Like Tree39Likes
 Old 03-06-2014, 01:54 PM   #81
jrotaryb's Avatar
Posts: 416   (View Stats)
jrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the world
Groaned at 17 Times in 5 Posts
Originally Posted by 12blkms3 View Post
I thought it was weird seeing that the majority of the community excluded cat backs from their mod list on k04 applications. Me included, just went with the flow!
Even in the Honda community most members ran 3in cat backs for K series motors!
I have an appointment with an exhaust shop tomorrow, I am going 3in mandrel bent just havent decided what muffler (if any). I'll report back with my findings.
That's surely an apples/oranges comparison. The N/A K series motor STARTS making power where our turbocharged motor starts trailing off.
If I remember correctly, the 3 inch exhaust on a K20 is wasted unless it's connected to a decent race header. Those guys also use 3.5-4.0" intakes with good results, even on stock cams! The stock head just flows that well...
pedal2plastic.wordpress.com
The driving game blog
Liquid Silver 2011 Mazdaspeed 3 w/ Tech Package
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
jrotaryb is offline   Reply With Quote
The Following 3 Users Say Thank You to jrotaryb For This Useful Post:
12blkms3 (03-06-2014), Easter Bunny (03-07-2014), rfinkle2 (03-06-2014)
 Old 03-06-2014, 04:52 PM   #82
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
There are several variables to consider here. If the tune is not changed, a CBE will often result in higher boost so many of these dynos and pulls are not 100% consistent in measuring just the decrease in pumping losses. However the fact that you get a bit more boost is a legitimate gain from an exhaust.
Due to higher pressure differential across the turbo you will need a lot less WGDC for the same boost and it may even creep in the cold especially if catless.
My example is about as pure as possible of showing the pumping loss differnce as it was a GTX3071 at 100% WGDC in both cases where the weak link was my stock BPV leaking...
Same ambient temp, same road, same tune, and same boost...
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
Easter Bunny (03-07-2014), Justin@Freektune (03-08-2014), Lex (03-06-2014)
 Old 03-06-2014, 04:58 PM   #83
My results mirror exactly what you're seeing. The gen2 however looks like sees higher gains due to a more restrictive OE exhaust.
 Old 03-06-2014, 05:01 PM   #84
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
Definitely, imo.. but without a resonator, that shit will be LOUD.
Like this?
MZRSPEED and Putin 2.3T like this.
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
The Following 5 Users Say Thank You to Zdraveca For This Useful Post:
12blkms3 (03-06-2014), bstover17 (03-07-2014), covelife1016 (03-06-2014), CrawlingMS3 (04-03-2014), Easter Bunny (03-07-2014)
 Old 03-06-2014, 05:04 PM   #85
Love hearing the turbine spool up and down but that must get tiring on a long drive.
sidekick (03-07-2014)
 Old 03-06-2014, 05:10 PM   #86
Zdraveca's Avatar
Groans: 145
its actually not that loud inside at all. I was expecting to hate it at highway cruising but one can actually live with it
GT2876r
E85 FREEKTUNE
 Old 03-06-2014, 05:17 PM   #87
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Originally Posted by Zdraveca View Post
That is nasty!!!
Sent while granny shiftin' and not double clutching like I should
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
The Following User Says Thank You to HawkeyeGeoff For This Useful Post:
Zdraveca (03-06-2014)
 Old 03-06-2014, 05:33 PM   #88
12blkms3's Avatar
Posts: 735   (View Stats)
12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world
Groans: 68
Groaned at 62 Times in 29 Posts
Your neighbors must hate cold starts.
[SIGPIC][/SIGPIC]2012 Black Mica
JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers
324whp 368tq Vdyno CF 1.01
268whp 300tq AWD Mustang Dyno
3 GAL. E85 mix STRATIFIED
13.10 @ 108.1 (Nt05's) Auto Club Speedway
12blkms3 is offline   Reply With Quote
The Following User Says Thank You to 12blkms3 For This Useful Post:
 Old 03-07-2014, 02:26 AM   #89
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Putin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the worldPutin 2.3T is the leader of the world
I just jizzed in my pants..
2011 Mazdaspeed 3 [Sold]
2013 Ford F-150 XLT 3.5 Ecoboost
Putin 2.3T is offline   Reply With Quote
The Following User Says Thank You to Putin 2.3T For This Useful Post:
Zdraveca (03-07-2014)
 Old 03-07-2014, 06:08 AM   #90
Zdraveca's Avatar
Groans: 145
You dont know about "quiet that shit down at cold start" trick?
Sent from Pu
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
 Old 03-07-2014, 06:16 AM   #91
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
For a long time, I've been with Rob on this. This is the only platform I've ever seen that disregards such a simple, common, and effective upgrade so quickly. I believe a larger portion of it is that people just don't want to believe the gains partially because of cost involved as well as the varying results from different manufactures. If my wife wasn't driving the car it would most likely already have a catback as I believe the results are well worth it.
If I don't go full retard when I do the CBE, I'll make sure to do some comparison logs. I'll hopefully be taking the ko4 to it's absolute limits this year so the results should be quite telling.
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
The Following 6 Users Say Thank You to El_Diablo For This Useful Post:
JgamB (03-08-2014), Justin@Freektune (03-08-2014), littleloogy (03-12-2014), MZRSPEED (03-07-2014), rfinkle2 (03-07-2014), WetzMS3 (03-07-2014)
 Old 03-07-2014, 09:16 AM   #92
jrotaryb's Avatar
I would imagine any 3 inch catback should show similar performance gains but the systems with better fit/finish from Cobb/UR/Corksport aren't cheap. For most of us just doing bolt-ons, that $$ is probably better spent elsewhere IMHO.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 03-07-2014, 09:26 AM   #93
Every flow part adds "something" if well designed and installed properly. The bigger question is - what is the downside, is it worth it, and is there an alternative to arriving at the same power level? No one said the CBE does nothing.
12blkms3 (03-07-2014), btstarcher (03-08-2014), JgamB (03-08-2014)
 Old 03-07-2014, 09:50 AM   #94
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
yeah the argument has always been the money is better spent elsewhere.
rfinkle2 and HawkeyeGeoff like this.
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
The Following 4 Users Say Thank You to maisonvi For This Useful Post:
12blkms3 (03-07-2014), HawkeyeGeoff (03-07-2014), Justin@Freektune (03-08-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 10:17 AM   #95
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
exactly, most of the "dont get a catback" responses are in some noob intro thread where the guy had a honda before and thinks that dropping $850 on a catback is the best way to pickup 30 hp.
I hugged rfinkle2
 Old 03-07-2014, 10:40 AM   #96
12blkms3's Avatar
Groans: 68
Exactly, and most of the time people inquiring about cat backs are stock or close to stock. Imo, yes there are other modifications that are more important but doesn't mean we should completely rule it out.
It's more about when you get it, thats going to determine how much gain you'll see.
The Following 2 Users Say Thank You to 12blkms3 For This Useful Post:
jrotaryb (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 10:52 AM   #97
JgamB's Avatar
Posts: 2,566   (View Stats)
In my case, I had relegated it to last on my list if ever because of the perception of minimal gains. If Rob says he often sees better gains from CBE than a DP, then it's time we pressure a vendor to make us an axle back at a tolerable price.
I searched the company that @NCspecV81; used and didn't find anything for Mazda at all, haven't called them and probably won't because my Speed Daddy goes under the knife in a couple hours.
The Following 6 Users Say Thank You to JgamB For This Useful Post:
12blkms3 (03-07-2014), adamizme (03-07-2014), chaser27 (03-07-2014), El_Diablo (03-07-2014), HawkeyeGeoff (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 11:51 AM   #98
I'm going to go ahead and say that yes, CBE prices are absurd. But, there are options if you want the performance without a graceful sound.....like Speed Daddy. You may have to use a mallet and torch gun to get it fit, but it'll produce probably the same results performance-wise as more expensive options.
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
JgamB (03-08-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 12:21 PM   #99
NCspecV81's Avatar
Posts: 2,867   (View Stats)
NCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the world
Groaned at 32 Times in 17 Posts
Well if you travel over to the ST forum you can talk to OCDSpeed (Ollie) about the axleback. I know he has a jig for it since it was hanging on the underside of my car.
NCspecV81 is offline   Reply With Quote
The Following 2 Users Say Thank You to NCspecV81 For This Useful Post:
chaser27 (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 12:35 PM   #100
JgamB's Avatar
[/url]
The real question is how much did you pay?
The Following User Says Thank You to JgamB For This Useful Post:
 Old 03-07-2014, 12:56 PM   #101
NCspecV81's Avatar
PM'd.
The Following User Says Thank You to NCspecV81 For This Useful Post:
 Old 03-07-2014, 01:05 PM   #102
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
If you guys feel that the majority of the CBE exhaust prices are a bit high for what you are getting, you can usually find a custom exhaust shop in your area that can custom build you an exhaust for a few hundred less than many of the CBE's available now.
You can also kind of customize the sound if you go this route, because many of the shops will start the car and let you hear the volume and tone and add resonators or delete resonators while you are there.
That being said, I know that there are some vendors working on a single exit for the gen2 that should be much cheaper than most of the dual muffler design set-ups available now, and offer weight saving if you are ok with the second exit being left open.
MZRSPEED likes this.
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
12blkms3 (03-07-2014), Crarrs (03-07-2014), daafisch (03-07-2014), Easter Bunny (03-07-2014), El_Diablo (03-07-2014), HawkeyeGeoff (03-07-2014), JgamB (03-07-2014), Justin@Freektune (03-08-2014), MZRSPEED (03-07-2014), WetzMS3 (03-07-2014)
 Old 03-07-2014, 01:27 PM   #103
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
There's more than one working on this?
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
 Old 03-07-2014, 01:30 PM   #104
rfinkle2's Avatar
Groans: 298
I know one company is taking it very seriously, the other, it has been suggested to and they responded with something to the effect of "interesting".
 Old 03-07-2014, 01:30 PM   #105
Erick13Speed3's Avatar
Posts: 353   (View Stats)
Erick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the world
I know Corksport mentioned something about it a while ago. Could be wrong but I think they ended up dropping it because of the small market for it. I know I would have bought one
Erick13Speed3 is offline   Reply With Quote
 Old 03-07-2014, 02:34 PM   #106
You can also consider putting in a cutout in the test pipe. A fraction of the price and can be turned on and off very easily while giving you more flow than a large catback.
 Old 03-07-2014, 02:35 PM   #107
I'm sure that wouldn't be ear piercing at all lol
 Old 03-07-2014, 02:52 PM   #108
At least it's only sometimes . You can rig in a nice red NAWS switch for it.
5LOWMS6 (03-11-2014), HawkeyeGeoff (03-07-2014), maisonvi (03-07-2014)
 Old 03-07-2014, 02:53 PM   #109
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
My logs are consistently 10-15hp higher since I've gone 3" vs stock. I also didn't have an issue with creep, I do now.
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
 Old 03-07-2014, 02:56 PM   #110
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
I found side by side images I took before installing my Mangaflow if anyone want to compare a 3" inch exhaust to stock.
I was surprised at the difference when I first examined the stock midpipe. It has tons of restrictions that have to be eating up some ponies on a well flowing speed. It's hard to tell from the picture but the pipe going into the resonator actually reduce to fit inside the res. Also as you can see all the bends on the stocker appear to be crushed causing more restrictions.
Minus the stupid flange that needs to be fixed, the Mangaflow is well worth the money and gains you get. It's a lot less than most of the competitors even after fixing the flange. You can have this shipped to your door for $500.
Also I agree with @rfinkle2; that a shop can custom make you something for less than you might think.
Fixed flange
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
12blkms3 (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 03:14 PM   #111
Patty-Wack's Avatar
Posts: 885   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
damn it. You fuckers are going to make me buy a CBE now too.
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
The Following User Says Thank You to Patty-Wack For This Useful Post:
 Old 03-07-2014, 03:16 PM   #112
maisonvi's Avatar
Groans: 75
I know right? Son of a bitch. I liked when I didnt think it would do anything for me. That was cheaper.
The Following 5 Users Say Thank You to maisonvi For This Useful Post:
12blkms3 (03-07-2014), Cheapspeed (03-09-2014), HawkeyeGeoff (03-07-2014), Patty-Wack (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 05:10 PM   #113
JgamB's Avatar
My sanity has been restored - the below pic shows the mid chassis brace post-op. Those two humps you see are one piece all the way across OEM, significantly reducing clearance. The shop plasma cut that notch out, hammered down the sides and welded it back up. No more resonator pinging off that SOB.
I also had a resonator added to my test pipe - Dynomax 16" bullet fit perfectly and now the vibes in cabin are gone and the highway drone has been cut in half. (very tolerable, and I'm a vagina about NVH)
Total investment $350 CBE, $50 resonator, $100 labor. The only part of that really necessary is making some extra room over the chassis brace, and that can probably be accomplished with some flat washers and bending the rear hook out of your way, but I wanted something guaranteed to work the first time.
Almost forgot to mention LOLOLOLOL at you northerners and your filthy undercarriages
The Following 2 Users Say Thank You to JgamB For This Useful Post:
 Old 03-07-2014, 09:35 PM   #114
Raider is mah Homie
Groans: 2,978
Do we think the majority of the restriction is in the muffler? I have been considering hacking up my stock exhaust to go single outlet with a different muffler......... After I win the award for loudest stock muffler. In 40,000 miles it's completely shot, sounds very similar to the straight pipe above.
I hugged rfinkle2
 Old 03-07-2014, 09:41 PM   #115
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
corksport does now offer the single exit for the PU...
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
 Old 03-07-2014, 09:45 PM   #116
Yeh only 500 bones. TOTALLLLLLLY worth it.
El_Diablo (03-08-2014)
 Old 03-07-2014, 10:21 PM   #117
rfinkle2's Avatar
Groans: 298
The piping could be a restriction as well. I would think a majority of the restriction is the muffler itself though.
I didn't know they officially released that yet. Very nice.
Teddy will be running that on his car.
HawkeyeGeoff likes this.
Last edited by rfinkle2; 03-07-2014 at 10:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-07-2014, 11:57 PM   #118
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 54 Times in 27 Posts
Obx has a turbo back for $525 shipped. No real fitment issues and is quiet. That is what i will be getting soon. Only thing is muffler style is the same as oem. Being that the obx muffler is smaller and has a 3 inch opening, i hope that equates to better flow.
*COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite
specvspeedfreak is offline   Reply With Quote
 Old 03-08-2014, 06:34 AM   #119
Only data taking will tell.
Im going the mufflar less route to take full advantage of the monies I spent.
 Old 03-08-2014, 07:09 AM   #120
Dat8687's Avatar
Posts: 257   (View Stats)
Dat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond repute
Groaned at 60 Times in 22 Posts
CBE makes power.. It just doenst make the power cat deletes and DP make.
And my cat free exhaust is quieter than stock thanks to the Greddy elite exhaust
Dat8687 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/maybe-catback-exhaust-isn-t-just-expensive-165657/
Isuspectnargles comments on Downpipe or Catback for my 13 speed 3? This thread Refback 05-01-2015 01:07 PM
#1 Most Expensive Car Mod Oni Gen2 MS3 General Discussion 54 10-15-2016 08:04 PM
Why are APs so expensive? Roddiy Cobb Tuning 79 06-04-2013 05:45 PM
Who needs expensive tuning?! Doc MazdaSpeed 3/6 - ECU Computer Tuning 7 08-25-2008 09:37 PM
Bugatti Collection is expensive, but not Veyron-expensive Haltech Automotive News 0 08-08-2008 07:30 AM
Page generated in 0.63105 seconds with 41 queries
