Like Tree39Likes
 Old 04-15-2014, 09:20 PM   #161
YoursTruly's Avatar
Posts: 325   (View Stats)
YoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the worldYoursTruly is the leader of the world
Originally Posted by JgamB View Post
Nitto Tire - Fueled by Enthusiasts
25.47 for 235/40/18 Neo Gen. My speedo is also off 1.5mph at 100. If Vdyno calculations aren't accurate for changing out the stock dunflops, I can't help that.
Removing the Pu muffler is a good thing, that I will attest to. I was trapping ~109 on most passes at ENM on par with the other 330whp speeds that weren't running slicks with a TMIC as a handicap.
Weren't your logs taken with the same tires, just different exhausts? Even if the actual horsepower values are different than what would show on a real dyno, the difference in hp should still be valid because the tire diameter in vdyno was held constant.
I ran my pu without an axle-back for a couple days before I installed my ap and it was noticeably punchier, but I am sure that a tune would exaggerate this effect.
Also, don't run without an axle-back. It will melt the stuff in your trunk. FYI...
2010 MS3 "Maiko" - Sold
2006 MS6 "Izzy" - Sold - Totaled by next owner - Shell sold to NATOR AL member
1999 Miata "Geisha" - Hawnduh VTAK VeeSax Swop
2009 Rx8 "Queso" - powered by high rpm Doritos
2001 Ford F250 "Wampa" - All of the slow.
YoursTruly is offline   Reply With Quote
 Old 04-15-2014, 09:39 PM   #162
JgamB's Avatar
Posts: 2,566   (View Stats)
Yes they were - same tire. I plugged in the manufacturer's tire height for vdyno when I swapped and the gains appear to be largely valid. I did add a resonator to keep NVH within reason (holy shit so glad after 2K miles to ENM) but the losses from doing so appear to be negligible.
I'm going to agree that removal of the Pu muffler is probably the best bang for the buck, and then a person avoids resonators hitting the mid chassis brace or other fitment issues.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/maybe-catback-exhaust-isn-t-just-expensive-165657/
Isuspectnargles comments on Downpipe or Catback for my 13 speed 3? This thread Refback 05-01-2015 01:07 PM
#1 Most Expensive Car Mod Oni Gen2 MS3 General Discussion 54 10-15-2016 08:04 PM
Why are APs so expensive? Roddiy Cobb Tuning 79 06-04-2013 05:45 PM
Who needs expensive tuning?! Doc MazdaSpeed 3/6 - ECU Computer Tuning 7 08-25-2008 09:37 PM
Bugatti Collection is expensive, but not Veyron-expensive Haltech Automotive News 0 08-08-2008 07:30 AM
Page generated in 0.24834 seconds with 22 queries
