 Old 05-13-2019, 09:03 PM   #1
StronkRiberoni's Avatar
Posts: 1   (View Stats)
StronkRiberoni is an unknown quantity at this point
Default may have overfilled Manual Transmission?
I swapped out my manual transmission fluid for Redline MT-90. I know that the user manual for the speed 3 says that the transmission takes about 2.6 quarts of fluid, so I bought 3 quarts of the Redline. Everything went fine, but i had read online and seen online countless times that you're supposed to fill up the transmission through the fill hole until it starts to overflow. First two quarts, no problem. I get to almost all of the bottle gone on the third quart, and it never overflowed through the fill hole. I was really confused, but I figured i probably shouldn't put in anymore despite it not overflowing, so I put the fill bolt back on. I'm now conflicted because I know that overfilling a manual transmission can cause damage, but I've ALSO read that you need to keep filling it until it overflows. So what do I do? I took it out for a drive, everything seems fine other than the LSD whine that comes with switching to the Redline.
Yes, I put the Redline in the correct hole. I didn't put tranny fluid in my engine or otherwise. And yes, the drain plug was on before I put in the new fluid. Thank you!
StronkRiberoni is offline   Reply With Quote
 Old 05-14-2019, 05:41 AM   #2
san1234's Avatar
Posts: 18   (View Stats)
san1234 is an unknown quantity at this point
I imagine that as long as you put the correct amount in, and maybe a tiny bit extra, you should be good.
san1234 is offline   Reply With Quote
 Old 05-14-2019, 08:35 AM   #3
SaveMelMac's Avatar
Posts: 474   (View Stats)
SaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the world
Was the car on a incline or did you have it level when you were filling it up?
SaveMelMac is offline   Reply With Quote
 Old 05-14-2019, 08:58 AM   #4
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,789   (View Stats)
The only way to fix that is to fill your mouth with tranny fluid and release it into the tranny with a straw until it overflows.
Take it from me. I am orange so I am an expert at this.
Bro fill that shit up till it overflows. Nothing else to it. You will not blow the gear box to smithereens if you overfill it a little.
MAKE LOVE TO THE CANVAS
 Old 05-14-2019, 09:17 AM   #5
Db09ms3's Avatar
Posts: 347   (View Stats)
Groans: 75
Fill that tranny up like you're feeding those fat bitches from those A&E shows until you get a trickle on the ground
Stockish
 Old 05-15-2019, 07:24 PM   #6
Suzkuz's Avatar
Posts: 9   (View Stats)
Suzkuz is an unknown quantity at this point
Actually just did my MTF today.
I used a level on the bottom of the oil pan and my jack to get it (almost) perfectly flat. It took ~2.7 before it started to leak out. I still have the 3rd bottle so I guess I could go check tomorrow how much exactly I put in.
Suzkuz is offline   Reply With Quote
The slow death of the manual transmission Haltech Automotive News 0 12-02-2016 06:40 AM
New to MS3 and manual transmission questions. Matay726 2010 MS3 - Engine, Transmission & Driveline 24 02-27-2014 07:48 AM
Could my transmission be overfilled from the factory? J.Dy 2010 MS3 - Engine, Transmission & Driveline 1 10-21-2012 05:16 AM
spesific transmission manual Joern MazdaSpeed 6 - Engine, Transmission & Driveline 12 06-07-2010 11:39 AM
Manual Transmission rebuild manual Doc-1 MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-07-2009 07:57 PM
Page generated in 0.26528 seconds with 25 queries
