FYI - I have heard of similar problems on 350Z's which caused similar issues. Improper torque of the crank pulley bolt caused the keyway on the crank and the pulley to wear over time, resulting in a wobbly assembly and the inevitable code. |
Also it isn't throwing a code at this point, something I find kind of odd. I am unsure of what AW has found since they have had the car back but I'm willing to bet they are more stumped than ever. I am suppose to discuss the details of what they find wrong with it today and will post what I find out later on. |
Agreed, it doesn't sound like your issue - do you have any method of data logging? I wonder what the fuel pressure looks like when symptoms appear. |
3 Attachment(s) UPDATE: So, its been a few months (8!) since we've had the MS3 back and in good order. The dealership replaced the wiring harness and said that it was good to go. We where skeptical. Wiring harness? Really? But, since we've had it back, 0 issues to report. We have since bought the newest Cobb tuner, stage III CS intake, and have been using a prototype unrestricted single exit exhaust. Next step is the fuel pump internals and down pipe. Sorry its taken so long for us to update, life has been busy for us and the car has been perfect, we have pretty much just been waiting for something wrong to happen again before we posted that it was in such good condition, and luckily, we have no complaints. This car has turned out to be quite the STI killer, there is nothing I love more than to beat an STI kid. Lol. The build will be posted once we start building greater than the Cobb tune and intake mods. Thanks everyone for the support! :You_Rock_Emoticon: |
Any idea how they diagnosed the wiring harness, or how much it would cost to fix out of warranty? I had attributed the P0300 my car threw every once in a while to burning through plugs (happened about every 15k miles, replace plugs, and I'd be good for another 15k). Now, the car is out of warranty, and the code is back with 3000 miles on the plugs. . . I've seen the flywheel mentioned too, with no real explanation about how it happens, but the idea of paying to have the flywheel replaced sounds like it'll be painful for my wallet. |
As far as your engine code, have you checked anything else that comes up with that code? Here's a quick list of what comes up under that engine code. Just changing the plugs may not be good enough. - Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure |
There is a how to on stretching the spring in the coil wire for better contact. |
I'm taking the car to the dealer tomorrow. Hopefully they won't try to blow me off since the car is out of warranty and they stand to make money by fixing it. |
Quick reference^ |
Time for an EGR delete |
if that's what is, I'll have an awesome excuse to do a delete and add an AP. Problem is, it's going to be a week and a half and ~1200 of driving before I have a chance to do it. EGR delete, valve cleaning, and an OCC were on my to-do list for this summer, before I sold the house. Of course, after I don't have a place to work on the car, and since the warranty is expired, stuff starts going wrong. update: because I know somebody else will have the same problem and probably search for it. The dealer says the P0300 was being triggered on deceleration. Their story is there's a TSB about something being off with the ECU parameters causing the random misfire. They're fixing it relatively cheap (under $200), so I'm happy |
Glad they aren't trying to screw you over, that's a good deal |
I know how much that harness costs. Ask me how I know. |
It's illegal in many states. Heck, FL legally cannot have an afrermarket exhaust! |
Yeah pretty much. |
Although, the cops won't mess with many domestics (excluding nobalts and peons lol) for having exhaust but, they'll probably be a dick if you're in an import. Subject to vary Depending on your location. In TEXAS so, lots of 'MERICA here. I'm sure if you had a improved emissions system, you would be within the law and also gay. Fuck nature, racecars. |
| All times are GMT -7. The time now is 04:51 AM. |
