![]() | | #41 | ![]() |
![]() Join Date: Jun 2013 Location: Vernon, Connecticut
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 390
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score
The crank pulley which either holds the timing belt or chain and usually a serp belt or two... is where the sensor is.. the flywheel is where the clutch and everything is.. two opposite sides my friend. That would also mean.. the crank sensor would be reading the flywheel for timing positions... | |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
Now in some cases on the non turbo engines I did replace the emission harness to fix a random misfire issue. But in most cases on the mzr it was the coil pack or spark plugs.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 | |
![]() | | #43 | ![]() |
![]() Join Date: Apr 2012 Location: wilkes nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 146
| Not Ranked : 0 score Yes. My 944 uses the fly wheel to count the revolutions of the engine thru the crank sensor. The fly wheel is were the clutch is not were the belts are....the fly wheel is connected to the crank. The way that works is the crank sensor reads the revoulutions of the engine off the fly wheel. If sensor goes bad or the crank sensor reads less than 300 rpm the car won't crank . Also it works similar on the dodge v8s.the sensor sticks down between the bell housing of the trans and block of the engine and the crank sensor reads the position of the flywheel that is again connected to the crank....as stated I was not sure were the mazdas se crank sensor was located. I just searched for over an hour looking for tge post were the dealer fixed the miss fire code with fly wheel.....and couldn't find it. Now do think it would be safe to run a down pipe with out internals? I searched and can't find that either.....lol
__________________ 2014 Ford mustang gt: k&n drop in filter, heart throb muffler deletes, sr performance front and rear sway bars, bmr lower control arms, h&r springs, bmr adjustable pan hard bar, bmr upper control arm, barton short shifter and two post bracket. 2012 speed3: gone but not forgotten 86 Porsche 944 turbo. Sold will be missed 88 dodge ram: 4 inch rough country lift, 35 1250 bfg mud terrain km2, ex fuel injected 318, edelbrock intake, edelbrock carb, mopar performance headers, 340 mopar petformance purple shaft cam, flowmaster single chamber mufflers with true duals 2011 ford fusion awd v6 kid hauler |
![]() | | #44 | ![]() |
Groans: 793
| Not Ranked : 0 score We know what a flywheel is and where it is. Even on an ms3.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 09-23-2013 at 02:43 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #45 | ![]() |
![]() Join Date: Sep 2012 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,033
| Not Ranked : 0 score Here is one of the ones I've seen where they suggested a flywheel, I think I may have read of another case or two besides this one where they tried that as a solution: Brand new '13 speed P0300!! They f'ed up the body on this one though after replacing the flywheel. EDIT: Also Post #9 here: Codes help, P2187 and P0300 2 post brownie though.
__________________ 2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC |
| The Following User Says Thank You to Chuthor For This Useful Post: | hitmeagaintubesock (09-23-2013) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score Yeah I'm aware but the other guy seemed to think I was having a hard time understanding the location of the fly wheel.??? Was just trying to clear that up.
![]() | | #47 | ![]() |
Groans: 793
| Not Ranked : 0 score You seem to be on your ms3. Flywheel causing misfire on this motor, is grasping at straws. Those really stupid crazy bendy straws.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 09-23-2013 at 03:41 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #48 | ![]() |
| Not Ranked : 0 score I assure you lol that I know where the fly wheel is. I just stated that it could have been the issue based on a post that I read on here several months back. Do I have exact times or any thing no. Do I know what color speedo the guy that posted had on no...I don't. I can't even locate the post. I agree that it wouldn't be my first pic to solve the problem. That is just what I read. I still don't understand why you think I'm confused on the location of the fly wheel? Now,I did not know the location of the crank sensor on our engines. I assumed that it was reading off the fly wheel when it reads off the front of the crank.
![]() | | #49 | ![]() |
Groans: 106
| Not Ranked : 0 score Well one do we know if the tech even called tech line if he did he would of been told about that. Now there are some guys that work the tech line system that shouldn't and most times if I got a certain person I would hang up and call back hoping to get different person. I know there are at least 3 guys there that I have talked to on a regular baises that knows there shit pretty good, and there are 2 that I would hang up on a heart beat. But I am not going to defend mazda corp.
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | Tokay444 (09-23-2013) |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2012 Location: Bronx, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 110
| Not Ranked : 0 score Just to add to the flywheel/p0300 mystery: I don't know the technical reasons for this issue, but what I can tell you is that my car was a lemon buyback by Mazda that had this exact problem. In fact, the car used to belong to a former MSF forum member. The former owner spent over a month wrestling with misfires until the dealer agreed to buy the car back under lemon law and then sold him identical new MS3. The dealer had to get Mazda Japan involved to diagnose the problem, and they ended up swapping out the flywheel and the entire wiring harness to fix it. I saw the car at the dealer shortly after all of this happened and got a great deal on it, and the car has been fine since. Knock on wood. |
![]() | | #51 | ![]() |
Groans: 793
| Not Ranked : 0 score I would say the wire harness for sure. Flywheel? No.
![]() | | #52 | ![]() |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Well, after you replace everything else it becomes logical, from a part changers view.
__________________ |
| The Following User Says Thank You to Spec For This Useful Post: | Tokay444 (09-23-2013) |
![]() | | #53 | ![]() |
![]() Join Date: Aug 2012 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
(Thread Starter) | Not Ranked : 0 score I have a copy of repair order, from the dealer for the 2012 speed(lemon) and it doesn't go into much detail, but a do seam to remember from one of my daily update call from the dealer when this was all going down that they had checked the crank position sensor and found no fault. Here's a list of the parts they did replace up to the time they swapped me into the 2013 4 injectors both Cats. oxygen sensor. 4 ignition coils 4 plugs the PCM (powertrain control module) and a few misc. gaskets, o-rings,etc. My personal feeling is a wiring harness problem. next time I find myself at the dealer all check with the service writer and see if they ever fixed it and what it was.
__________________ CS RMM CS SS brake line,CS brake pads,CS SRI/TIP,CS OCC.Autotech internals,Cobb V3 AP, ETS TMIC, UR RP, Magnaflow CBE. Sure RSB Momo Revenge wheels 8.00x18 et40 stock 225/40 rubber. Current Rides 2013 Mazda Speed3 CRYSTAL WHITE PEARL W/tech package 2012 VW GTI Black DSG w/Nav & sunroof 1970 Plymouth Duster 360 10.5:1 904w/ 2400 stall 3:73 1993 Ford Mustang LX 5.0 Vortech V-3 S/C 1996 Suzuki GSXF 750 1989 Suzuki GSXF 600 Project 2005 Yamaha WR450F 2005 Yamaha YZ450F and coming this winter Ducati multistrada 1200 |
![]() | | #54 | ![]() |
![]() Join Date: Sep 2013 Location: Where you live...
| Not Ranked : 0 score Bought your '12 speed 3 from the same dealership and did not know about its previous issues. Turns out it was yours. We've had it for 5 days now, slowly lost power in 5th and 6th, and then christmas eve it completely broke down. Moving at a slugs pace winding down the gears to nothing. We are returning it today, with hope to get it replaced. All of this to say, do you have any suggestions for us in the process? Megan |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2010 Location: Dover, DE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 429
| Not Ranked : 0 score @ep87;
__________________ 2012 CWP MS3 w/ Tech Package Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder |
![]() | | #56 | ![]() |
![]() Join Date: Mar 2012 Location: Greensboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,087
Groans: 29
Groaned at 6 Times in 6 Posts
__________________ 2008 True Red Juan | Fully Bolted > Stocked out > Traded Partnered with DeftMotion deftmotion.com 2013 Mica Black Pu Performance CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune Suspension Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines Ricer Shit Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP | |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Thankfully he posted everything about it, this will severely help our case |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Approach them with he facts. What can they say?
![]() | | #59 | ![]() |
| Not Ranked : 0 score They won't give us the service history on the car, would be awesome to get it from you ep87 before we go in today |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I want to avoid the run around he first got with this car. It's issues where not taken care of obviously and I'm not waiting 30 days for it to be "fixed" then end up with the same bs after its grace period of working, however skirt that may be. For us, 5 days it lasted in seemingly prefect condition. No run around this time. They lied about the history on it to begin with. |
![]() | | #61 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
Groans: 52
| Not Ranked : 0 score Wowwwwwwww gotta love the internet.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
![]() | | #62 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Mmmm the plot thickens... we need some secret method of marking these cars when we offload them, like NATOR LEMON scratched into the trunk under the foam insert.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following User Says Thank You to JgamB For This Useful Post: | turbo test (12-26-2013) |
![]() | | #63 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score Wow....it was only a matter of time before someone else picked up the car. Glad you were able to find it here. Good luck on getting them to take back the car. Maybe this time they will just junk it or sell it off for parts. Lol
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() | | #64 | ![]() |
Check into state or federal laws that prevent a car from being sold after it reaches lemon status and/or if they are obligated to tell you about it on your request for it. Record your conversation with them. I caught a lot of those guys back tracking and contradicting themselves in the past. Get with the BBB federal trade commission and consumer protection agency to see what they can do or advice they'll offer you.
__________________ | |
![]() | | #65 | ![]() |
| Not Ranked : 0 score Manufacturer and Dealer Services Provide the required Lemon Law resale disclosure document to the first retail buyer/lessee of a vehicle reacquired by a manufacturer after a determination, adjudication or settlement under the Lemon Law. The Resale Disclosure and windshield disclosure forms are prepared and sent to the manufacturer by the Lemon Law Administration. The manufacturer is required to place the windshield disclosure in the vehicle and transfer the Resale Disclosure form with the vehicle. If a dealer knowingly obtains a Lemon vehicle but does not receive the Lemon Law resale forms directly from the manufacturer, auction or with the vehicle, the forms must be obtained from the Lemon Law Administration prior to a retail sale or lease.* And as far as Mazda's responsibility if it was declared a lemon: Lemon Law Resale Notice – A manufacturer, its agent or motor vehicle dealer to whom a motor vehicle is returned, is required to affix the "Lemon Law Resale Notice" to the lower center of the front windshield so as to be readily visible from the exterior of the vehicle. The Notice is provided to the manufacturer by the Attorney General’s Office. Only the retail purchaser of the vehicle may remove the Notice from the window. The car probably wasn't declared an official lemon because it was reacquired by the dealer before action had to be taken, but maybe having a print out of this thread and the Washington State law will get them moving faster.
![]() | | #66 | ![]() |
| Not Ranked : 0 score You all read my mind. I will have a print out of this thread, highlight his key points and modifications he says have been done, a print out of the lemon law for Washington, and a printed application to turn them into the better business bureau, as well as recording the entire conversation. |
![]() | | #67 | ![]() |
| Not Ranked : 0 score Take a squeeze tube of Vaseline with you, kick the door open and say "WHOS FIRST!!!!" And have a massive 20" strap on belted to you. Please be sure to highlight this as a key post.
| The Following 5 Users Say Thank You to Spec For This Useful Post: | Cujo (12-30-2013), Easter Bunny (12-27-2013), MizzyMS3 (12-26-2013), punkk77 (12-26-2013), Roddiy (12-27-2013) |
![]() | | #68 | ![]() |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score when you meet with the representative, you should sit down and ask him/her politely for a cigarette and immediately follow with "because I like a good smoke after I've been fucked so hard" and proceed to whip out above mentioned strap on with vaseline all over your printed documents...if for anything else, it'll be a great story.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
![]() | | #69 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score OMFG. This is a ROFLcopters moment. That stealership needs to be Old Yellered'. Good Luck @Ms.Agro; fuck them good....For America.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | punkk77 (12-26-2013) |
![]() | | #70 | ![]() |
| Not Ranked : 0 score I'm going to go America on all their asses! |
| The Following User Says Thank You to Ms.Agro For This Useful Post: | ArmanRus (12-26-2013) |
![]() | | #71 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you go back and cafefully read the OP's original post. LOL you'll find that Mazda stepped in before I had to take them to mediation, most likely because they knew the OP had a case. And if they didn't make the OP happy and he took it to the state they would have had to eather scrap the car or at least brand the title which would have been a big loss. If I was you I'd PM the OP LOL. and send him your number maybe he would talk to you. I beleive the OP saw his old car the other day does it have great big Corksport decals on the side?
![]() | | #72 | ![]() |
![]() Join Date: Nov 2010 Location: Ft Bragg, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,632
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Damn I was just about to close thread when shit got even more interesting. Subbed Sent from my EVO using Tapatalk
__________________ 2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned ![]() |
![]() | | #73 | ![]() |
![]() | | #74 | ![]() |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
Groaned at 43 Times in 19 Posts
The more I read it I'm gonna go with 99% chance you were talking in third person...kind of...calling yourself the OP....yeah.
__________________ ![]() Last edited by InkedInspector; 12-26-2013 at 07:46 PM. | |
![]() | | #75 | ![]() |
| Not Ranked : 0 score Yeah, no need to troll me. Just want answers. If he can't answer me, that's fine. I have my own way of getting out of this deal ahead of the dealership. Thanks OP |
![]() | | #76 | ![]() |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() ![]() Thanks: 0
| The Following 2 Users Say Thank You to Mr.Agro For This Useful Post: | InkedInspector (12-26-2013), Spec (12-26-2013) |
![]() | | #77 | ![]() |
| Not Ranked : 0 score There is two? So an additional tube of Vaseline is in order.
![]() | | #78 | ![]() |
| Not Ranked : 0 score DP on AW and OP can join in (AW= Dealership )And if you don't know what DP is, then this joke is clearly not for you Last edited by Ms.Agro; 12-26-2013 at 09:09 PM. |
| The Following 2 Users Say Thank You to Ms.Agro For This Useful Post: | InkedInspector (12-26-2013), punkk77 (12-26-2013) |
![]() | | #79 | ![]() |
Groans: 312
__________________ ![]() | |
| The Following User Says Thank You to InkedInspector For This Useful Post: | Roddiy (12-27-2013) |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2009 Location: Monterey Park, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score wow chalk one up for mazda customer service !!
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Act Stage 1 Streetlite///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP V3. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt///ProClip,GPS,AP,I5/// |
| 2012 Mini Cooper S Roadster vs. 2012 Mazda MX-5 Miata Special Edition | Haltech | Automotive News | 0 | 08-22-2012 10:30 AM |
| Got DP'd I couldn't help it... | AllLostThings | MazdaSpeed 3/6 - Turbo Induction | 57 | 11-05-2011 04:05 PM |
| E39 M5 couldn't get enough | JNR5005 | Street Racing Stories ( Bench Racing ) | 16 | 12-31-2009 09:56 AM |
| Is this the iCar? Nah, couldn't be | Haltech | Automotive News | 0 | 06-13-2008 10:00 AM |
