!!! |
COBB Tuning - MAZDASPEED3 SF Intake Kit This is the SF Intake. I suggest you drive 50-100 miles and then do a MAF Cal log so we can see what your LTFTs are. |
Thank you for your input! |
http://www.mazdaspeedforums.org/foru...torial-138781/ Start with this Tutorial. Don't worry if you don't understand everything that they are talking about right away. As you begin doing things like the MAF Cal, you will really start to pick up what is going on. ATR has some really nice little graphs that can illustrate what you are doing with these tunes. As you do your logs you will see how your car reacts to different weather conditions and fuel. What you need to understand is that people are not going to want to help you if you aren't putting in the effort yourself to find this information. If you really get stuck with something specific, then it is good to post your question in a thread that is related. If you are asking for someone to do everything for you, then you are going to be ignored. |
The S-OTS maps are load based configurations, so with a temperature drop you could be achieving the load targets with less boost required. So it might "feel" slower, but is actually performing the same (load wise). Other than that, check for leaks and take more logs (4th gear preferably). I would also stick with the S-OTS map if it is performing well. It is designed for the JBR pp intake, and is far superior to Cobb maps. |
I checked for leaks and loose 'bolts' and everything is in order. I just wonder why car became slower and less crisp after a month of running S-OTS |
Does that makes sense? Thank you! |
That being said, a map doesn't change once it's flashed, so a drastic change in performance would almost definitely be a mechanical issue. Flashing different maps is just disguising it and making it harder to diagnose. |
Thank you |
Logs logs logs. |
or like i said, you got used to it as well. i have so many people ask me to review logs because they think their car got slower, when in reality everything is running perfect. the s-ots maps are load based and will aim to produce the same calculated load in all conditions. you should go into the archives on cobbtunings website for a map with the jbr intake, the cobb intake values are much different than most, typically you will just run rich with the cobb values flashed. they are typically about 10% off. |
So running Cob Stage1 OTS SF with JBR SRI+TIP stuff will run rich? Thanks |
So quick Update: I flashed the car with S-OTS map and car runs great, I'm not sure what happened in the first place but flashing car resolved the issue. |
| All times are GMT -7. The time now is 05:15 AM. |
