Like Tree2Likes
  • 1 Post By MSMS3
  • 1 Post By DadliMS3
 Old 10-22-2019, 05:25 PM   #1
DadliMS3's Avatar
Posts: 13   (View Stats)
DadliMS3 will become famous soon enoughDadliMS3 will become famous soon enough
Default MS3 Gen 2 Electrical/ ecu problem?
So guys, ive had my 2011 JDM speed for the last 5 weeks, and its been nothing but smiles on my face as having been my first performance car that I've owned but not driven. Any ways issues started 2 weeks ago when my traction control, abs light and rvm light came on a cold start. it stayed on for a few days and then came off and then back again. I went to a diagnostics mechanic and the diagnosis came back with abs faults and when we took it for a drive all 4 wheel sensors were unresponsive. He said that its highly unlikely all four would be faulty and said maybe its the abs module. Anyways drove off and the lights came off. The back again and stays on. This has been the cycle for 2 weeks with it coming off then coming on and staying on even with normal driving
issue 2:
Today was jus sitting idle and the car started reving by itself and a warning light on the dash screen comin on and off ...
I like this car but these things are doing my head in and wondering if i made a mistake.
anyone have anythoughts
DadliMS3 is offline   Reply With Quote
 Old 10-22-2019, 06:01 PM   #2
MSMS3's Avatar
Posts: 2,738   (View Stats)
Groans: 154
issue 2:
Please go somewhere and get it scanned for diagnostic error codes, if you don’t have a scanner, and report them here.
There is little we can do without those codes, and potentially a lot of help we can offer with them.
DadliMS3 likes this.
 Old 10-22-2019, 06:44 PM   #3
DadliMS3's Avatar
Thanks man, I will try and get codes this wekeend, just annoyed i gotta pay another 50USD to get it done
The Following User Says Thank You to DadliMS3 For This Useful Post:
MSMS3 (10-23-2019)
 Old 10-22-2019, 07:42 PM   #4
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
You can also just acquire an ELM327-style OBD2 reader that can interface with the Torque app. That will allow you to read and clear codes.
MSMS3 (10-23-2019)
 Old 10-23-2019, 11:14 AM   #5
Jeff23spl's Avatar
Posts: 2,133   (View Stats)
is torque reading abs codes ? I think abs are on the lsCAN network and torque is just reading mscan error codes.
Instead you can also ack the same cheap elm327 with a toggle switch and load Forscan app and switch to the other communication protocol and pins to reach abs and air bag computers.
https://www.forscan.org/forum/viewtopic.php?f=4&t=4
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Vansquish (10-23-2019)
 Old 10-23-2019, 12:21 PM   #6
DadliMS3's Avatar
Unfortunately where I live on this side of the world, it's abit of a hassle to get that device in a good time frame. So I have to stick to goin to a mechanic with the diagnostic device. The car runs good except for those faults.. when i first got the car the passenger side light wasn't working despite having a new bulb and all fuses being intact... then a week later it just started working but the AFS malfunctions from time to time.
 Old 10-23-2019, 01:13 PM   #7
Jeff23spl's Avatar
with your story of intermittent problems, i would add ground strap between body-engine-battery negative (the big3 used in car audio) and check all ground in the engine bay following electric diagram and make sure all of them are clean and tight.
then i would check both fuse box connection (in the back)
Is the engine been replaced ? Could it be a flooded and repaired car ?
which part of the world take more time to get Chineese parts than in North America ?
Wife drive 2010 CX7
 Old 10-23-2019, 08:34 PM   #8
DadliMS3's Avatar
Noted, will check that out thanks for the advice. The car is a fresh import to the island, its only been here 1 year and it was driven by a friend of mine since it landed. and as far as i kno it never gave any issues. The engine hasnt been replaced as far as i know from japan, but the driver side (passenger side for USDM) needs replacing. I live in the caribbean and the logistics to get parts and not to mention the tax duty on car items is like 40 or 60% of the value including shipping lool!
 Old 11-08-2019, 08:33 PM   #9
DadliMS3's Avatar
found the cause for the abs/traction control light issue was a faulty sensor. have two ordered and shipped as we speak.
Jeff23spl likes this.
Vansquish (11-11-2019)
Confusing electrical problem ShintaroIchi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-02-2015 01:30 AM
Wierdass Electrical Problem marco427 Gen2 MS3 General Discussion 5 06-18-2014 06:53 AM
Strange Electrical Problem, Help Please Amped MazdaSpeed 3/6 - Car Audio & Electronics 15 09-26-2012 12:45 AM
Yet another electrical problem MazdaSpeedster Mazdaspeed3/6 General Discussion 2 01-29-2012 05:56 PM
Page generated in 0.30602 seconds with 23 queries
