1 Attachment(s) Here's my first log after, after custom 3 in exhaust. The shop cuts the exhaust in sections to avoid crushed bends, they actually did a pretty good job. I paid $380 for 3 in piping with 2 resonators and 4 in tips. I'll post pics later, along with old logs that are saved to my work computer. The car definitely feels faster, boost is a few psi higher and holds longer, the only thing that doesn’t make sense is that my g/s seems a bit lower! But to be fair I haven't logged in this kinda heat in awhile. Also, I can boost 13psi and 270 g/s while in neutral, when before I would only see 3psi. |
The stock rear section of the pu exhaust is rediculously restrictive. I think all that is necessary is aftermarket axle back |
I like seeing threads like this, i'm learning so much :) I know I'm paying a lot for it, but I really like the sound of the cpe cbe. Should be getting it sometime mid-April. Rallysport had it backordered during their 10% off sale and won't be getting it in til then. |
Just got a quote from a shop... 300 installed.. Stainless steel 3" cat back and flow masters mufflers.. And resonators according to the loudness; I might go in to get it tomorrow |
crush bent? I'd stay away from crush bends. |
I guess one of my questions...are our resonators restrictive at all? What type of resonators are they? This would help us determine if just an axleback vs a catback would have very similar performance on the Pu |
With and without Axleback. With resonator delete stock pipe. :usa2: |
Not so sure I want to do it there anymore Sent from my SPH-L900 using Tapatalk 4 |
I used my speed daddy 3" piping and a used a greddy rs ricer special muffler. Total was around $500. Sounds aggressive as hell. Less weight also. But I can never leave anything alone. So I'll be going back to dual tips soon. Using the same speed daddy piping. |
I have someone local working on a reasonably priced axle back for the rest of Nator AL Pu's. That might turn into something worth talking about, I'll share pics n stuff once progress is made. |
I was very pleased with my OBX turboback exhaust, no cats, 1 muffler, 2 resonators, 3" piping, 4" tips, $507 shipped to my door. The OBX CBE is also a slightly different design than the full TBE (1 stock size muffler on the TBE, 2 mini mufflers on the CBE, don't know why that is) I think for $510 basically, you really can't beat the price for what you get. Spending over $1000 on an exhaust is insane to me. |
Lets not forget that if you're running a 3 inch downpipe, the stock midpipe will neck it down. There may not be a huge amount of power to be had with a replacement midpipe but there will be gains. IMO, the best buy right now is the ebay special CBE's for the gen2, just make sure you get the one that has the Y split evenly instead of the one that tends to flow more to the passanger muffler. |
If I ever make this a track only car, definitely just going with a straight 3" pipe. |
Hmmm time for me to make it a full turbo back! I having a xrappy weld in the rear Sent from my iPhone using Tapatalk |
2 Attachment(s) So finally here are some real logs. The first log was all mods in sig minus the customs catback, only resonator delete. I went to a local shop and had them make me a 3in catback with 2 resonators, 1 10" and 1 14" Second log I find very interesting, I went back to the exhaust shop and had them cut out the large 14" resonator that was right after the tp. Ive never seen anything over 300g/s until now. |
My Vdyno doesn't seem to want to open up, can someone post these for me please. Both runs were done in the same location, tire size 235 40 18, I weigh about 345 |
1 Attachment(s) Quote:
1 Attachment(s) redone for you. I'm glad when my logs reported similar that it appears not to be a fluke. http://www.mazdaspeedforums.org/foru...1&d=1396549309 |
I installed CS axle back exhaust last night. I'll try to get some logs tonight and post them up so we can see the difference between stock exhaust w/ racepipe and stock exhaust w/ racepipe & axle back. |
5 Attachment(s) OK. Here's what I ended up with. Logs labeled "-pre" are pre ABE and... well... you can figure it out... Both are taken on the same road. pre 1 and abe 1 are one direction and pre 2 and abe 2 are the opposite direction. @atvfreek; let me know what you think. |
2 Attachment(s) Quote:
1 Attachment(s) So I've been following this thread and decided that I was in disagreement with those saying that a catback system does nothing but add sound. So much so that I ordered an ultimate racing catback exhaust. The Vdyno's are two days apart on same tank of gas and same E85 map by @Lex; . The Maps labeled Post exhaust are obviously after putting exhaust on and the other two are with all my other mods in signature with CPE downpipe (catted) and stock catback. In the logs I saw MAF g's go about 8-10 higher than in any other previous log or map. Boost seemed to be a tad higher for that RPM in the other maps. |
4 Attachment(s) Ya no problem, not sure if my tune is complete but this is the latest stratified map im running... |
3 Attachment(s) Got another data point to add to this. Just installed the CS single-exit CBE last week and ran a log yesterday. Plenty of asterisks here available for the doubters to poke holes in the results (and I doubt the increase is actually as big as VD says it is), so I'll just go ahead and list them. Logs weren't done on the same day, weren't done on the same tires, BATs were 10 degrees higher in the stock logs, blah blah blah. Logs show that I'm moving 20 g/s more air. Datalogs 1 and 2 are the stock exhaust, datalog 8 is with the CBE. These were all done with the same OTS stage 1 map, 91 octane, and I still haven't run a new MAF cal since installing the exhaust. Only other power mod is an SRI/TIP. Stock logs were done on the stock wheels/tires. After CBE log was done on 245/40/17s. http://i797.photobucket.com/albums/y...pseae74b31.jpg |
looks like i was able to get about 15-20whp from installing my UR cbe, cleaning the valves, and installing TIGs. i'll take it. |
For what I can see most ppl are running different size than oem tires because oem is 25.08... Changing that number will inflate you hp numbers... Sent from my SM-N900P using Tapatalk 4 |
My charts are with aftermarket size tires but both my graphs are with that size so there is no change in consistency, so the increase is not from changing tire size |
Nitto Tire - Fueled by Enthusiasts 25.47 for 235/40/18 Neo Gen. My speedo is also off 1.5mph at 100. If Vdyno calculations aren't accurate for changing out the stock dunflops, I can't help that. Removing the Pu muffler is a good thing, that I will attest to. I was trapping ~109 on most passes at ENM on par with the other 330whp speeds that weren't running slicks with a TMIC as a handicap. |
| All times are GMT -7. The time now is 04:52 AM. |
