Like Tree55Likes
 Old 09-23-2013, 12:15 PM   #41
MS3CB's Avatar
Posts: 254   (View Stats)
MS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond reputeMS3CB has a reputation beyond repute
Groaned at 8 Times in 3 Posts
Originally Posted by hitmeagaintubesock View Post
I have no idea were the crank sensor is on the mzr engine? But assumed it was close to the fly wheel. I know my 944 and magnum v8 dodge engines and countless others place the crank sensor to read off the fly wheel.I figured the mazda would be simalar. I know other vehicles place the crank sensor behind the crank pulley as well.
Yes, behind the crank pulley is correct BUT you keep saying its near the flywheel.. if there is a flywheel and the crank pulley next to eachother.. (which is not possible) then IDK you have some freak 13' fucking ms3.
The crank pulley which either holds the timing belt or chain and usually a serp belt or two... is where the sensor is.. the flywheel is where the clutch and everything is.. two opposite sides my friend.
That would also mean.. the crank sensor would be reading the flywheel for timing positions...
MS3CB is offline   Reply With Quote
 Old 09-23-2013, 01:52 PM   #42
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
motherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the worldmotherfnmonsta is the leader of the world
Groans: 106
I'm gonna have to say that's damn near impossible. At least without completely demolishing a motor in the process.
For a flywheel to be so imbalanced that it throws out the timing ring enough that it isn't picked up by the cps, ON THE OTHER END OF THE CRANK, that motor isn't going to run long enough to throw any misfire codes.
Honestly man I am not sure how it is doing it either, when I was working at a mazda dealership I never came across this issue my self, but have talked to tech line about other issues about ms3 and this topic came up sometimes, and they told me they had a few cases where the flywheel was the cause of the misfire, and they even told me what to look pid's to look out for to see if the fly wheel was the culprit or not.
Now in some cases on the non turbo engines I did replace the emission harness to fix a random misfire issue. But in most cases on the mzr it was the coil pack or spark plugs.
go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle
suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55
motherfnmonsta is offline   Reply With Quote
 Old 09-23-2013, 02:02 PM   #43
hitmeagaintubesock's Avatar
Posts: 257   (View Stats)
hitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the worldhitmeagaintubesock is the leader of the world
Yes. My 944 uses the fly wheel to count the revolutions of the engine thru the crank sensor. The fly wheel is were the clutch is not were the belts are....the fly wheel is connected to the crank. The way that works is the crank sensor reads the revoulutions of the engine off the fly wheel. If sensor goes bad or the crank sensor reads less than 300 rpm the car won't crank . Also it works similar on the dodge v8s.the sensor sticks down between the bell housing of the trans and block of the engine and the crank sensor reads the position of the flywheel that is again connected to the crank....as stated I was not sure were the mazdas se crank sensor was located. I just searched for over an hour looking for tge post were the dealer fixed the miss fire code with fly wheel.....and couldn't find it. Now do think it would be safe to run a down pipe with out internals? I searched and can't find that either.....lol
2014 Ford mustang gt: k&n drop in filter, heart throb muffler deletes, sr performance front and rear sway bars, bmr lower control arms, h&r springs, bmr adjustable pan hard bar, bmr upper control arm, barton short shifter and two post bracket.
2012 speed3: gone but not forgotten
86 Porsche 944 turbo. Sold will be missed
88 dodge ram: 4 inch rough country lift, 35 1250 bfg mud terrain km2, ex fuel injected 318, edelbrock intake, edelbrock carb, mopar performance headers, 340 mopar petformance purple shaft cam, flowmaster single chamber mufflers with true duals
2011 ford fusion awd v6 kid hauler
hitmeagaintubesock is offline   Reply With Quote
 Old 09-23-2013, 02:41 PM   #44
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
We know what a flywheel is and where it is.
Even on an ms3.
Same tech line that couldn't figure this car out? Same one that told me the k04 isn't water cooled?
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 09-23-2013 at 02:43 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-23-2013, 03:04 PM   #45
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
Here is one of the ones I've seen where they suggested a flywheel, I think I may have read of another case or two besides this one where they tried that as a solution:
Brand new '13 speed P0300!!
They f'ed up the body on this one though after replacing the flywheel.
EDIT:
Also Post #9 here: Codes help, P2187 and P0300
2 post brownie though.
2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC
Chuthor is offline   Reply With Quote
The Following User Says Thank You to Chuthor For This Useful Post:
hitmeagaintubesock (09-23-2013)
 Old 09-23-2013, 03:17 PM   #46
Even on an ms3.
Yeah I'm aware but the other guy seemed to think I was having a hard time understanding the location of the fly wheel.??? Was just trying to clear that up.
 Old 09-23-2013, 03:41 PM   #47
Tokay444's Avatar
Groans: 793
You seem to be on your ms3.
Flywheel causing misfire on this motor, is grasping at straws.
Those really stupid crazy bendy straws.
Demodded.
The Seals
Last edited by Tokay444; 09-23-2013 at 03:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-23-2013, 04:20 PM   #48
I assure you lol that I know where the fly wheel is. I just stated that it could have been the issue based on a post that I read on here several months back. Do I have exact times or any thing no. Do I know what color speedo the guy that posted had on no...I don't. I can't even locate the post. I agree that it wouldn't be my first pic to solve the problem. That is just what I read. I still don't understand why you think I'm confused on the location of the fly wheel? Now,I did not know the location of the crank sensor on our engines. I assumed that it was reading off the fly wheel when it reads off the front of the crank.
 Old 09-23-2013, 06:02 PM   #49
Groans: 106
Even on an ms3.
Well one do we know if the tech even called tech line if he did he would of been told about that. Now there are some guys that work the tech line system that shouldn't and most times if I got a certain person I would hang up and call back hoping to get different person. I know there are at least 3 guys there that I have talked to on a regular baises that knows there shit pretty good, and there are 2 that I would hang up on a heart beat. But I am not going to defend mazda corp.
The Following User Says Thank You to motherfnmonsta For This Useful Post:
Tokay444 (09-23-2013)
 Old 09-23-2013, 06:26 PM   #50
MacheteJames's Avatar
Posts: 152   (View Stats)
MacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond reputeMacheteJames has a reputation beyond repute
Just to add to the flywheel/p0300 mystery: I don't know the technical reasons for this issue, but what I can tell you is that my car was a lemon buyback by Mazda that had this exact problem. In fact, the car used to belong to a former MSF forum member. The former owner spent over a month wrestling with misfires until the dealer agreed to buy the car back under lemon law and then sold him identical new MS3. The dealer had to get Mazda Japan involved to diagnose the problem, and they ended up swapping out the flywheel and the entire wiring harness to fix it. I saw the car at the dealer shortly after all of this happened and got a great deal on it, and the car has been fine since. Knock on wood.
MacheteJames is offline   Reply With Quote
 Old 09-23-2013, 06:41 PM   #51
Tokay444's Avatar
Groans: 793
I would say the wire harness for sure.
Flywheel? No.
Demodded.
The Seals
 Old 09-23-2013, 06:56 PM   #52
Spec's Avatar
Posts: 4,472   (View Stats)
Flywheel? No.
Well, after you replace everything else it becomes logical, from a part changers view.
The Following User Says Thank You to Spec For This Useful Post:
 Old 09-23-2013, 09:59 PM   #53
ep87's Avatar
Posts: 114   (View Stats)
ep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the worldep87 is the leader of the world
I have a copy of repair order, from the dealer for the 2012 speed(lemon) and it doesn't go into much detail, but a do seam to remember from one of my daily update call from the dealer when this was all going down that they had checked the crank position sensor and found no fault. Here's a list of the parts they did replace up to the time they swapped me into the 2013
4 injectors
both Cats.
oxygen sensor.
4 ignition coils
4 plugs
the PCM (powertrain control module)
and a few misc. gaskets, o-rings,etc.
My personal feeling is a wiring harness problem. next time I find myself at the dealer all check with the service writer and see if they ever fixed it and what it was.
CS RMM CS SS brake line,CS brake pads,CS SRI/TIP,CS OCC.Autotech internals,Cobb V3 AP, ETS TMIC, UR RP, Magnaflow CBE. Sure RSB Momo Revenge wheels 8.00x18 et40 stock 225/40 rubber.
Current Rides
2013 Mazda Speed3 CRYSTAL WHITE PEARL W/tech package
2012 VW GTI Black DSG w/Nav & sunroof
1970 Plymouth Duster 360 10.5:1 904w/ 2400 stall 3:73
1993 Ford Mustang LX 5.0 Vortech V-3 S/C
1996 Suzuki GSXF 750
1989 Suzuki GSXF 600 Project
2005 Yamaha WR450F
2005 Yamaha YZ450F
and coming this winter Ducati multistrada 1200
ep87 is offline   Reply With Quote
 Old 12-26-2013, 12:19 PM   #54
Ms.Agro's Avatar
Posts: 33   (View Stats)
Ms.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond reputeMs.Agro has a reputation beyond repute
Bought your '12 speed 3 from the same dealership and did not know about its previous issues. Turns out it was yours. We've had it for 5 days now, slowly lost power in 5th and 6th, and then christmas eve it completely broke down. Moving at a slugs pace winding down the gears to nothing. We are returning it today, with hope to get it replaced.
All of this to say, do you have any suggestions for us in the process?
Megan
Ms.Agro is offline   Reply With Quote
 Old 12-26-2013, 12:29 PM   #55
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
@ep87;
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
 Old 12-26-2013, 12:32 PM   #56
omgvance's Avatar
Posts: 1,221   (View Stats)
omgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the world
Groans: 29
Groaned at 6 Times in 6 Posts
Megan
damn
2008 True Red Juan | Fully Bolted > Stocked out > Traded
Partnered with DeftMotion
deftmotion.com
2013 Mica Black Pu
Performance
CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune
Suspension
Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines
Ricer Shit
Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP
omgvance is offline   Reply With Quote
 Old 12-26-2013, 01:14 PM   #57
Ms.Agro's Avatar
Thankfully he posted everything about it, this will severely help our case
 Old 12-26-2013, 01:20 PM   #58
Spec's Avatar
Approach them with he facts. What can they say?
 Old 12-26-2013, 01:27 PM   #59
Ms.Agro's Avatar
They won't give us the service history on the car, would be awesome to get it from you ep87 before we go in today
 Old 12-26-2013, 01:41 PM   #60
Ms.Agro's Avatar
I want to avoid the run around he first got with this car. It's issues where not taken care of obviously and I'm not waiting 30 days for it to be "fixed" then end up with the same bs after its grace period of working, however skirt that may be. For us, 5 days it lasted in seemingly prefect condition. No run around this time. They lied about the history on it to begin with.
 Old 12-26-2013, 01:42 PM   #61
ABolewski's Avatar
Posts: 1,279   (View Stats)
ABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the worldABolewski is the leader of the world
Groans: 52
Wowwwwwwww gotta love the internet.
Ms.Agro likes this.
2010 Alternative Lifestyle Blue Mazdaspeed3
(sold)
2008 Chevy Colorado. The only truck that comes with a lifetime guarantee...
ABolewski is offline   Reply With Quote
The Following 2 Users Say Thank You to ABolewski For This Useful Post:
bstover17 (12-26-2013), Cujo (12-30-2013)
 Old 12-26-2013, 01:50 PM   #62
JgamB's Avatar
Posts: 2,566   (View Stats)
Mmmm the plot thickens... we need some secret method of marking these cars when we offload them, like NATOR LEMON scratched into the trunk under the foam insert.
Cujo, doctavus, ABolewski and 2 others like this.
The Following User Says Thank You to JgamB For This Useful Post:
turbo test (12-26-2013)
 Old 12-26-2013, 01:53 PM   #63
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Wow....it was only a matter of time before someone else picked up the car.
Glad you were able to find it here. Good luck on getting them to take back the car. Maybe this time they will just junk it or sell it off for parts. Lol
Ms.Agro likes this.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 12-26-2013, 02:16 PM   #64
Spec's Avatar
Consult an attorney. Does your state have a lemon law?
Check into state or federal laws that prevent a car from being sold after it reaches lemon status and/or if they are obligated to tell you about it on your request for it.
Record your conversation with them. I caught a lot of those guys back tracking and contradicting themselves in the past.
Get with the BBB federal trade commission and consumer protection agency to see what they can do or advice they'll offer you.
 Old 12-26-2013, 02:22 PM   #65
JgamB's Avatar
Manufacturer and Dealer Services
Provide the required Lemon Law resale disclosure document to the first retail buyer/lessee of a vehicle reacquired by a manufacturer after a determination, adjudication or settlement under the Lemon Law. The Resale Disclosure and windshield disclosure forms are prepared and sent to the manufacturer by the Lemon Law Administration. The manufacturer is required to place the windshield disclosure in the vehicle and transfer the Resale Disclosure form with the vehicle. If a dealer knowingly obtains a Lemon vehicle but does not receive the Lemon Law resale forms directly from the manufacturer, auction or with the vehicle, the forms must be obtained from the Lemon Law Administration prior to a retail sale or lease.*
And as far as Mazda's responsibility if it was declared a lemon:
Lemon Law Resale Notice – A manufacturer, its agent or motor vehicle dealer to whom a motor vehicle is returned, is required to affix the "Lemon Law Resale Notice" to the lower center of the front windshield so as to be readily visible from the exterior of the vehicle. The Notice is provided to the manufacturer by the Attorney General’s Office. Only the retail purchaser of the vehicle may remove the Notice from the window.
The car probably wasn't declared an official lemon because it was reacquired by the dealer before action had to be taken, but maybe having a print out of this thread and the Washington State law will get them moving faster.
 Old 12-26-2013, 02:37 PM   #66
Ms.Agro's Avatar
You all read my mind. I will have a print out of this thread, highlight his key points and modifications he says have been done, a print out of the lemon law for Washington, and a printed application to turn them into the better business bureau, as well as recording the entire conversation.
 Old 12-26-2013, 03:06 PM   #67
Spec's Avatar
Default Mazda couldn't fix my 2012 MS3
Take a squeeze tube of Vaseline with you, kick the door open and say "WHOS FIRST!!!!" And have a massive 20" strap on belted to you.
Please be sure to highlight this as a key post.
Roddiy, donjohnk and swsmailman like this.
The Following 5 Users Say Thank You to Spec For This Useful Post:
Cujo (12-30-2013), Easter Bunny (12-27-2013), MizzyMS3 (12-26-2013), punkk77 (12-26-2013), Roddiy (12-27-2013)
 Old 12-26-2013, 03:31 PM   #68
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
when you meet with the representative, you should sit down and ask him/her politely for a cigarette and immediately follow with "because I like a good smoke after I've been fucked so hard" and proceed to whip out above mentioned strap on with vaseline all over your printed documents...if for anything else, it'll be a great story.
Ms.Agro likes this.
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
The Following 3 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
Cujo (12-30-2013), MizzyMS3 (12-26-2013), punkk77 (12-26-2013)
 Old 12-26-2013, 04:34 PM   #69
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
OMFG. This is a ROFLcopters moment. That stealership needs to be Old Yellered'.
Good Luck @Ms.Agro; fuck them good....For America.
Ms.Agro likes this.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
The Following User Says Thank You to HawkeyeGeoff For This Useful Post:
 Old 12-26-2013, 04:41 PM   #70
Ms.Agro's Avatar
I'm going to go America on all their asses!
HawkeyeGeoff and darthxar like this.
The Following User Says Thank You to Ms.Agro For This Useful Post:
ArmanRus (12-26-2013)
 Old 12-26-2013, 06:45 PM   #71
ep87's Avatar
If you go back and cafefully read the OP's original post. LOL you'll find that Mazda stepped in before I had to take them to mediation, most likely because they knew the OP had a case. And if they didn't make the OP happy and he took it to the state they would have had to eather scrap the car or at least brand the title which would have been a big loss. If I was you I'd PM the OP LOL. and send him your number maybe he would talk to you. I beleive the OP saw his old car the other day does it have great big Corksport decals on the side?
Current Rides
2005 Yamaha WR450F
2005 Yamaha YZ450F
 Old 12-26-2013, 06:57 PM   #72
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Damn I was just about to close thread when shit got even more interesting.
Subbed
Sent from my EVO using Tapatalk
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 12-26-2013, 07:19 PM   #73
Ms.Agro's Avatar
Yep, that's ours. Had smaller 2ft carbon fiber cs stickers on the front doorsdoors and our eyelids. I would gladly contact the OP, if I knew who he was, thought it was you... Were you not the original post starter?
 Old 12-26-2013, 07:33 PM   #74
Police
InkedInspector's Avatar
InkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the world
Groans: 312
Groaned at 43 Times in 19 Posts
Am I high? You are the OP, so unless your talking about yourself in the third person I'm confused as hell. Just double checked, yeah I'm not high. See that "Thread Starter" under your user name for this post?
The more I read it I'm gonna go with 99% chance you were talking in third person...kind of...calling yourself the OP....yeah.
DoMiNic, Ms.Agro and Mr.Agro like this.
InkedInspector is offline   Reply With Quote
 Old 12-26-2013, 07:43 PM   #75
Ms.Agro's Avatar
Yeah, no need to troll me. Just want answers. If he can't answer me, that's fine. I have my own way of getting out of this deal ahead of the dealership. Thanks OP
InkedInspector and Mr.Agro like this.
 Old 12-26-2013, 08:00 PM   #76
Mr.Agro's Avatar
Posts: 5   (View Stats)
Mr.Agro has a spectacular aura aboutMr.Agro has a spectacular aura about
Shouldn't be hard to get our way, if they couldn't fix the car the first time around I doubt it will be any different now. From the first time I drove this thing I knew something didn't feel right. I usually feel a lot better about things when I end up being right but in this case, not so much...
Ms.Agro likes this.
Mr.Agro is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr.Agro For This Useful Post:
InkedInspector (12-26-2013), Spec (12-26-2013)
 Old 12-26-2013, 08:32 PM   #77
Spec's Avatar
There is two? So an additional tube of Vaseline is in order.
Ms.Agro likes this.
 Old 12-26-2013, 08:36 PM   #78
Ms.Agro's Avatar
DP on AW and OP can join in
(AW= Dealership )
And if you don't know what DP is, then this joke is clearly not for you
The Following 2 Users Say Thank You to Ms.Agro For This Useful Post:
InkedInspector (12-26-2013), punkk77 (12-26-2013)
 Old 12-26-2013, 09:31 PM   #79
Police
Groans: 312
(AW= Dealership )
DUH! Downpipe, everyone knows that.
Ms.Agro likes this.
The Following User Says Thank You to InkedInspector For This Useful Post:
Roddiy (12-27-2013)
 Old 12-26-2013, 10:11 PM   #80
heeltoe's Avatar
Posts: 387   (View Stats)
heeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond repute
Groaned at 8 Times in 7 Posts
wow chalk one up for mazda customer service !!
///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Act Stage 1 Streetlite///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP V3. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt///ProClip,GPS,AP,I5///
heeltoe is offline   Reply With Quote
2012 Mini Cooper S Roadster vs. 2012 Mazda MX-5 Miata Special Edition Haltech Automotive News 0 08-22-2012 10:30 AM
Got DP'd I couldn't help it... AllLostThings MazdaSpeed 3/6 - Turbo Induction 57 11-05-2011 04:05 PM
E39 M5 couldn't get enough JNR5005 Street Racing Stories ( Bench Racing ) 16 12-31-2009 09:56 AM
Is this the iCar? Nah, couldn't be Haltech Automotive News 0 06-13-2008 10:00 AM
Page generated in 0.57476 seconds with 40 queries
